I hav a WPN824 RangeMax NetGear router connected up. Service comes in from ATT DLS into this Router then goes to another router in another NetGear Router. The second router has no problems. The WPN works great until you power down and come in the next morning and you get an IP address but con not access the internet. I have to unplug an replug the router back in the get out to surf. This just started happening since I changed over from a T1 connection to this ATT and upgraded the Netgears Firmware. Someone tried telling me a 2.4G hz phone can cause this prob, just don't see how given what happens above.
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up. b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator. b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key. c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds. b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a DSL connection that does not require a login, please follow the steps below:
a. Click on Basic Settings under Setup tab. b. Select No for Does Your Internet Connection Require A Login?. c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection that requires a login, please follow the steps below:
a. Click on Basic Settings. b. Select Yes for Does Your Internet Connection Require A Login?. c. Select Other on the Internet Service Provider drop down box. d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup. b. Change the SSID to any unique name. c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy). d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit". e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes. g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers. b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking. c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer. b. Then click on View Available Wireless Networks. c. Click on the Advanced tab. d. Please delete all the preferred networks then click on OK. e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key. f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router. g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer. b. Then click on View Available Wireless Networks. c. Click on the Change Advanced Settings. d. Click on the Wireless Networks tab remove all the preferred networks then click on OK. e. Right click on the Wireless icon then click on View Available Wireless Networks. f. Select your network and click on Connect. g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To. b. Connect to a network window will show up. c. Select your wireless network and click Connect. d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
And then open the netgear admin UI using www.routerlogin.com
Username - admin , Password - password
-- Click on router upgrade ..
-- Browse this download and upload it...
But after the firmware upgrade u have to resett And reconfigure the product,...
In case of further help u can contact me....
Was this helpful?
Yes
No
Popular Solutions for Westell Wirespeed ProLine 6100
i recently upgraded my internet connection and when i tried to get on xbox live it said that i had...
(More)
i recently upgraded my internet connection and when i tried to get on xbox live it said that i had to have atleast 1364 ntu or higher i cant find how to change it
I recently re-formatted and re-installed windows on my pc. I have verizon dsl for my isp. The...
(More)
I recently re-formatted and re-installed windows on my pc. I have verizon dsl for my isp. The modem is a Westell 6100. The modem had to be reset. I called the isp and talked to a tech to get everything re-activated. I used a usb to lan converter to do what I had to do for the re-installation and the downloading of the modem software. and then hooked usb back up and it worked fine. I shut my computer down and the next day all of the sudden I have no internet connection. The usb light is no longer solid and I dont know what to do to stay connection to the internet without using the usb to lan converter. I thinking that it is something in the network connection settings that I have to tamper with but not real familiar with dsl modem connections. PLEASE HELP! PS. Not sure if it's a proline or litline-
i purchased a westel 6100 router from verizon. all connections are ok, and i am getting the green...
(More)
i purchased a westel 6100 router from verizon. all connections are ok, and i am getting the green lights. my operating system is windows vista, and in no way it allows me to connect to the internet. my computer is a sony vista VGN-NR180E. the verizon tech is telling me that the problem is vith the Sony computer and the Sony tech is telling me that the problem is with Verizon. what shoul i do?
