Question about Toshiba 62HMX84 62" Rear Projection HDTV
62hm84 problem I got in the back and looked at the fan, it is running but it seems to surge and makes a nosie when it cuts off and on, is this still the power supply if so where is that?
  • dannyj526 Jul 30, 2008
    The fan is not cutting off but there is a noise coming from somewhere in the back of the tv.
    The sound is more of a reving sound as the tv tries to cut on.
    Guru:
  • 1,894 Answers
Yes. now you said the exact point.
if the fan keeps running and a sound comes and shuts the fan off.
this is the relay in the power board. and this relay trips down the supply.
check for the short circuits in power board and main board sir
Posted on Jul 30, 2008
  • dewan nafees ahmed Jul 30, 2008
    does it sound like TICK TICK or what?? can you just describe a\me about that?
Have sound no picture?
if the fan is cutting off and ON there is a problem with your power supply unit.
and this may also affect your other systems on the unit
Jul 30, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
Cleaned throttlebody and now idle surges when fan is on
Did you disconnect the battery to reset the PCM while you cleaned the TB?
Also make sure you reconnected the small vacuum line on the side of the air tube.
Feb 04, 2013 | 2004 Chevrolet TrailBlazer
Both fridg and freezer not cooling down. Diconected damper wich was continualy trying to close heard Evap. fan trying to kick on surge surge surge
well u answered ur own question if the evap fan isnt running then the compressor is overheated check the fan and make sure that the fridge isnt froze up unplug it for a few hours and plug it back in and see if it will cool for a while
Jan 22, 2011 | GE Refrigerators
My AT is "surging" and seems to be cycling between
Check all connections. Most likely, something is not firmly in place. Unplug the machine.
1) Make sure the plate is inserted into the grooves, top and bottom.
2) Make sure the contact "fingers" press firmly onto both sides of the plate.
3) Make sure the plug is inserted FIRMLY into the back (MOST COMMON PROBLEM).
4) Make sure the back screen is inserted firmly, and that the safety switch is depressed by it.
5) Make sure that the outlet is not on a line with heavy power users, like a furnace or refrigerator.
Jan 19, 2011 | Ecoquest Breeze AT Living Air Purifier
Hpa pavillion dv4-1220us has very high fan nosie and overheating problem
Make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
Sep 29, 2010 | HP NB199UA Pavilion Notebook
GE GSS25IFRF "surging"
The motherboard (part 801 on diagram) controls the speed of the fans and it may be going bad. The round type of condenser fan you have may be the cause of the weird sound.(part 730) Make sure it's clean. As long as it's cold you can run it just beware it may stop. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5241174&diagram_id=24104631#d24104631
May 11, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Microwave will not heat food
Dear Pam,
I am familiar with this problem...
It can be the drive belt for the microwave dispersing unit (fan), which is an quick, inexpensive repair... a burned wire, which is also a quick, inexpensive repair... or a chip on the circuit board that has blown, most likely due to a lightning strike or other power surge, not as quick and a little more expensive to repair...
My recommendation is to unplug the microwave, take the cover off after removing the cover screws with a screwdriver, and just be nosy... take a good look for something obvious like any of the above items...
Write back if I can be any further help...
Elex
Jan 11, 2009 | GE Microwave Ovens
Sound no picture?
I have no solution for this problem and I'm not sure I can fix it without taking it to a repair shop. The replies I got yesterday did not help.
Cooling fan
i would deff check the relay i had a problem with my relay going out on my 04 but i just ran my fan to a togle switch so i can turn it on and off when i want it on when im in dead stop situations like traffic and also when your ac is on the fan has to be on or your ac will cut on and off to keep your car from really over heating in a hurry if your not moving, but i also run my car at the track and it helps to keep it cooler when racing down the drag strip.
Jul 14, 2008 | 2002 Chevrolet Cavalier Coupe
Toshiba 62HMX84 62" Rear Projection HDTV Logo
152 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
