Question about Toshiba Computers & Internet
Toshiba power saver fatal error 0xb7 - Toshiba Computers & Internet
  • nte2000 Jul 30, 2008
    toshiba power saver - fatal error 0xb7. How to fix this problem?
Okay I don't know if this will work for you, but bear with me, cause this is what I did and it fixed my fatal error.
First Download System Mechanic (theres a 30 day free trial you can use for the time being)
After it's done downloading and you've installed it. Do a deep Analysis of your system, and some errors will come up. Have the program fix them for you (if there are some you don't want to fix just hide them, and if your unsure about them, just go ahead and fix them). After this restart your computer whether or not the system mechanic asks. If after a restart it still gives you an error, download the latest version of the toshiba power saver which is currently 7.08.05. I have a toshiba U205 so there wasn't a specific one for mine, so I downloaded the Toshiba Satellite R20-ST4113 Power Saver Utility 7.08.05 Windows X.
Which still worked for my system since it's an XP. If yours is a vista, I recommending finding one for vista.
After this again restart your computer to see if it helped. I hope it helped with your problem. If not i'm sorry I couldn't give anymore advice.
Posted on Sep 16, 2008
Toshiba Power Saver. Fatal error Code 0x7E
uninstall Power Saver while in Safe Mode, reboot into Safe Mode again, and reinstalled Power Saver
Jul 05, 2012 | Toshiba Computers & Internet
I recently discovered that Anytime I start my Toshiba Saetelite A105-S3611 laptop/notebook with windows Xp SP2, there is a message: ?Toshiba Power Saver?, A fatal error has occurred, this program will be...
Download the hotkey utility from the toshiba web site. I got this errorafter installing service pack 2 for xp. The hotkey utility fixed it.error appeared every time I started windows xp. Go to:http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
and go to downloads, select model and download:
Toshiba Hotkey Utility
Install and restart, problem solved. thank you, thank you...
May 05, 2009 | Computers & Internet
When I opened my L30 satellite laptop the power saver not working
please do have a check with ur ram, there may also be the problem with motherboard or cpu also but lets start from ram
Jan 16, 2009 | Toshiba Satellite A135-S4527 Notebook
The brightness level
You need to use the Toshiba "Power Saver" console. Go to Control Panel -> TOSHIBA power saver. Click the Icon and use the console to adjust the brightness for the various power schemes. If you don't see the TOSHIBA power saver icon, go to Go to Control Panel ->Power Options and open that console. Select "TOSHIBA Power Saver" option in the "Power schemes" dialog box. If you don't have that option in the dialog box, you need to go to the Toshiba site and download the Power Saver installation file and reinstall it.
Jan 11, 2009 | Toshiba Satellite A45-S151 Notebook
Toshiba satellite pro a60 power problem
did u install already all the drivers for the A60???
then, update / flash the bios... http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1213736&rpn=PSA60U&modelFilter=A60-S1072&selCategory=3&selFamily=1073768663&selModel=1213736|PSA60U
Dec 30, 2008 | Toshiba Satellite A60 Notebook
Toshiba satellite m40 booting problem.
Hi! It appears that possibly your hrad drive isn't set properly in the caddy? with the laptop powered down and disconnected locate the hard drive cover pop out the two locating screws and carefully move the caddy/hard drive BEWARE as the drive has fragile pins at the opposite end where you opened, hopefully little sliding pressure should remove. Check the retaining screws around the caddy (You'll need a small torx/philips screw driver for this) if all tight replace gently.
If you are uncertain I would recommend a technician check it for you.
Good Luck!
Paul 'W'
Onyer~EDson(:0)~[><
Dec 09, 2008 | Toshiba Satellite M40-S417TD Notebook
Toshiba power saver fatal error code 0x57
try to reinstall your operating system..or restore the system..go to control panel and click the back up or restore files so that all the errors in your computer will fixed..even a fatal error..hopefully this will help your problem..
Aug 28, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba power saver keeps on saying that it has encountered a fatal error 0x2 even after i have reinstalled the common modules and power saver HELP I have an M500 portege
try the original laptop recovery cd for the power saver utility of ur specific model...this works best..
many people downloading TPS from the website have had no luck it seems
Apr 14, 2008 | Toshiba Computers & Internet
Toshiba Power Saver
It sounds like the built in powersaver utility is crashing. Assuming you can log into the OS after the error, go to Control Panel - Power Options and change to some other (or none at all) setting. And/or uninstall the application completely.
If you can not even get into windows you could try changing the power settings within to bios to disable power saving at all, and that might allow you to boot properly and then turn off/uninstall as described above.
Jan 16, 2008 | Computers & Internet
Power saver error 0x5
Dec 10, 2007 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
3,204 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
