Question about NEC Dterm DTP 16D-1 Corded Phone
NEC Dterm 80 display
Recently taken job as assistant. Previous employee's name is on display for my office extension. No one knows where I am or what button to push to locate me. Help. I want to change her name ont he display to my name. How do I do that! Thanks.
  • 2 more comments
  • Anonymous Oct 16, 2008
    i have the same problem and that didnt work...any other suggestions?
  • firkin55 Oct 21, 2008
    I can't change a mailbox name, tried the 700 but that did not give me options to change name just record.
  • Anonymous Apr 02, 2009
    Can't figure out how to leave spaces neither
    cannot use the 700, the feature 1 # option = both give me "error" beeps
It took me forever to find out, but heres what you do.
with the phone hung up:
1) "Feature" then press "1"
2) then press "#", "*", "#"
3) lift the phone, then hang up
4) press "Speaker"
5) dial "700"
6) press "hold"
7) enter the name (I'm still trying to find out how to leave a space, or use aother character that the same number key has... ugh"
8) press "hold" then "Speaker"
then make sure it saves it in the directory
Posted on Mar 24, 2009
  • irene_pink00
    irene_pink00 Jun 15, 2012
    If you press # you can move to the next letter.
    If you press ## you create a space.
  • irene_pink00
    To leave a space, press ##.
    To use another chatacter that the same number key has, press # once.
  • 3 Answers
Try this:
With the handset on hook dial 700
dial your extension # and use the keypad to enter your name, just like a cell phone (you can space by using the pound key. Once the name is entered press "hold" to save and "speaker" to complete and save.
Posted on Aug 06, 2008
    New Friend:
If you're using the master phone you can put in anyone's remotely. Otherwise it should work just for your own as well.
-Speaker
-Dial 700
-Dial extension #
-Type in name in the same way you would text on an old phone. Use the # symbol if you need to enter another letter using the same key.
-Hold
-Speaker
Posted on Feb 05, 2013
    New Friend:
Dial 700 then put in the extension and add the name:) if there are two letters in a row that are on the same key, (examples: jiLL, shaNNON) just hit # and it will let you. If you need to put in a space for some reason hit ## (# twice). You're Welcome :)
Posted on Sep 29, 2015
    Problem Solver:
  • 4 Answers
Log into the system manager console via web browser and you can control and manage all the extensions / voice mails etc.
Posted on Nov 24, 2009
I had to have handset up no on hook. And I have a manual which does not give these details
Posted on Feb 03, 2009
    New Friend:
When I tried the above, I received an "ERROR" message.
If that's the case for you, you may need to follow these steps I finally figured out.
Press Feature, Hold, then dial # 0 *. If it shows "PROGRAM MODE" on your display, then these are the steps for you.
Press the 4th light up key along the top (one you normally push for a phone line). Will show "01/01:...". Type in 18. Will show "01/18:..." Should show the first name (usually the Admin's) and will flash at the first letter.
To delete the existing name press Hold. Then type in the name you want using the correct buttons. Push same button multiple times to change from 2-A-B-C etc. Will change from upper case to lower case. Cycle through to the correct one you want. To advance a letter (if using same button for two letters), press #, to go back a letter press *, to delete the current letter press Hold. Once the name is ready, push Transfer to save. Hope this saves someone else a lot of time and grief.
Posted on Oct 28, 2015
    Problem Solver:
  • 14 Answers
It all depends on what system you have. I believe the explanations are for an IPK 2. What if this person has the IPK 1. There is a totally different set of options on the IPK 1. Determine what type of system before asking the question.
Posted on Dec 02, 2009
How do i change the extension name on the display of NEC Dterm Series i?
Which NEC system is the Dterm Series i connected to? Normally you change the ext name in system programming, but I need to know which system it is.
Oct 14, 2016 | NEC Lands Phones
How to change name on nec dterm 80
You need to do this from the Admin phones, by default the lowest ext #'s on the system.
This is system programming not the phone itself.
Refer to the Attendant guide for the phone system model your phones run on.
Nov 01, 2012 | NEC Dterm 80 Phone Dth-8d-1 bk Tel 780571...
Our phone is a NEC DTerm 80, but looks a lot like ...
The Display can be swapped.... if you can find one.
Otherwise no programming is retained in the telephone. Swapping phones will not loose any data programed to that jack/Extension number
May 21, 2010 | NEC DTH-8D-1 Corded Phone
We need a cordless phone that can be used with our NEC Dterm 80 s
Thank - you but I have found a company from whom I can buy a NEC cordless phone. Have a good day.
Oct 05, 2009 | NEC Dterm DTP 16D-1 Corded Phone
I need to change my display name for my Dterm 80 phone. I also need to add a name and extension
you need to access program mode on the phones.
mb 4-18 is name assignment
new station is 4-10
ldtsnj.com
May 11, 2009 | NEC Dterm DTP 16D-1 Corded Phone
NEC Dterm 80
You will need a professional installer to do this for you.
Cross conecting and proper grounding required for any installations.
Mar 18, 2009 | NEC Dterm DTP 16D-1 Corded Phone
Changing a display name
hey do you know how to change the display names or better still do you know where i can get hold of a user manual for the DTU 16d nec phone thanks
Apr 01, 2008 | NEC Electra Elite 32D-1 Corded Phone
Change the Extension ID To New Employee Name
To change the names on the NEC Dterm 80.
Feature, Conf, #, 0, *, 8974, LINE 4, 18.
Select Conf to go to the name you want to change.
Select Hold to erase the characters.
Select Transfer to save it.
Once you save, make sure you go back to "18".
Mar 11, 2008 | NEC DTU 8D-2 Corded Phone
NEC Dterm DTP 16D-1 Corded Phone Logo
8,559 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
Oloyede Monsuru
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
