TV DVD control button faulty - Televison & Video
  • 260 Answers
Usually when a button is faulty it is caused by wear and tear or dirt. Use compressed air to clean out the dirt. If that does not work, replace the remote.
Posted on Jul 30, 2008
Unit will play a VHS when using button manually. It doesnt matter which button is pressed on the remote, the display on the unit says 'DVD 3'
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Apr 14, 2016 | Panasonic DMREZ48VK DVD Recorder/VCR Combo...
Living solutions Jumbo remote programming
Jumbo remotes all seem to come from the same source regardless of the "brand". I do not see a code listed for your Trutech TV so you will have to do a code search. To do a search:
1. Turn on the TV
2. Press and hold the CODE SEARCH button until the red indicator stays on, then release the button
3. Press and release the TV button. The indicator blinks once.
4. Point the remote directly toward the front of the TV
5. Press the on-off button (top right) down until the indicator stays on
6. The indicator flashes until your TV turns off.
7. Press the ENTER button to store the code.
If the TV code is correct, you should be able to control the built-in DVD using the appropriate buttons on the remote. You just have to press the DVD button to do this.
Dec 24, 2013 | Universal Remote Control Hampton Bay...
Remote & Buttons on TV not working
There are three chances for this fault. [1]. There is no infrared emission from the remote control. [2] Infrared sensor inside the TV is faulty. [3]. Front panel controls have been locked, using remote control, prior to this fault, and the set was switched OFF by remote control. Check the remote control, for its infrared emission. Try it with fresh batteries. You can see all these faults and related help how to follow. Try this link, and select the site named Electro-help. Pull up older posts there.
Jul 06, 2012 | Televison & Video
My dvd remote control,turn on and off the tv but not the dvd, so i need to know how to change back to just to operate the dvd, (samsung digital home cinema system) thanks,
Press the DVD button on the top of your remote to operate it with the dvd player. You remote is multi purpose on you can use it for controlling Samsung DVD and TV. When you press the DVD button it will change to the DVD remote state. When you press the TV button then it will change as remote for the TV. So if yo want to operate DVD with the remote just press the DVD button and if you want to control the TV then press the TV button.
Jun 09, 2011 | Samsung DVD-VR329
Connected DVD player to Sanyo DS27930 TV via input
According the manual for this TV the remote control has an input button, it is left of the power button. Make sure that the remote mode slected for TV not VCR or DVD and press input button to make a selction, make sure that the power to the DVD player is on. If yours is different try stepping through the channels buttons, some TVs input is selected through the channel buttons.
Jan 02, 2010 | Sanyo DS27930 27" TV
Try to clean contact with contact cleaner spray( radio schack or computer sotre.
If the problem persist Reset with you code in your manual if you do not have the code go to: and download free.
After that if the probllem remain, your contact in the remote control is faulty.
Replace it.
Good luck, G-d bless you
Ernesto Cuadra
managua,nicaragua. c.a.
Nov 17, 2009 | Sony RMT-D166P Remote Control
Need control code, to operate dvd samsung
Yes. I found the code. To operate Samsung HT-Z 310 with a remote control of Samsung TV, You have to turn off DvD, and then select Dvd on the remote(press the dvd button), press SET on YOU
remote control, input the CODE(020). For different Samsung dvd. you can from 000-to 080. The DVD button must blep three times. After that swich on Dvd. Enjoy....
May 04, 2009 | Samsung TV Remote Control
Tv turning back on when turned off.
Thanks for helping me understand this problem. I've placed new batteries in the RC but, that don't help. It's the RC that came with the TV when I purchased it new.
Aug 12, 2008 | Televison & Video
Volume buttons of Sony Remote control is not working for Akai TV.
Volume buttons on Sony remote will work on Sony TV only.
Aug 04, 2008 | Sony RM-V310 Remote Control
Locked dvd
1. Press the Menu button on your remote control 2. Press the 5 button on your remote control
3. Press the 7 button on your remote control
4. Press the 5 button on your remote control
5. Press the 3 button on your remote control
6. Press the 8 button on your remote control
7. The currently selected region will be indicated on the TV.
8. Press the 1 button on your remote control for region 1, the 2 button for region 2, and so on, or the 9 button for multi-region playback
9. Press the Menu button on your remote control
10. Press the Menu button on your remote control
Tested with Region 1 DVD's on my UK player (Region 2 bought from Comet)
Mar 02, 2008 | Panasonic PV-DF2703 Triple Play 27 in....
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
