Question about Toshiba 62HMX84 62" Rear Projection HDTV
Have sound no picture?
I have replaced the lamp unit and the ballast unit and I still have no picture. Tha red light on the front stays on and the green blinks rapidly and it goes into cutting off and on 8 times and after that both red and green lights blink. I don't think the lamp is coming on, I know the fan is cutting off and on. It also makes a nosie when cutting off and on. Help!
dannyj@charter.net
    Guru:
  • 1,894 Answers
If the fan is cutting off and ON there is a problem with your power supply unit.
and this may also affect your other systems on the unit
Posted on Jul 30, 2008
The tv made poping sound & it lost the picture but the sound was ok, their is buzzing sound coming from inside the tv, after about a min. the set turn off & red light stays on. reset tv, same...
This model is prone to a lot of problems to the point where a year or so ago they offered a chassis replacement on an exchange basis.
I would with rear cover removed try to localize first where the sound or buzz is coming from: The ballast? the Light engine? The power supply?
I can help but as I said this model has a LOT of chronic problems.
Steve
Nov 01, 2011 | Mitsubishi WD-52525 52" Rear Projection...
I was watching tv and i heard a loud pop.then my picture went out but i had sound.red light in the front comes on model number is 50pl9126d/37
If it is a lamp led light in the front panel, this is an indication that the lamp is not working. Pop sound was came from the electrolytic capacitor most probably in the ballast board that's why the lamp is dead. When the ballast board gone to malfunction, no high voltage will feed to the lamp resulting to that kind of symptoms.
Faulty capacitor has a physical indication of fault like bulged/dome at the top. Check the ballast board and inspect the capacitor. If you found it faulty, I would advice you to replaced the entire ballast board if you can't troubleshoot it yourself. Click this LINK for the replacement.
Also, check if your unit is still under warranty/extended warranty period, avail it because the manufacturer will fix it for free. Opening the back cover will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jdvillanueva
Jun 22, 2011 | Philips 50PL9126D/37B 50" DLP TV
I have a Sony Grand Wega KDF-55XS955 and replaced the buld in December of 2009. I turned the TV one the other day and after about 60 seconds, the lamp light flashs red. There's no sequence to the flashing,...
Yes,if "LAMP" LED light indication front bazel panel,flashes or stay on.The projection lamp life is over.Require changing a new projection lamp.But if u also hearing clickings sound too?The board call Ballast board also dead.This Ballast board help to ignite the projection lamp.If a power supply board problems,only power light LED indication will flashes.
Aug 04, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Lamp light on after i replaced the blown lamp Hitachi 60v500a
Was the tv working before you replaced the lamp? if it was then make shure you have reinstalled the new lamp and the door exactly as removed, there is a disconect switch on the door that has to close when the door is reinstalled,or sometimes the ballast may go bad at the same time.Hope tha t will help you fix it.
Mar 19, 2010 | Televison & Video
I turn tv on...green light comes on but i get no picture or audio....then light indicator blinks red
Hello!
Lamp or ballast(if lamp has been replaced) is bad.
Explanation: green comes on: system works, waiting for light to shine into light engine: no light is coming out of lamp, system shuts down, then you see red! how to determine: pull the lamp out of the unit's compartment. Inspect lamp: bloated stem? shuttered? reflector is not shiny? Chuck it!
Lamp looks good or just been replaced: try ballast. Close lamp compartment without lamp itself. Make sure, door is shut, as well. Turn unit on and listen close to lamp compartment: good ballast will make a buzzing noise, then stop. You've got "red'! No buzzing: ballast quit. Needs major repair! Lamp must be good, for sure, to get to the last part of diagnostics. Conclusion: more, than 2000 hours of usage: replace lamp first!
Good luck,
Alex.
Jul 29, 2009 | Panasonic PT-D5600U DLP Projector
Need verification of potential ballast issue and to be directed to step by step fix it directions
After lamp replacement, TV worked 4 days and now TV gives 3 blinks error. right?
If yes, please recheck lamp door / cover and fix it properly.
May 09, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sound no picture?
I have no solution for this problem and I'm not sure I can fix it without taking it to a repair shop. The replies I got yesterday did not help.
Jul 30, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
No Picture
its probably the ballast that is bad, call Optoma and you can buy a ballast for it, but you will probably want to have a pro do it, changing the ballast is a lot more involved than just changing the bulb, the ballast is what powers the bulb and it does go out on occasion.
Oct 28, 2007 | Optoma RD65 65" Rear Projection HDTV
Toshiba 62HMX84 62" Rear Projection HDTV Logo
96 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
