My drum of my washing machine fills with water when it is not in use. i have moved the outlet pipe many times but it keeps on doing it. should there be a cut off valve to stop the water returning?
  • 254 Answers
You probably have a bad water valve that the fill hoses attach too at the back of the washer, if the solenoid is stuck open the water won't stop unless you shut it off at the wall.
Posted on Jul 30, 2008
Water keeps filling even when not in use
hi Jeremy.
Why does my washing machine keep filling up with water when not in use? Ensure that the waste pipe of the washing machine is higher at one point than the drum of the machine, this will prevent water running back into the machine. Normally this would fill the machine with dirty water. Or it could be a faulty water inlet valve, which will fill the machine with clean water.22 Sep 2007
why is my washing machine filling up with water when off ...
forums.moneysavingexpert.com/showthread.php?t=558300 Search for: Why does my washing machine keep filling up with water when not in use?
if you want to read up more then go to this link.
Washing Machines keeps filling even when not in use Google Search
Nov 18, 2017 | Washing Machines
Haier xqg65-11su Keeps filling with water
I don\'t know this particular model but on many machines there is a diaphragm switch operated by a tube.As the water level rises in the machine the water also rises in the tube and the resulting pressure in the trapped air pushes on the diaphragm.If yours is like this look for a clear plastic tube running from the front or rear of the outer drum to a circular switch about 10cm diameter towards the top of the machine.If the pipe is blocked with soap powder or scum or the pipe has rubbed allowing the trapped air to escape the machine will continue to fill.If this is not the case by removing the pipe at the bottom and blowing into it you should hear the diaphragm click on and off as you release the pressure.Also check if the point where the pipe comes out of the drum is clear by pushing a piece of wire through the outlet.Don\'t forget the usual safety measures and unplug the machine before you start.
Jun 09, 2014 | Haier xqg65-11su washer dryer combo...
My clothes are sopping wet when the wash has finished and there is water at the bottom of the drum. I can sort it by taking clothes out, bailing out the water and then re-spinning the clothes twice to get...
Sounds like a blocked outlet pipe. It may be possible that a small item of clothing i.e. sock or baby item may be stuck between the drums and occasionally moves over the outlet from the drum causing the blockage, hence only happens once in a blue moon. To see if you can see if there is something between the drums use a flashlight to help you look through the holes in the inner drum to see if there's a stray sock or something that can be moving around between the drums and covering the outlet. If there is then you will have to remove the outlet pipe from the bottom of the drum to try and remove the item that is causing the blockage, check all the way around the drum as it may be stuck to the inner drum at the time. If no item is found between drums then the blockage may be in the outlet pipes (both sides of the pump) or in the pump. Check these also as it may even be a small button or coin creating a blockage if it is moving around.
Feb 25, 2010 | Hotpoint Aquarius WD63 Front Load...
We moved the washing machine , then issues popped up. connection?
Possibly the belt was a bit loose in the first place and the move helped it move a bit closer to the edge causing it to slip off when machine was run.
The second part may have come to light only when machine was moved but would have eventually reared itself. There may have been a sock or something stuck between the drums and the movement has caused it to shift to the outlet pipe of the outer drum. This has probably now caused a blockage to the outlet and now not letting all the water out of the machine on any emptying cycle which will cause it to still have some soapy water left inside and keeping clothes wet. Check for a blockage in the outlet pipes.
Feb 14, 2010 | Hotpoint First Edition FEW12 Front Load...
Drum is filling with water after each wash
There is only 2 possibilities for the drum to fill with water after it has finished.
Firstly, if the empty pipe is connected to the sink outlet pipe, the water can syphon back into the washer if the pipe is too low, thereby slowly filling the washer when not in use.
Solution is to lift the outlet pipe higher.than the bottom of the sink.
The other reason is the inlet valve is not shutting off properly.
To prove if this is the case, turn the water off at the valve, if it is hot and cold fill, then turn the hot off only, and wait and see if water comes in over a period of time, if it does not then you need to replace the hot valve.
If water stills comes in with hot turned off, then you need to replace the cold valve.
If cold fill only , turn off cold and wait to see if any water comes in, if it does not, then replace cold valve.
Plz rate my solution.
Thanks.
Jan 29, 2009 | Washing Machines
Hotpoint ultima washer dryer
ok lay the machine on its side the side with the soap draw under you will find the outlet pipe runing to the pump then another hose going from the pump to the bottom of the drum. if you disconnect the hose from the bottom of the drum you will find the filter remove this hose from the other end and clean the filter and hose with hot water once replaced check the hose in tight it may be tricky to replace stand up the machine and test using water only and an empty drum.
Nov 01, 2008 | Hotpoint Ultima WD72 Front Load...
Water will not shut off
Usually there is a thin pipe from the bottom of the drum to a pressure switch at the top of the machine. As the machine fills the water goes up the pipe from the drum and increases the air pressure in the pipe to a point where it's enough to switch the switch inside. If the pipe gets blocked with washing powder it will not switch off and the machine will keep filling. The pipe is connected to a sort of flat round box with a few wires on it. If you can take the top or back off the machine you should see it and be able to clean the pipe out yourself.
Jun 26, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washing Machine Hoover H100M fills too much water in the drum.
this is 1 of 2 solutions  2 this problem the first thing to check is the vacuum system or it is a split in the pressure switch hose
Mar 05, 2008 | Hoover AAA140 Front Load Washer
Ariston margherita wont drain and selector knob keeps turning
Plug off the wall first. The spin normally does not work when the outlet filter is clogged; be prepared for a flood of water. If the filter is clean you should then check your pipe coming out from under the tub. Last check your outlet pump, could be blocked with something. Refit carefully, you might need a nice pair of pliers to get the grip clip on and off the pipes.
You can also drain water from the tub thru the rear hose in the wall. Keep bucket handy. The outlet pipe into the wall stands at a particular height, refit exactly to this height, about 3 feet from ground. Do not push the pipe too much down the stand pipe.
Nov 29, 2007 | Ariston Technologies AWD120 13 lb. Washer...
Washing Machines Logo
Top Washing Machines Experts
