Question about HP Office Equipment & Supplies
I cant install my new hp office jet J6480 - HP Office Equipment & Supplies
I have vista and the printer works once in a while,but now not at all.
i have it set for wireless with another computer.
Posted on Mar 10, 2009
    Guru:
  • 1,049 Answers
If the standard install is failing follow these steps.
Unplug, uninstall, and remove anything related to your printer install. Delete the printer added to the printer Windows in the control panel. We're starting fresh.
  • If you have Vista and let me know, you're going to have issues and I'll have to give you another set of instructions. Otherwise...
  1. Plug the printer into the wall and the printer cable into your computer. The cable can only go in the right places so just pick a place plug it fits. (a USB port)
  2. Turn the printer on and make sure Windows can detect it. If it can not, you need to check your cable/hardware again.
  3. Cancel the Windows Hardware setup wizard and either run the setup from the CD that came with your printer or download it from HP' website linked here.
  4. Click next, OK, etc. and take the whole install at its default.
  5. Restart the computer.
  6. Try printing, it should work.
A standard install is listed below...but you will need Acrobat reader to see it.
Here are step-by-step instructions with pictures.
Hope this helps.
Posted on Jul 30, 2008
HP OFFICE JET J6480 ALWAYS SPEWS OUT EXTRA BLANK PAGE AFTER PRINTING
Check if your document has empty lines at the end. Use your keyboard down arrow to scroll past the last line of text. Then backspace until you get to the last line.
Mar 09, 2016 | HP OfficeJet Office Equipment & Supplies
My HP OfficeJet J6480 All-in-One is leaving black vertical streaks on each side of the page when using the document feeder. Does not leave streaks when using the flatbed scanner. How do I correct
Hi
Just remove the ink cartridge. Clean the print head by a soft cloth with rubbing alcohol to remove some sticky or ink residue. Then rub the printhead into a plain paper until ink flows. Then run the print nozzle for 2 times.
I hope it helps you. Regards
Apr 09, 2011 | HP J4680 Office Jet All-In-One Printer
Officejet J6480 won't scan. It indicates no
If you have the cd installer for your printer, try to install the driver for scanner... don't forget to disable first the connection of your printer from your computer when installing the driver...
If you don't know the location of the driver, try browsing first the cd installer..
May 26, 2010 | HP J4680 Office Jet All-In-One Printer
How do i get my hp officejet j6480 all in one to scan to my computer?
If you're already set up to print with J6480, you can use the drivers built into Windows XP or Vista.
For Windows XP
For Windows Vista
Sep 22, 2009 | HP J4680 Office Jet All-In-One Printer
I have a new HP printer Office Jet J6480 all-in-one. I've had it less than a week. I was doing a lot of printing and it began putting a vertical streak down the paper and then the display said it was low...
Check the rollers that move the paper. There is probably some ink on one if them. You can usually clean them with warm water. Just use a damp cloth and rotate the wheel slowly by hand while holding the cloth against the suspect roller.
Jul 02, 2009 | Office Equipment & Supplies
I lost my instructings,I need a new copy. hurry. rmfreeman2@verizon.net. 208 villanova avenue,circle, Swarthmore, PA 19081
I am in the process of installing anew hp j6480 all in one printer on my new hp pavillon computer. First problem their is no in struction manual. I picked up 60 pages at the store were i purchased the equipment.before their printer died. I need to get balance of instructions. Second proplem I cannot install Ink jet cartridges.They seem to jam on top of insert. Worked with same cartridges at the store and had no trouble installing them
Jun 29, 2009 | Digital Products Hewlett Packard OfficeJet...
Problem with hp deskjet 3920
If your printer connects to your PC with a USB cable, there is a specific sequence. Some setup programs want the USB cable connected after the driver is installed, others want it connected first. Try reinstalling the driver and pay close attention to the setup instructions.
Sep 12, 2017 | Office Equipment & Supplies
HP OFFICE JET PRO L7500/L7600/L7700
my hp office jet pro l7500 indicates the ink has expired in all cartages but the cartgages are new because they were just put in . Before the same error code came up and so bought new cartages. Also the door to the cartages will not stay closed without tape.
Nov 29, 2008 | HP Officejet Pro L7480 All-in-One...
Hp office jet j6480 all in one will not turn off.
remove the power cord directly from the back of the printer.and then wait for a minute.then reinsert the power cord.and check it should.turn ON/OFF properly.
Nov 07, 2008 | HP Office Equipment & Supplies
105 people viewed this question
Seeker5211
Seeker5211
