Question about Jenn-Air Microwave Ovens
Jennair m446 - no juice to transformer
I wired the primary inputs to a 60W bulb and powered the unit up for 5 seconds. No light. So no power to the primary. Where do I go from here?
Cheers.
Dave
  • Jenn-Air Master
  • 9,086 Answers
It's probably a bad door switch (or door switch mount) or a failed cook power relay or connection on the control panel.
We have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Posted on Aug 03, 2008
To William Miller
Hi Joe,
please undo the all thing you have done (remove bulb).........etc.
unplug ignition transformer's primary side from its connecting pin.one pin is enough.
then power on see what happening the bord must have power in this situation because it does not drive the magnitron this time .
if no result .something wrong with cct board.
please let us know the after checking to go next level.
regards,
nuwan.
Jan 09, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Model "KOT-152UW" The
well inside the unit check for any burn fuses on the power supply area, and into the control board. fuse basically the one will tripped if power surged occurred..
Jun 27, 2008 | Microwave Ovens
There's no high voltage ,thus no magnetron activity
check the ceramic fuse in the primary circuitry as it probably blew out when the primary connection arced and burned through
Mar 23, 2010 | Magic Chef MCD1110ST Microwave Oven
VMOC205SS quit heating, it runs but does not heat? What part do I need?
the heating components of a microwave r the diode, magnetron, and transformer. checking a unit plugged in can be dangerous seeing there is about 5000 volts from the step up transformer. if you have a amp probe you can check the amps at the wires powering the transformer. if you have less than 12 amps, and 110 volts at primary side of transformer change the magnetron and diode
May 18, 2009 | Viking VMOC205SS Microwave Oven
Panasonic 1250 Watt genius microwave- will not cook. message refer to operators manual before use. Have owned for several years, has run afew times after unplugging for a few minutes, then nothing. clock,...
 Confirm 110-120 volts AC is entering the primary coil on the high voltage transformer....meter works but can be fooled, I usually rig up a light socket and household light bulb and hook that to the 2 input wires for the transformer and see if the light works or not when you run the microwave....can even set a power level and watch the light go on and off. Discharge the capacitor first before attempting any checks or tests.
Scary but works!....
If ok, put those 2 wires back on the transformer. Discharge the capacitor .
Remove the 2 wires going to the magnetron....run the microwave a few seconds ( 2-3 ) and remove power....again discharge the high voltage capacitor . If you got a good crack&spark when you discharge the cap the second time you are creating high voltage but not using it ( bad magnetron or loose High Voltage wire somewhere )....if you get no crack&spark you are not creating high voltage.
How to check a common high voltage diode - click here. Check the diode with one end off/disconnected....should show continuity one way, reverse your meter leads and none the other way.....many meters are not high/good enough and often show no continuity ( infinity ) in both directions. A full continuity reading in both directions  (0 ohms) on the diode may be shorted/bad one!
Many  microwaves however have a defect in the microwave distribution system which causes the magnetron tube to overheat and cut out and/or damage the diode.
Jan 27, 2009 | Microwave Ovens
Kenwood CJ/AL28 microwave does not heat the food anymore...any reason why?
Check the high voltage fuse between the transformer and the capacitor, had the same problem with mineand this fixed it. Not an ordinary fuse though (5Kv 0.8a), cost me about a fiver.
Oct 16, 2008 | Microwave Ovens
THE MICROWAVE DOESN'T HEAT UP?
Is the unit under warranty? If not, you can try to remove the cover and see if there is a blown fuse in the section that powers the Magnetron. How old is the unit? Typically, no heating of food, indicates a bad Magnetron (tube).
Good Luck,
- Jim
Jan 24, 2008 | Hotpoint RVM1425 Microwave Oven
Microwave stopped working
Magnatron is suspect. Need to put a voltmeter on the input (primary) side to the high-voltage transformer (big heavy iron thing in there) Should be getting 120Vac when it goes to cook cycle. Don't touch the other (high voltage) side of this transformer. If the power is there, you are looking at replacing the magnatron. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Jan 01, 2008 | Microwave Ovens
No heat
Magnatron is suspect. Need to put a voltmeter and see if the input (primary) side to the high-voltage transformer (big heavy iron thing in there) is getting 120Vac. Don't touch the other (high voltage) side of this transformer. If the power is there, you are looking at replacing the magnatron. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Dec 28, 2007 | GE XL1800 1100 Watts Microwave Oven
Whirlpool MH6151XHT-1 - No Power - Stumped
First change all the fuse and check whether it works or not, if it does not work than as per your finding the secondary transformer could be the issue, the secondary transformer tap down the voltage fro 230-240/110 to required control board voltage. the best thing if the unit is opened then the right problem can be found but as per your description either fuses are faulty or the secondary transformer.
Dec 12, 2007 | Whirlpool MH1150XMQ Microwave Oven
Microwave Ovens Logo
43 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
