Question about Dell C600 (002UH) Motherboard
Power Connection The power into the laptop doesn't stay connected. I have to move the plug up/down until the LED comes on and then don't touch the laptop. Have tried 3 different power cords with same results. It is getting harder and harder to get the plug just right to get it charging the battery. Opened laptop and connections look good. Considering replacement of motherboard as an option. Ideas?
  • gleach Jul 30, 2008
    The pins don't seem to move much. Is the DC Jack a separate component from the motherboard that can be replaced?
    Producer:
    Uploaded 30 video answers.
    Filmmaker:
    Uploaded 5 video answers.
  • 72 Answers
The solution is to repair/replace the power pin assembly. Available on the web for $ 10-$20. Should only take you a couple of hours to disassemble, repair and reassemble the laptop. In the meantime you can get one of these to help hold the plug in the "right" position. Every laptop should come with one.
Posted on Mar 12, 2009
    Genius:
  • 2,028 Answers
Sounds like the DC jack on the computer has come loose or is broken. Use a small screwdriver and see if the jack on the computer has any movement to it. If it does, then the jack needs replaced. You should replace it ASAP, a loose or broken jack can create an electrical arch, which can do severe damage to the machine.
Posted on Jul 30, 2008
  • Ryan Rogers
    Ryan Rogers Jul 30, 2008
    The jack is soldiered onto the motherboard, but it is replaceable. There are three pins on the jack that are soldiered into holes on the board, heat up the soldier, remove the old jack, clear the holes, and soldier the new jack in place. That easy!!! I get replacement jacks from Ebay for $4 to $6.
The adapter stopped charging my laptop due to a faulty wire, I bought a new adapter and now as soon as I plug in it starts for a second and turns back off. The charging light blink and it doesn't
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Jan 28, 2013 | HP Compaq Presario C509NR Notebook
AC adapter power connection LED blinks but not charging
This suggests to me that you need to check out the AC adapter, and see if there is an intermittent short. In otherwords a break in the wires.
AC adapter unplugged from laptop, and power, remove the AC power cord from the body of the AC adapter.
Use a multimeter set to OHM's, (1K), and connect the Positive (Red) probe lead to one of the flat bladed prongs, in the power plug that plugs into the surge protector.
Touch the Negative (Black) probe lead to one of the holes in the plug, that goes into the AC adapter 'body'.
Keep going from hole to hole, until you get a reading.
Now have an assistant gently wiggle the power cable, and see if you get an intermittent reading.
Do the same for the other plug's flat bladed prong.
Intermittent reading means replace the power cable, or if more feasible, the entire AC adapter.
Power cable proves to be fine, move on.
Plug the power cable back into the AC adapter. Plug the AC adapter into power.
Using a multimeter set to DC Voltage, touch the Positive (Red) probe lead of the multimeter, to the center hole of the plug that goes into the laptop.
(If just a symbol, the DC Voltage symbol is a dotted line over a solid line)
The Negative (Black) probe lead, touches the outside cylindrical metal shell, of the plug.
Have an assistant gently wiggle the cable, and see if there is an intermittent reading on the multimeter.
(Reading should be 18.5 Volts DC)
[There are Analog multimeters which have a scale, and a needle, and Digital multimeters that just have a digital readout.
If using an Analog multimeter the needle will drop towards 0.
If using a Digital multimeter the readout will drop to smaller numbers, or 0 ]
AC adapter checks out? Go on.
The port on your laptop where the AC adapter plugs in, is the DC Power Jack.
AC adapter unplugged from laptop, Battery removed.
Take a pencil, and gently use the eraser end to see if you can wiggle, the center pin of the DC Power Jack.
ANY perceptible movement means a problem with the DC Power Jack.
The GOOD news is that the DC Power Jack, is NOT soldered directly to the motherboard.
It slides down in a Channel on the outside edge of the Base Enclosure, and has a wiring harness coming from it.
The end of the wiring harness has a plug, that plugs into the motherboard.
The HP part number for this DC Power Harness is HP 600630-001
A) http://www.dectrader.com/600630-001-New-HP-DC-input-power-socket-connector-With-cable.html#.UD0_w6B0k9Q
B) http://www.ebay.com/itm/HP-Compaq-600630-001-DC-Power-Input-Jack-Cable-CQ42-G42-Notebook-Series-/180932154005?_trksid=p4340.m1850&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D11%26meid%3D1653940420718665976%26pid%3D100011%26prg%3D1005%26rk%3D1%26
This is a link to a free Service Manual from HP Support,
http://h10032.www1.hp.com/ctg/Manual/c02627955.pdf
Page 73 is for the Power Connector Cable.
No damage to the DC Power Jack, and the harness is not slightly unplugged?
Now you have real problems.
You have a bad Power MOSFET,
A) MOSFET:
http://en.wikipedia.org/wiki/MOSFET
B) Power MOSFET:
http://en.wikipedia.org/wiki/Power_MOSFET
C) http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
However it doesn't take a rocket scientist to replace. (Sorry Gort)
These SMD's use a J-lead contact. Simple unsoldering, and soldering.
(Better be fast though as you don't want to overheat a power transistor. Better be good, because you don't want any cold solder joints)
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 28, 2012 | HP Computers & Internet
Hi I have a problem with my acer travelmate 5730. My laptop is always in plugged coz i use it,but lately when i move the laptop the sound of the dc connection is bipping all the time and i have to play...
