Question about Whirlpool Dryers
Duet dryer ggw9200lwo E1 code - Whirlpool Dryers
5 Suggested Answers
Master_Tech
  • 770 Answers
SOURCE: Whirlpool Duet dryer error code
E1=Thermistor open
post your email and i will send you the steps to fix and check it too much to type here
Posted on Aug 05, 2008
jonniewalker
  • 1029 Answers
SOURCE: whirlpool duet dryer shuts off
E1 is an open thermistor. The thermistor lives on top of the blower housing. Get to it by removing the bottom quarter panel.Does the E1 error represent failure of the thermistor,
The quarter panel is right there in front, down at the bottom, below the door. Look closely and you'll see two screws. Remove them and the panel comes right off. Some pics at this link:
http://fixitnow.com/2005/03/appliance-repair-revelation-peek.htm
hope this helps.thanks and Godbless .appreciate by rating as fixyaa
Posted on Oct 17, 2008
  • 21 Answers
SOURCE: My whirlpool gas dryer keeps coming up with E1
e 1 code means thermistor bad [black color]
Posted on Aug 01, 2009
localwonder
  • 6784 Answers
SOURCE: whirlpool duet dryer error code e1
HI, the Thermistor has failed. replace it asap. this will fix your issue.
Jahn27
  • 1554 Answers
SOURCE: E1 whirlpool duet electronic gas dryer error keeps
The fault code means the electronic control detected the thermistor is open. It's either the wire harness connecting the thermistor and electronic control is broken or the connection is loose or the thermistor is indeed open. Measure the resistance of the thermistor then refer to the temperature and resistance table below for the normal thermistor resistance values. Replace the thermistor if the measured resistance is not in the table.
Check the continuity of the wire harness if the thermistor resistance is good and make sure the connectors are fully inserted. Replace the harness if it is broken (no continuity). The problem lies in the electronic control board if no issue is found in the harness and the connections.
The thermistor is located on the blower housing and can be accessed through the toe panel. Shut off the gas supply and disconnect electrical power to the dryer. Remove the two hex-head screws from the bottom flange of the toe panel then pull the panel down and off the cabinet.
Remove the hex-head screw from the lint duct bracket and remove the bracket. Remove the two hex-head screws from the lint duct and remove the duct.
Remove the wires from the terminals of the thermistor when measuring its resistance. Remove the two-hex-head screws securing it to the blower housing when replacing it and install the new one. Reassemble in reverse order of the disassembly steps.
Posted on Aug 11, 2010
Error code E1 what does it mean
The problem is an open thermistor as what error code E1 means. It's either the thermistor is exhibits an extremely high resistance or the wire harness connecting it to the control board is broken or cut open. Click on the link below for the detailed procedure in troubleshooting this error code.
Troubleshooting Error Code E1 on Whirlpool Duet and Kenmore Elite Dryers
Aug 27, 2011 | Kenmore 62602 Electric Dryer
The dryer shuts off, keep getting an E1 code, what needs to be done
It sounds like this is a Whirlpool Duet or a Kenmore Elite Dryer due to the error code E1 being available only on this models. The problem here is an open thermistor as what error code E1 means. It's either the thermistor is exhibits an extremely high resistance or the wire harness connecting it to the control board is broken or cut open. Click on the link below for the detailed procedure in accessing the thermistor.
Whirlpool Duet and Kenmore Elite Electric Dryers Not Starting
Measure the resistance of the thermistor and refer the table below. Normal thermistor resistance is around 10000 ohms (10K) at room temperature.
Replace the thermistor if the resistance is significantly higher (or lower) than what it is supposed to be based on the resistance table above. Check the wire harness connecting it to the control board, if the resistance turns out good, and make sure the connectors are good and the wires are intact. Replace the wire harness if necessary. Consider replacing the control board if both the thermistor and the wire harness turn out good. The link below might enlighten you further on the troubleshooting of the thermistor.
Thermistor Troubleshooting on Whirlpool Duet and Kenmore Elite Dryers
Aug 21, 2011 | Dryers
Kenmore ht3 dryer, the dryer runs for about a min. then shuts off. the code E1 comes up. i have clean the vent out from within the the dryer. is their a sensor that shuts it off or what.
The error code E1 indicates that the thermistors is open or having a very high resistance. Click on the link below for the detailed troubleshooting of the thermistor.
Whirlpool Duet and Kenmore Elite Dryers Thermistor Troubleshooting
Jul 19, 2011 | Dryers
I get an E1 code on a whirlpool duet dryer. What could the problem be.
The problem is the control thermistor being detected open by the electronic control. It's either the wire harness connecting the thermistor and electronic control is broken or the connection is loose or the thermistor is indeed open. Measure the resistance of the thermistor then refer to the temperature and resistance table for the normal thermistor resistance values. Click on the link below for the detailed troubleshooting procedure.
Troubleshooting Error Code E1 on Kenmore Elite and Whirlpool Duet Dryers
Feb 04, 2011 | Whirlpool GEW9250 Electric Dryer
E1 error
The fault code E1 means the electronic control detected the thermistor is open. It's either the wire harness connecting the thermistor and electronic control is broken or the connection is loose or the thermistor is indeed open. Measure the resistance of the thermistor then refer to the temperature and resistance table for the normal thermistor resistance values. Click on the link below for the detailed troubleshooting procedure.
Dec 31, 2010 | Kenmore Elite HE3 Steam 8676 Dryer
A code E1 flashes the dryer shuts off and the clothes are still wet
Oct 25, 2010 | Kenmore HE5
Code E1
E1 or E2 Thermistor Failure
The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.
Take the top off the dryer and inside you'll find the "tech sheet." It has instructions for removing the front panel and locating the thermistor.
Apr 21, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Duet error code e1
Whirlpool Duet E1 Error
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 02, 2010 | Whirlpool GGW9200L Gas Dryer
My whirlpool gas dryer keeps coming up with E1 error code after drying for about 50 min, model ggw9200lwo. Any solutions to what the probelm might be?
The E1 code means there is an open thermistor. This thermistor is located on top of the blower housing. Access it by removing the bottom panel on the front of the dryer. This device is not repairable, so unless it's just a loose connection or the device is not firmly mounted, it will need to be replaced.
Unplug the dryer before you work on it!
Mar 28, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool Duet dryer error code E1 keeps coming on after a few minutes of running shuts down dryer.
E1=Thermistor open
Aug 05, 2008 | Dryers
Dryers Logo
259 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
