Question about OKI MICROLINE 8810 Matrix Printer
Oki 8810 dot matrix
Showing "error 103 power off" Alarm and auto gap lights are flashing. I have tried replacing the sensor assy AG (41592302), then the board MID assy (43508002). Still getting the error.
  • Fe Butterfly Jul 30, 2008
    new info. printer will print with no ribbon in it 10 out of 10 times. If I put the ribbon back in it fails immediately.
  • Anonymous Sep 26, 2008
    Showing "error 103 power off" Alarm and auto gap lights are flashing. Cannot access any menu functions.
SOURCE: OKI Pacemark 3410 Matrix Printer Error Writing to LPT1
A blinking alarm usually means an hardware error of some type, such as an obstruction on the printhead, or a bad motor or such.
When you have a blinking alarm light the other lights that are on will give you an error code that will tell you what the alarm means. You will need to look it up at Okidata.
Posted on Dec 10, 2007
  • 97 Answers
SOURCE: toner sensor error on an Oki C3520 Laser
Check the little switch/door on the right hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
0.10a?openelement&fieldelemformat=gif
Cause:
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Resolution:
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
0.106?openelement&fieldelemformat=gif
Posted on Dec 07, 2008
ohms
  • 1879 Answers
SOURCE: I have an OKI ML5590 dot matrix printer. what driver do I use?
get the driver here
http://www.okidata.com/mkt/html/nf/Drivers.html
Posted on Apr 14, 2009
SOURCE: Problem with OKI ML 395
the lid has 2 small points the holds down 2 censors that indicate when it is off, make sure that there are not broken and that the censors are being engaged.
Posted on Jul 22, 2009
  • 44 Answers
SOURCE: oki 320ml dot matrix printer pauses while printing
The printhead has some thermisters in and it is either actually overheating or a faulty thermister thinks it is overheating. Either way, a new printhead is required.
Posted on Jan 17, 2010
Machine stopped - alarm light flashing
just saw this yesterday. remove the top rear paper guide. on the left side between the tractor feed and the input slot for the paper, there is a sensor flag that pivots. check for paper scrap caught under the flag. it prevents the flag movement, causes a paper out alarm.
Jul 13, 2012 | OKI MicroLine 420 Matrix Printer
Oki microline 320 form feed
Am afraid the Power Surge (when the power came back on) has damaged the unit and there is no "Reset" to these printers. You would need to replace the control board but as its a power surge there is a reasonable chance that the power supply will have been damaged/weakened and this will lead to a shortened life span of the printer. I would throw it away and replace with new. sorry, ( I am not a salesman either)
Jul 18, 2017 | OKI MICROLINE 321 Turbo Matrix Printer
My oki microline 520 elite is showing alarm and the Character pitch of 15 is flashing
This is a checksum error. I would suggest replacing the main control board
Dec 09, 2010 | OKI MICROLINE 520 Matrix Printer
get the driver here
Apr 02, 2009 | OKI MICROLINE 590 Matrix Printer
Oki Microline 420 Network Card
As the alarm is on and steady then you most probably knocked the change lever into a position where it detects no paper loaded. The easiest way to check is to load your paper and move the change lever until the error lamp goes out!
Sep 08, 2017 | OKI MicroLine 420 Matrix Printer
Alarm light flashing
Is the front cover on the printer(ifs its not the alarm light will keep flashing as there is a sensor that will trigger the alarm if the cover is not on or not on properly.Hope this helps?
Dezzi
Jul 16, 2008 | OKI MICROLINE ML-395 Matrix Printer
T 2250
tally t 2250 give hardware alam
code +03211 ne -007000 000000 128+0304
Jan 19, 2008 | Tally T2250 Matrix Printer
Keeps saying "Auto Gap"
Does it Error auto gap, if so it means head gap is out of spec?
If it is just displaying Auto gap, it means it is set for auto gap rather that manual gap.
Jan 07, 2008 | OKI Pacemark 4410 Matrix Printer
Oki 520/521 logic boards
Check if the Pico fuse is blown ? next to the heat sink on the transisitor array with the number 2025.if the fuse is gone than the fuse plus the 2025 transistor must be replaced.
Dezzi
Nov 22, 2007 | OKI MICROLINE 520 Matrix Printer
Oki microline 520
It is likely that a few different things can cause this condition. First suggest looking for the paper present sensor. This is usually an optical sensor with a lever which contacts the paper. If the lever is broken, or sensor defective, an error condition is exhibited, and printer won't operate. There is also a sensor for printhead home position, and perhaps one or more sensors at one end of the platen assembly. Some printers sense whether a lever is set for tractor feed style paper, or for standard single sheet. A NEC p6200 has one, and probably other printers too. Check for the presence and proper operation of these. You might have to remove a cover to see them... As you probably know, dot matrix printers are practically dinosaurs these days. You should be able to pick up a decent Epson or other good model for practically nothing, if diagnosis on your rig is fruitless. Companies began getting rid of these critters years ago.
Jun 05, 2007 | OKI MICROLINE 520 Matrix Printer
OKI MICROLINE  8810 Matrix Printer Logo
113 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
