Question about Asrock K7VM2 Motherboard
Replaced CPU fan, now it won't boot up.
Well I have done this several times on PC's and never had this happen.
I changed out the CPU fan, PC case fan and CPU fan started when I powered up, but that's it. No video output and it doesn't appear to have any hard drive activity either.
Power supply feeds are all good, no loose cables, reseated CPU several times and the same with memory. There are no beeps when booting either.
I had another AMD Athalon in an unused PC, and that didn't help. So both CPU's work in my spare PC and so does the RAM.
Cleared CMOS according to manual, no help.
Any help would be appreciated.
Thanks,
David
  • dcmille290 Jul 31, 2008
    Thanks Styme, I figured as much. Just seemed kinda strange that it died by having a fan put in it. Oh well. I found another K7 board and I am going to try and do a swap without losing all my data on the hard drive..
    Any suggestions on the swap? The replacement board uses different North/Southbride, but that's the only difference I can see from the spec sheets.
    Thanks,
    David
Wish that was an option, I have not yet been able to find one.
It's an ASRock K7VM2 ver 3.0.
If anyone has one, I'd love to chat.
David
Posted on Aug 01, 2008
  • 84 Answers
No beep codes means the motherboard is dead .
sorry David for your loss
Posted on Jul 30, 2008
  • Styme
    Styme Aug 01, 2008
    If you want it all to work like nothing ever occured best thing I can suggest is to use same exact motherboard . Make sure you use artic silver between heatsink and CPU . A good thing also is to make sure the fan is as good or better then the fan you replaced ( more RPM is always a cooler idea )
Won't start but CPU fan vibrates but will not go full blast. Intermittant
It appears you have a faulty CPU fan and it is causing the CPU to overheat and shut down.
I suggest you replace the CPU fan. remove any dust from the heatsink and put new heatsink compound on the CPU/heatsink.
May 06, 2012 | Compaq Presario S5000NX PC Desktop
Toshiba satellite m645-s4114 keeps crashing i just got my laptop for the 3rd time from geek squad. and this time they told me that the toshiba replaced / fixed the fan. and then went home and turned on...
When the CPU in the computer or laptopoverheats then it will shut down (i.e. thermal overload) and won't boot upagain until it has cooled down. If this is the problem is not fixed then theCPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Feb 06, 2012 | Computers & Internet
My dell vostro 1015 gets completely shut down without giving any prior warning..i have to restart it again and it shows that windows didnot shut down properly.it happens 3 to 4 times a day.plz help..
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Dec 02, 2011 | Dell Vostro 1015 Laptop
Hello, I have Toshiba Satellite M200 window Vista, I have a new problem after working for 10-15 mins my laptop is getting hang nothing visible on screen just blurred screen , when i switch off and start...
Your Toshiba could be overheating.
When the CPU overheats then it will shutdown (i.e. thermal overload) and won't boot up again until it has cooled down.If this is the problem is not fixed then the CPU will eventually fail.
Jul 06, 2011 | Computers & Internet
My HP desk top shuts down during boot. I've
The CPU cooling fan usually sits on top of a heat sink which is held tightly agaist the core of the CPU by the clasps you refered to. It soumds to me like the CPU has oveheated and will only function for a few seconds. If it's a fairly new CPU, you may be able to buy one online at places like http://www.tigerdirect.com. If it's an older model, you will have to try & find one at places like E-bay.
If you install a replacement make sure the CPU fan/heatsink clamps the CPU flush against the heat sink (apply a thin coating termal paste to the top of the CPU core).
NOTE: If the plastic clamps attached to the motheboard which hold the fan clips are broken - forget it! A new CPU will just ovehat again.
If you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
Jun 24, 2011 | HP Computers & Internet
I put the computer in hibernate this morning now it won't boot up. I removed the power supply from the pc to test it. On the 24 pin connector all my voltages were good to the motherboard. I reconnected...
Good work. Reseated memory and all? Try booting with minimum attachments (old known good videocard, no floppy, even just one stick of memory) and/or resetting the BIOS in case a bad timing value was somehow programmed or a soft failure happened there. You can leave the HD detached if you tell the BIOS (once it's sensible) to boot a LiveCD (e.g. WattOS, Fedora 14, etc.) and thus be unworried about the hibernated state coming up with the system minimized as it is for service here.
It's rare to have to reseat the CPU. Less rare to need its fan plugged in to allow booting. It's a good time to flash the BIOS in case a new version is around, too.
Hopefully your newly optimized BIOS will let you come up with a faster machine and make up for your time and trouble.
Jan 05, 2011 | Gateway FX6800-01e PC Desktop
When pluged into outlet fans spins and doesnt stop, wont boot
Fan spinning hard is usually a CPU issue.
If you've made any hardware changes to your computer, undo them. This happened to me when I was trying to upgrade my Processor (CPU) and I had the wrong kind.
Mar 09, 2010 | HP Pavilion m7560n PC Desktop
Boots up but only runs for about a minute. Then fan runs at full speed constantly with no video. Also front panel popwer switch appears shorted. i.e as soon as you plug in the PC starts
Very well could be overheating or powersupply problem. Most Definately Hardware related. You can try opening up the case and blowing air into it from compressor. (Make sure to do this outside away from clean items). Also, check CPU fan and heatsink to make sure fairly clean. CPU fan may also be old and need to be replaced. Don't put case back on and try again. Look at CPU fan to see if moving (or struggling). If computer stays on longer then CPU fan most likely the problem. If off in same time as before then most likely the main power supply problem, in which case the only way to check this is to replace the power supply. Hope this helps, Best Regards,
Nov 09, 2009 | Acer Aspire T310 PC Desktop
DG31PR Won't Boot
you ight have a BAD CPU, try checking it out on another pc or friends pc.
Jan 08, 2009 | Intel DG31PR Motherboard
Friend has a Emachine T1862 that won't start
May be the CPU fan is going bad. I hope it is that simple.
Dec 14, 2008 | E-Machines Computers & Internet
Asrock K7VM2 Motherboard Logo
169 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
