Question about Magic Chef MCD1311ST Microwave Oven
Mcd1311st 1100 smoking and arching
  • 3 more comments
  • bdoug Sep 09, 2008
    I have the MCD1311ST and it arcs behind the waveguide cover if the item in the oven is small. Placing a cup of water in the oven with the item usually stops the arcing, but my confidence in the unit safety is LOW. I am cleaning the cover and waveguide area as recommended. This unit is 4 years old and other than this recent arcing problem, I have been very happy with it.
  • bdoug Sep 21, 2008
    Follow-up - I examined the original waveguide cover and found a possible spot of something (maybe grease) on the inside where the arcing was occurring. The cover was slightly damaged at that location. After several calls, I finally got a number for the manufacturer, Daewoo, (877-393-7823) in NJ and they were very helpful. I purchased a new waveguide cover for $2.52 (unfortunately the shipping was $8.00), but still a lot less than buying a new oven! The arcing problem appears to be solved, but I still watch the unit carefully.
  • ksaad Nov 07, 2008
    WOW - I am so glad I found this website! Our microwave is having the same problem, and I can see that the waveguide cover is damaged, and there is a dusting of metal particles inside. I have now ordered a new waveguide cover, and will clean the microwave thoroughly, and hopefully that will solve the problem! I'll keep you posted.
  • Anonymous Jan 16, 2009
    MCD1311ST IS ARCING AND SMOKING. A FRIEND OF MINE CLEANED THE MICRO WITH WINDEX AND THE PROBLEM STARTED RIGHT AFTER THAT. IS IT SOMETHING THAT GOT WET AND WILL IT JUST REPAIR ITSELF OR IS SOMETHING RUINED. PLEASE HELP.
  • Anonymous Mar 31, 2014
    MCD1311ST
  • Magic Chef Master
  • 9,098 Answers
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
(In some models it is a larger stirrer cover type made of thicker plastic in the ceiling of the oven)
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
You can order Magic Chef / Ewave parts here.
Posted on Aug 03, 2008
Man that was right on the money fixed asap washed it dried it bam saved me from going out to buy a new one even suprised the wife hahahahahaa thank you all for the great advice
Posted on May 19, 2009
Electrical arching between top metal plate and shell?
i would imagine its a shield but iam not completely sure without a good look
Nov 20, 2011 | GE XL1800 1100 Watts Microwave Oven
Smoking and electrical smell
OOPS!
Sounds bad!
Remove the power plug & remove the lid!
Remember microwaves are deadly! Never touch! use your eyes only!
Put a 1/2 cup of water in & start. Look if you can see where the smoke comes from. If there is some arching somehhere, you may unplug it & leave it for 1/2 an hour to get rid of lethal high voltages. There may be carbon black at the arching site. You may clean it and if you see any paint damage, cover it with a piece of duck tape. Then try again.
If the smoke comes from the transformer, a square heavy iron box, dump the microvawe.
They are cheaper than the combined cost of the transformer & the labour!
Sep 04, 2011 | Danby DMW1146SS Microwave Oven
I need the Magnetron for model MCD1311ST
I would try www.mwoparts.com
Hope that helps.
Mar 02, 2011 | Magic Chef MCD1311ST Microwave Oven
My MCD1311ST Majic Chef Microwave has a paper that is made of some sort of reflective type material on the side of the right hand wall of the microwave. It is a part of the microwave. It has been causing...
I have not seen a microwave wall made up of such material but similar was commonly used as a roof to the earlier microwaves that employed a stirrer to deflect the microwave radiation in order to reduce hotspots in the food. Turntables were found to be effective enough so the stirrer has been largely consigned to history. Many microwaves so equipped often had the cardboard discarded without apparent ill effect.
The exit of the waveguide is often covered by a similar material but these are mostly only a few inches square...
These examples used a material transparent to microwaves and wasn't reflective in any way. That yours is reflective indicates it could be intended to bounce the microwave energy around in an attempt to reduce food hotspots. It should be available as a spare part if the oven isn't obsolete.
Sep 21, 2017 | Magic Chef MCD1311ST Microwave Oven
I just installed an over the range Magic Chef microwave and all controls seem to work properly however, it will not cook or heat anything. Am I correct in assuming the magnatron is faulty.
Sometimes there is a separate fuse for the magnatron circuit. Sometimes the fuse is the culprut, and sometimes it is the control board. Usually when magnatrons fail, they smoke or go bang or both.
I would look for a blown fuse first, and then look for a factory authorised service center.
Best of luck.
Jan 20, 2010 | Magic Chef MCD1311ST Microwave Oven
I need to replace a magnetron tube in my Magic Chef MCD1311ST 1100 Watts Microwave Oven do these tubes have diffrent power ratings do you no were I can find a cross-referance for this tube (DAEWOO RM259...
Try Ace Appliance who can cross reference most of these megatron tubes. Most of the time, its getting the access to the tube that will take up most of your time inside the microwave. Also, another good place to find these parts is Daewoo website.
Nov 08, 2009 | Magic Chef MCD1311ST Microwave Oven
Cana I download an instruction manual for the MCD1311ST?
Go to this link to get your user manual:
http://www.devicemanuals.com/guide/Microwave%20Oven/Magic%20Chef/Magic-Chef-Microwave-Oven-CT-MCD1311ST-Instruction-==TVRJek16UTU=.html
When you get there, scroll down and enter the validation code.
Then on the next page, scroll down and click on Download Now.
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 17, 2009 | Magic Chef MCD1311ST Microwave Oven
Started arching
This can be caused by grease in the oven especially on the paper like filter inside most of them. If it has burnt spots it may need to be replaced.
Aug 30, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Magic Chef MCD1311ST, no longer heats. Any suggestions?
Probably a bad magnetron tube. If you dont hear that tell tell buzz when it is running then that is a good indication of a bad mag tube.
Jul 29, 2009 | Magic Chef MCD1311ST Microwave Oven
Magic Chef MCD1311ST Microwave Oven Logo
393 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
