Question about Gateway 450ROG Notebook
Laptop screen very dark
Our laptop screen on our Gateway laptop just went very dark. We can still see the icons and everything but we are unable to brighten the screen to view it comfortably. We hooked up another monitor to it and it works fine. Any suggestions as to what this could be? We are hoping we can fix it ourselves. Thanks
  • nascor Dec 25, 2008
    screen is dark i can see things but it is harder to do whatever. i tried the arrows and it didnt work help
  • Anonymous Apr 28, 2009
    the screen on my laptop is very dim, anyone knows how to brighten it?
  • 458 Answers
The screen is not a sealed unit... and the backlight and the lcd bulb can both be changed out...
I do it on a daily basis....
It is way cheaper to change out the lcd bulb than it is to replace the lcd display panel... Way CHEAPER
the results are the same
Posted on Nov 19, 2008
    Genius:
  • 2,028 Answers
This is going to be either the screen back light or the screen inverter. If it's the back light, then the screen will need to be replaced, the screen is considered a sealed unit and the back light cannot be changed out. I would get the parts off Ebay. You will be able to get them at a better price from Ebay than a computer shop. Here's links to Ebay listings for the inverter and screen for your machine (assuming it's listed properly, 450ROG) The third link down is for basic instructions on screen replacement for Toshiba.
http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=+Gateway+450ROG+inverter&category0=
http://search.ebay.com/search/search.dll?sofocus=bs&sbrftog=1&dfsp=32&from=R40&satitle=Gateway+450ROG+screen&sacat=-1%26catref%3DC6&sargn=-1%26saslc%3D2&sadis=200&fpos=64804&sabfmts=1&saobfmts=insif&ftrt=1&ftrv=1&saprclo=&saprchi=&fsop=32%26fsoo%3D2
http://www.screentekinc.com/lcd-removal-instructions_en,toshiba.shtml
Posted on Jul 30, 2008
My laptop screen went very dark, I can barely make out whats on the screen but I know its working. What can I do to fix this situation on my gateway p-6860fx pc notebook?
Hi josue fernan...
You need to see if your laptop lcd screen is faulty and/or the lcd inverer is faulty.
1....Test the lcd screen:
Hook your laptop to an outside monitor and then start your laptop normally...if the picture on the external monitor is good, then your lcd screen is bad.
2....Backlight Faulty: If the monitor is still as dark like your lcd screen on the laptop then it could be the backlight that is faulty.
Please take time to rate me thumbs up
LCD Backlight and Screen Replacements:
http://www.laptopsman.info/0-Gateway-lcd-1.html
LCD Screen replacement:
http://www.screentekinc.com/Gateway_P-6860FX--17-inch--1440x900-wxgaplus-laptop-lcd-screen.shtml
Sep 11, 2011 | Gateway P-6860FX Notebook
My Gateway MT6707's screen makes everything negative.
It sounds like the 'High Contrast' Accesabiliy option in windows has been truned on. This is a setting that a person who has visual imparement might use to be able to see the screen and text better.
To turn this off :
  • Click Start->Control Panel
  • Double Click the 'Accessibility Options 'icon
  • Click on the 'display' tab
  • Remove the check mark from 'Use High Contrast'
  • Click OK
Your screen will return to it's not color/size settings.
Nov 18, 2009 | Gateway MT6707 Notebook PC
Gateway 450ROG screen went dark
Try using a can of compressed air and blowing out all the nooks and cranies. I did this and it worked for mine. Haven't had a problem since doing this. Let me know if you need more help.
Jun 19, 2009 | Gateway 450ROG Notebook
Lcd of my gateway laptop lost ligth inside so is to dark but i can see the destop icons but is to dark
Your Backlight bulb has burned out, or the Inverter for it.
1.General information on replacing a Backlight lamp,
(Bulb)
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
2.General information on replacing an Inverter,
http://www.laptoprepair101.com/laptop/category/replacing-screen-inverter/
May 28, 2009 | Computers & Internet
MY GATEWAY LAPTOP SCREEN WENT BLACK AFTER 20 MIN OR MORE
I'm betting that you need a new "Inverter" board, especially if it's a Gateway 450ROG.
There is an inverter that Gateway used in several models that has a known defect.
Inverters are relatively inexpensive ,and easy to replace. You could ven do it yourself if you have a little skill at disassembly / re-assembly. Tell me the model number of your laptop and I can help you more
Apr 10, 2009 | Gateway 40G / 40GB for laptops /...
Screen is dark
DID YOU TRY EXTERNAL MONITOR TO SEE IF IT IS A SCREEN ISSUE
ROD
Feb 09, 2009 | HP Pavilion zd8000 Notebook
LCD went dark
hook it up to another monitor then control panel then display see i8f something was changed in there
otherwise your screen may have gone but it's only two years old
what were you doing when you lost your screen
Jan 14, 2009 | Gateway MT6707 Notebook PC
Laptop screen illumination
The fault could be a faulty CCFL lamp or inverter.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Nov 03, 2008 | Gateway SL9550-30165318 Notebook
Look for cracks in the hinges. It is a big problem with the Gateway 7330GZ.
Sep 30, 2008 | Gateway 7330GZ Notebook
Problem with laptop screen
you reinstall your laptop........your OS
Feb 16, 2008 | Gateway MX8711 Notebook
Gateway 450ROG Notebook Logo
875 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