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
May 24, 2011 | Acer TravelMate 5730-6204 Notebook
Will not hold charge, touch power cord on back or move it any way and the computer shuts off, the third light bar on front of computer keeps flashing between red and green
DC Power Jack is bad, or it's solder connections to the motherboard.
To explain;
The DC Power Jack is the port you plug your AC adapter into. (Charger)
Your DC power jack Not installed looks like this,
http://www.megaemarket.com/dc-power-jack-for-dell-inspiron-laptop-b12120130.html
(You can click on the photo to enlarge)
Looking at the jack in the photo, it is upside down in relation to how it actually sits, on the motherboard.
Those flat pins you see go down through the motherboard, and are soldered.
As I'm sure you know, your laptop uses DC electricity. (Direct Current. A flashlight battery, and your laptop battery are examples of stored DC electricity. The AC adapter converts AC electricity into DC for the laptop)
The round metal pin in the center is for Positive. It is the Positive connection. The outside round hole has the Negative connection. (For this jack I believe it is a flat strip of metal going down the side of the hole)
What you can't see is that the body, or outside shell of this DC Power Jack is composed of Plastic. Looking at the photo, look at the rear view of the jack. The view on the right of the photo.
That metal center pin is riveted to the flat pin. (Or Prong, if you wish)
Doesn't take too much of a bump, when the AC adapter plug is installed into the jack, to break the plastic at this point.
However your jack may not be broken. It could be cracked solder joints. Solder joints where those flat pins are soldered to the motherboard.
I apologize for being so lengthy, but unless you repair these babies, you may never know this information, and I thought I would share.
I wanted you to know what the problem is.
It is my belief without looking at this laptop, and based on many repairs, that your DC Power Jack has cracked solder joints.
Only a professional, competent, tech will know for sure when they go to repair it. If the above is the case they will re-solder the joints.
Repair cost? This cost varies from city to city, and country to country. I could only hazard a guess.
In my area it varies from $50 on up. (The cost of the jack online is about $9 should one be needed)
(The entire laptop needs to be disassembled down to the bare motherboard. {The LCD screen stays intact} Then work on the jack can ensue)
Nov 09, 2009 | Dell Inspiron B120 Notebook
Bad AC connection, how do I fix it myself? soder the connection?
The AC connection is at the mains wall socket. I presume you mean the DC plug that plugs into the laptop or the DC socket on the laptop.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Oct 28, 2009 | Dell Inspiron 6000 Notebook
My Inspiron 9400 started going off and all the lights would go off with the ac power cordYou could wiggle the cord which connects in the back a little and sometimes the green light would come on. The AC...
You could have a power adapter problem, the adapter usually quite warm to touch but not very hot.
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
Oct 08, 2009 | Dell Inspiron 9400 Notebook
My HP pavillion ZD8000 laptop will not operate on mains power. To recharge the battery the machine has to be upside down. There would appear to be a loose connection wher teh mains adapter plugs in to teh...
Check the power adapter with a multi-meter, the voltage of the power plug that plugs into the power socket on the laptop should be slight higher than the voltage that is printed on the label on the adapter.
If it is faulty, there are replacement power supplies available on the Internet or at your friendly computer shop.
If the adapter is OK then the power socket on the laptop is faulty or this socket has a dry solder joint connection on the motherboard.
You can test this by wriggling the power plug when it is connected to the laptop, if the charge LED flickers and if you hold this plug in a certain position the charge LED stays on without flickering, then the power socket is faulty.
This can be repaired, but requires the laptop to be completely
disassembled. I suggest you get a quote first.
Sep 10, 2009 | Computers & Internet
Screen Problems with my Laptop
hi dear
1. That can be connection related problem. I check connection between the video cable and the LCD screen, try reconnecting the video cable. It’s necessary to take apart the display panel, unplug the video cable from the connector on the back side of the LCD screen and then plug it back in. In some cases reseating this connection helps. 2. If reconnecting the video cable doesn’t help, here’s what I do in this case. While the display panel is still disassembled, I turn on the laptop and wait until image appears on the screen. Then I move the video cable a little bit without touching the LCD screen. If moving/touching the video cable affects image on the screen, it’s possible that there is a problem with the cable. Apparently there’s a short somewhere inside the cable. In this case, replacing the video cable may fix the problem.
3. If reconnection the cable doesn’t help and moving/touching the cable doesn’t change image at all and the only way to get better picture is moving/touching the LCD screen itself, apparently there is a problem with the LCD and it has to be replaced.
oke
Posted by Laptop Freak on March 22nd, 2008 Filed in Video Problems, LCD Screen Issues, LCD Displays Lines -->
Mar 24, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 1200 won't charge battery
dear N9YK
you can follow this
If you have a loose connection where you plug in the power on your laptop, or it works intermittently, you could have a bad dc jack. Symptoms
  • Move the power plug and the laptop loses connection
  • Broken or cracked dc jack
  • Laptop won't charge but worked on battery
  • Power LED and battery LED flicker when the adapter tip is moved
  • Battery won't charge
  • Sparks come out the back of the laptop
Why does this happen?
  • Flaw in manufacturer designs
  • Use of universal or non-original ac adapter
  • Lots of plugging and unplugging of the ac adapter
  • Tripping on or pulling the ac adapter cord
or you can check your dc amper in your adaptor
oke
thx
cropp
Mar 16, 2008 | Compaq Presario 1200 Notebook
Dell C600 (002UH) Motherboard Logo
161 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
