Question about Mitsubishi CS-40503 TV
Mitsubishi CS 40503
Horizantal line picture only. About 6 inches in width. The rest of the picture is blank. Service guy says parts not available. I've been waiting for 6 weeks. Is this problem repairable, and/or is my current service guy "out to lunch"?
  • jw62 Jul 31, 2008
    Could you identify what parts may be required. Are they available on line?
  • jw62 Aug 01, 2008
    Brigadier General:
  • 3,614 Answers
It is repairable and can be fix,,
Posted on Jul 31, 2008
  • micromaster
    micromaster Aug 01, 2008
    Replace all electrolytic capacitors in the vertical section along with the vertical output IC & the low ohms fuseable resistor connected to the vcc of vert o/p IC leading back to the flyback, That will allow the TV to operate normally.
  • micromaster
Remove parental lock on a mitsubishi CS-40503
model# cs-40503 default parental code is 6629
Nov 16, 2009 | Mitsubishi CS-40503 TV
Mitsubishi 40" tv
i would like to know the model# of the tv..
thanks
Jul 29, 2008 | Mitsubishi CS-40503 TV
Mitsubishi CS-40503 TV previously had discoloration in the corners and lines at the top of the screen. Now I have no picture at all. Is it worth trying to fix?
no picture?do you see a white horizontal line in the mid?or black out?
its up to you if its really worth fixing. if its really old then ,i think its time to buy a new one, if not try comparing the cost.
May 18, 2009 | Mitsubishi CS-40503 TV
Mitsubishi CS-40503 Zapped by high voltage
the only option is to bring your x-former as sample or take a pic of it and post it.
Mar 26, 2009 | Mitsubishi CS-40503 TV
Narrow blue horizontal line across screen on intial power up
You have trouble with the vertical deflection circuitry. Probably something in the driver circuit or power supply to the driver. Maybe even a cold solder joint since it comes up after a little warmup.
Jan 17, 2009 | Mitsubishi CS-40503 TV
Mitsubishi CS-40503 shuts off while watching.
Could be any number of things, none of them easy to diagnose. Unless your a TV repairman it's probably not worth fixing. It will cost tou more in repairs than a new TV.
Sep 28, 2008 | Mitsubishi CS-40503 TV
Mitsubishi CS-40503 Horizontal Picture Problems
Your trouble is with the vertical deflection circuitry. You'll need to have it serviced by a professional.
Sep 13, 2008 | Mitsubishi CS-40503 TV
FORGOT PASSCODE ON TV PARENTAL LOCKOUT
that's a big problem. sometimes using the 0000 can unlock it but it's not 100 percent.try the trial and error.
Apr 19, 2008 | Mitsubishi CS-40503 TV
Entirely black screen Mitsubishi Model CS40503 SER. 530082
  1. YOU WILL NEED TO CHANGE
  2. Q6c2
  3. Q291
  4. D251
  5. CHECK MOUNTING OF PIP-PCB TO MAIN-PCB
Nov 25, 2007 | Mitsubishi CS-40503 TV
Weight
I have one of these TVs and still love it.  The manual says that the weight is listed at 250lbs (approx.).  Most of the TV stands in retail stores only hold up to 240lbs., so that is something to consider.
Sep 23, 2007 | Mitsubishi CS-40503 TV
Televison & Video Logo
181 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
