Question about Acer Aspire 5600 Series 5630-6951 Laptop
Acer Aspire won't start
Hello I have an Acer Aspire, i'm not at home but i believe it is a model #5920-6914. It has worked perfect for the past 6 monthes i've owned it. One day after not turning it on for about 3 weeks it simply would not start. No lights, no fan, nothing. I tried running it off of a live outlet thinking maybe the battery was just dead but still nothing. The charge light does not come on but the light on the actual charger does. So it seems as if there is just no power getting to the laptop, could this be the computer's motherboard? The charger consists of two separate components, the part with the cord that goes into the wall and the rectangular black box with the green light (the green light comes on) and then the cord that plugs into the recangular box and goes into the computer. Could the problem be with this second cord running from the box to computer? Please help!!!
  • 1 more comment
  • mr9010 Aug 26, 2008
    SAME THING. ANY SOLUTIONS?
  • anad_ellehci Jan 05, 2009
    i have the same problem. did anyone got their laptops fixed?
  • kairast Apr 27, 2009
    Here the exact same problem. I suppose its the motherboard, not routing the power into the computer
Iv got an acer aspire as well and experianced the same isues with the power light not comeing on when charging it.i did how ever mange to diagnoes my problem.It was the sockit that you plug the power cable into.that sockit has a very fine copper conection between it and the mother board whitch had frizaled out due to the fact i use the laptop at work so its always pluged in to mains because its on all day long.This can burn out the copper conection,I found an apliance electrician to solder a new thicker conection between the mother board and the housing you plug the powersupply in to he also strenthined the houseing it self because it was starting to crack up from all the use.Im happy to say that iv had smooth sailing ever since, pluss i didnt have to pay the outrageous fees that acer would have charged to repare it :) .I do hope this helps others with similar problems.
Posted on Jul 08, 2009
I had the same problem with my acer aspire 3050. I found the power cord connection to the computer is not stable. Playing around with the connection point makes the power light goes on and off. After several testing with the different points inside, I decided that the loose end is the touch point for the central pin of the power cord. Then I made the pin sticking out 1mm and plug it in. Here it works! power comes back stable!.
Posted on Aug 27, 2008
    Problem Solver:
  • 3 Answers
Check the battery make sure it has full contact. Im having a problem with my acer aspire 5610 as welli bought a new battary and it says its not an acer battery. i match up the voltage and every things its the same and it has the same case and prongs and it still wont charge the battary light just blinks and it wont charge and at start up it says atteniton not an acer battary then starts the acer screen then just show the warning agin can any one help me???
Posted on Aug 11, 2008
I'm also having this problem. Sometimes if I move the connection a little I can get it to charge. I don't know what happened though. Yesterday I came home and bam it won't charge. It's an Aspire 5600 series. Let me know if you come up with anything...
Posted on Aug 08, 2008
    Problem Solver:
  • 6 Answers
Make sure the plug is completely secure into the back of the laptop.. i also have an acer aspire..
maybe someone spilled their drink on it...
..idk..
Posted on Jul 30, 2008
2 Suggested Answers
mwalker02
  • 41 Answers
SOURCE: Acer Aspire won't start
There is one common flaw with most all laptops. The socket plug for the power cord is connected to the motherboard. When you plug the power cord into this socket it applies pressure or weight on the socket inside the computer. It sounds as if your charge cord is working. Moving the computer around while it is plugged in can cause even more stress on the plug socket.
Try this...but be careful...using a small item such as a toothpick or other non-metalic item...push up and down on the plug socket. If it moves around this is not normal and probably the cause of your problem.
I fixed my laptop by soldering the contacts of the socket back down to the board. I don't suggest doing this yourself unless you know how to take a laptop apart. Check with your local computer repair shop and have them give you an estimate to either fix by reconnecting or replacing the motherboard. Hope this helps. Thanks!
Posted on Jun 01, 2009
I have an Acer one aspire that won't start. I keep
Dear user,
Please try to restore it to factory mode or re-install OS
Aug 22, 2012 | Acer Aspire One PC Notebook
ACER ASPIRE ONE D255E POWER CORD WON'T CHARGE BATTERY PLUGGED IN THE POWER CORD WON'T CHARGE THE BATTERY ALL THE TIME ...
Hi: Acer chargers have a very short life time, in the past 2 years I had bought 2. Just buy a new one from amazon they're very inexpensive. Here's the link: http://www.amazon.com/Laptop-Adapter-Aspire-AOA110-AOA150/dp/B0028LK6IU/ref=pd_bxgy_e_text_b
Regards,
Sep 25, 2011 | Acer Computers & Internet
I have an acer aspire 5050 running windows 7 home premium and I cannot for the life of me get the webcam to work. I downloaded a driver and it looks as though the webcam works and the little green light...
Hello download the driver here:
http://support.acer.com/product/default.aspx?modelId=43
Please select your windows system.
Download the driver and unzip the file before you install.
If the model is wrong select the right one here:
http://us.acer.com/ac/en/US/content/drivers
Select first notebook.
Next aspire.
The model number.
And your windows system.
Good luck
Sep 19, 2011 | Acer Aspire 5050-3242 Notebook
Where can I get the download manual for Acer Aspire 5253?
Thank you for using FixYa
r
Here is the exact page link for your manual.
http://www.getdriver.com/redirectdownload/3321/dritek-launchmanager-application-5-0-5-6-6-mb-acer-aspire-5253-series-application-windows-7-x86-x64/
I hope this was useful and please comment if this was helpful to you.
Mar 30, 2011 | Acer Computers & Internet
My laptop won't turn on. It goes past the logo screen then goes blank.
shut down the laptop and start it again...immediately start hitting f8 key..select option ....safe mode....
if it works go to start .accessories and system tools and restore the system to previous date where in it was working fine..
it should be able to work perfect then
May 30, 2010 | Acer Aspire 5600 Series 5630-6951 Laptop
I have a hp printer how you get it to work with the acer aspire one 8.9 there is no dvd drive
Hello !
Since you have a connection to the Internet, you can download the driver.
Here's the HP Website (copy / paste into your browser) - start by selecting "Download drivers ..." and entering your printer's model number.
http://welcome.hp.com/country/us/en/support.html
Hope this helps.
Oct 06, 2009 | Acer Aspire One Netbook 8.9" Notebook
Ok i have had my acer aspire 5315-2326 for a year
try downloading the compatible acer aspire webcam software for your laptop. My laptop is also acer. It is aspire 4730z and it works perfectly fine. I think the software you are using is not compatible with your laptop.
Also most aspire models have lesser durability webcams. It gets really annoying when webcams of aspire won't work. I completely understand your situation.
Just follow my instruction and it will work perfectly fine.
Aug 09, 2009 | Acer Aspire 5500 5570-2609 Laptop
Jun 01, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer opticam
Is it possible that you rotated the camera past its 225 degree maximum and damaged it? Just curious. There are several other camera types installed on the same model. It might be an idea to verify that. Also XP or Vista drivers ? Just a few questions. Best
Feb 19, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5600 Series 5630-6951 Laptop Logo
1,047 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
