My brother hl-5250dn printer is spitting out very wrinkled paper
  • Anonymous Mar 04, 2009
    I have same prob only when duplexing. No problem with roller. Still crinkles about every 12th duplex page
It could be the fuser unit. If you open the door on the back of the printer and pull open the paper path tray you will see an orange colored roller. If this roller is wrinkled even just a little it will wrinkle the paper. I purchased fuser roller units for my 5240 and 5250 printers and replaced them myself and that corrected the problem. I got the fuser units from ebay.
Posted on Mar 03, 2009
    Problem Solver:
Adjust the pressure lever for envelopes and the problem will be fixed.
Posted on May 07, 2009
I had the same problem. I switched to 24# paper and that has solved the problem. Originally, I was using 20# paper and everything was all right for the first 1000 sheets or so.
Posted on Apr 04, 2009
Samsung hl-s5087w.... Tv is 4.5 years old, and is about 200 hours into its 3rd bulb. Yesterday, very similar to when the bulbs burnt out, it shut off. I thought that it may be getting too hot, so after it...
Above the light is a temp sensor with a blue and white wire plug. This sensor is the problem for all these shut downs in my opinion. Pull out plug and jump it with a wire or paper clip bypassing sensor. Tv should work now!!!!
Apr 23, 2011 | Samsung HL-S5087W DLP TV
Samsung HL-P4663W/HL is making a buzzing noise
Color wheel needs replacement is the most likeliest cause.
Jan 02, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
Unable to clean
probably refers to a clogged print head. in the long run it would be cheaper to buy another unit instead of repairing old one.
Nov 12, 2009 | Televison & Video
Samsung printer/copier toner doesn't bond very well to paper. Toner is on the edges of the paper too.
It would seem that your fuser is faulty in the printer. Odd that the printer is not reporting a low temperature error maybe the Samsungs don't check the temperature.
Depending on the value of the printer it may not be a good idea to replace the fuser, it might be hard to find a replacement. If this printer is worth less than $200 new, I would say replace the printer, the fuser would likely cost more.
Oct 27, 2008 | Televison & Video
HP photosmart 7280 - when printing with Toshiba or HP notebooks (both Vista) a blank page is ejected between EACH printed page of a document. HP had no solution.
Assuming that you are connecting directly to the printer via USB, on the advanced tab under the printer properties, make sure the "Print Directly to the Printer" option is selected.
Aug 16, 2008 | Televison & Video
When I try to print on A4 paper the Canon printer pulls on the right side of the paper only and it jams. I can still print on the small sheets (A5?) or on my 4 x 6 photo paper.
Check to see if this will affect your guarantee and if so would probably not go ahead with it.
Protect yourself from shock by disconnecting the power cord from the back of the Canon printer.
Unhinge the back access panel of the printer. .
Look through the opened back panel and look for paper or any other object that should not be there. Remove any paper or obstacle you find jammed there.
Close the back access panel. Make sure that it latches back into place.
Find the front or top access panel. This is the panel you would lift to change ink cartridges. Open this access panel and look for paper or any other object that should not be there
. Remove any paper or object you find jammed here. If you find paper pull slowly or the paper will rip and create a major problem.
Close the front access panel. Make sure that it latches back in place.
Put the power back on..
Jul 14, 2008 | Televison & Video
Instruction Manual for Samsung HL-R5087w
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=02010300&prd_mdl_cd=&prd_mdl_name=HL-R5087W
Sep 09, 2007 | Samsung HL-R5087W 50" HDTV-Ready...
Televison & Video Logo
482 people viewed this question
Top Televison & Video Experts
Electro Med Services...
