Question about Saeco Primea Cappuccino Touch Plus Coffee Maker
Saeco Touch plus
Hello!
Is you machine running perfect now?
I might have something for you.
Just let me know. Im from Sweden so please dont be to advanced. ;)
Please talk like you should do to a 5 year old.
  • 3 more comments
  • 0505 Jul 31, 2008
    Hello!
    I was trying to use 110celsius in cup temperature, only thing that happend, it came out boiling water no luck. But i have set cup temp to 93 celsius now. My std setting were 87. It looks like you have a little low value. You said you have set "coffee Temp" to 83 degrees. Did you mean "Normal Cup temperature"?
    Have you found that menu?
  • 0505 Jul 31, 2008
    Another tip for you, if you take out the brew group and look at it you will find a metal filter on it whit a X screw in the center of it.
    You need i very short screw driver to reach it. Remove that filter and clean it carefully. Put the filter against a light source you must see thru all these small holes. You might need a needle to get rid of all dirt. It will not fall out any small parts when you remove that filter. Easy fix!
  • 0505 Jul 31, 2008
    Im running the following settings.
    Activated temp in heater unit 140 Celsius
    Deactivated temp in heater unit 115 C
    Activated temp in steam unit 145 C
    Deactivated temp in steam unit 130 C
    Impulses with aroma 110 (with todays coffie beans) it will diff depending on bean type.
    Coffie cup tem 93 C
    I think the machine will mix hot water and milk to do a perfect milk foam. With this settings a black coffie i SUPER HOT!!
  • 0505 Aug 02, 2008
  • brunomana Dec 06, 2008
    Hello, I have the same problem, but I can't find the "Milk temp" in the service menu, can you help me ?
    Thanks.
    Bruno
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 5 Answers
Hi There,
First I would like to say a very big THANK YOU.
For taking time to post a solution, thank you so much.
I can enter both service menu!
I change the "Milk Steam Temp." to 150 degrees, and "coffee Temp" to 83 degrees.
All appears to be working fine now and I am very happy !!!
Thank you again for all you help. Your English is great too :-)
Posted on Jul 31, 2008
  • peeablo2000 Jul 31, 2008
    I just did a few tests and the coffee is still only warm - not hot.
    I'm a little worried about putting the Temperature higher.
    Any other suggestions?
    Also do you know if the type of coffee bean affects the machine?
    I had some beans that seemed to block the coffee coming out and I had to constantly run the "Clean Coffee Cycle" almost after every cup.
    Thanks in advance.
    PS
    If you ever need any IT help let me know
    Thanks
    Paul
    I've now changed all the settings the same as yours.
    The Milk Temp. maximum setting is 150 degrees.
    I set the Coffee Cup to 93 degrees.
    Now even my first Latte is hot and I don't need micowave.
    THANK YOU 0505.
    Please if you have any more TIPS let me know.
    I owe you.
    Paul
Hi, I have a Saeco Primea Touch Plus, in the display it says error 5. What ca I do? Regards, staffan
I had that error too, the very first day after i received my Saeco Primea Cappuccino Touch Plus from Germany. The curiosity is that the machine was able to prepare a cuple of cups and suddently died with 5 in screen. Going to the service, they said that error 5 is about a lack of pression in pipes, probably due to the unprotected transport to Romania. I don't know if they fixed alsi some jonctions, but i had to pay for few rings. Everything took a day in service, but now is working fine. Hope it was usefull and my english enough inteligible.
Apr 17, 2011 | Saeco Primea Cappuccino Touch Plus Coffee...
Coffee and milk is luke warm when i make something
If you set proper menu position to "high temp", then i think one of the the boiler heater coils must be broken.
Apr 08, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Water not running through the machine!
sounds like air got in the water lines. Try turning off the machine and making sure the tank is seated good. at menu try an get hot water to get the pump flowing again. you may hear a loud "eh-eh-eh" buzz which means air is in the pump. It will quiet down as the air is forced out. try it several times. Hopefully you get it working. Just remember not to run the tank completely dry.
Apr 03, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Primea ring hot milk
Remember that the milk temp should be around 60-70c. Milk will start to boil around 80c.
You´re welcome and good luck!
Jan 11, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Cappuccino brewing very slowly
Try to descale the machine.
Try to adjust the grinder little.
/Mirran
Aug 21, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Cappuccino Touch Plus Coffee Maker fill water tank
The Primea do not have a float, it have a magnet and inside the machine there are a printed circuit card, this send a signal to the powerboard.
Jun 20, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Ring - no milk - just steam
Hello!!
Okay! Looks like many of you out there has the same problem, whit the milk temerature (not me i never had).
But there is a service menu on primea touch plus series.
Im from Sweden but i will try my best to explain how to enter the menu. First of all !!MUST!! write down off parameters before changing any thing!!!! It is possible to set the grinder to grin more coffie for each cup. I think the factory setting is 85 Aroma impulse. It is possible to change that for you type of coffie beans that you use, i will diff from bean to bean.
Okay, to enter the menus you have to turn you machines off.
Now turn it on !!!!!EXACTLY!!!!! when the display lights up press your display in the following order ALWAYS IN THE CORNERS (you will not see any icons were you have to touch on you display) RIGHT LOWER CORNER, LEFT UPPER CORNER, RIGHT UPPER CORNER, LEFT LOWER CORNER.
To enter the second service menu, do as i explained before but use this "CODE" instead. LEFT UPPER CORNER, RIGHT UPPER CORNER, LEFT LOWER CORNER, RIGHT LOWER CORNER. This is it! Hope i could help you! Remeber to write down before doing any changes! DO NOT ERASE ANY FAULT CODES YOU SERVICE CENTER WILL FIND THAT INFORMATION VERY IMPORTANT!!!!!
Dont say that it didnt work, it will it´s a huge matter of timing!!!! IT WILL WORK!!!!
Let me know some results please!!
Apr 30, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Primea ring - milk not hot
Hello!!
Mar 04, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Cappuccino Touch Plus Coffee Maker Logo
424 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
