Question about Jl Audio 500/1 Car Audio Amplifier
I have 2mb quart 15's 2ohm sub and a hifonics bxi1608d amp
I wanted to know the best way to wire this and if this is a good combo
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 108 Answers
The two 2ohm subwoofers can only be wired to a 2ohm or 8ohm load. You are gonna want them wired 2ohms on a monoblock amplifier. the other option is to wire each sub to 4 ohms (series) and then connect each one to a separate channel on a 2 channel (stereo) amplifier. go for an amplifier that produces up to the MB's RMS rating and make sure they are enclosed in a box to their specifications and they should pound.
Posted on Aug 03, 2008
My hifonics is on and u cant hear bass the red light is not on wat could it be?
Double check your wiring. Make sure all conections are correct. Does the unit have fuses? Check them, replacewith exactly what the unit calls for.
Apr 03, 2011 | Hifonics BXi1608D Car Amp
Why does the hifonics bxi1608d 1600 watt super D-class mono have 2 postive terminals and two negative terminals? would that cause my speakers to blow?
That is still a single channel cass D amp. Each (-) and each (+) terminal are connected so its actually like only having one. This is so you can hook speakers up in a series circuit to lower impedance, because this amp is 1ohm stable. What causes your speakers to blow is too much power. What kind of speakers are you running? This hifonics amp is very powerful, they are getting big in the competition industries beacuse they put our true power for less money and they are tough. That 1600 amp you have may be putting out more like 1800 watts at 14.4 volts which is 900 per sub at 1ohm so be careful this amp has tons of power and its true rated its not like a sony or rocksford or kenwood that says 1800 max and then in small writing it says 500 rms. This amp puts out true. I have 3 hifonics amps and love them.
May 07, 2010 | Hifonics BXi1608D Car Amp
How to conect a hifonic amp class d to four
+ too - & - too + & + too - & - too +& + too -
Apr 01, 2010 | Hifonics BXi1608D Car Amp
Amp draw, voltage dropping from 14.6 to under 12v
I would not use a bigger cap, I would use a bat cap. If u dont know about these look them up they work wonders
Feb 19, 2010 | Hifonics BXi1608D Car Amp
I hooked my Hifonics BXi 1610 Brutus series amplifier up to my 2 12" Kicker Solo Baric L7 subs. Everything turns on on the amp but its barely pushing my subs. Ive tried tuning it and it still doesn't push...
wire the subs if thair dual 4 ohm . in parallel. red to red and black to black. giving it a 2ohm load. do the other sub the same. and conect it on the amp . turn your gain about 12oclock and db level less than 12oclock and your frequnecy around 80-100. and that should work
Feb 18, 2010 | Hifonics BXi1608D Car Amp
Wiring options
Hello chino2g,
For 3 DVC 4 ohm subs wired to a 2 ohm stable amp, your best option would be to wire all of the sub voice coils in series (individual 8 ohm loads) and then parallel the three subs for a final load of 2.67 ohms. There's really no other configuration. Here's the wiring diagram:
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=3&woofer_imp=4
Hope this helps.
Sep 07, 2009 | Hifonics HFi HFI12D4 Car Subwoofer
Price check
that is 2 12 hitting 150 db you got to know what you are doing
Sep 14, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
3 amps 2 subs sound system for car, need wiring help
As i read your problem i can recommend you that connecting each of the hifonics amp to each hifonics sub with the same specs by getting the specs in interfacing the two or you can simply look to the output of the amp and the input of the sub and find a suitable plug that fits to them.
In the case if you want to run each hamp to individually run each sub but sharing 3 farad capacitor: what i can suggest is that you connect in parallel one connecting wire of each input or ouput of the amp or sub. Its like connecting a connector from each of the input or output of the amp or sub to one leg of the capacitor, and connecting two wires to the other leg, one is being connected to the amp or sub and the other wire is connected to the other amp or sub.
In the case of putting a circuit breaker at the car battery: what i can suggest is that you find an appropriate circuit breaker that fits the specs of the car battery then connect it in series on the positive supply or read the specs of the circuit breaker before you connect it to the battery. Having a circuit breaker is like having a fuse but with special advantages in favor of the circuit breaker.
In the case of having power to the amps you can run one power wire to the amps by dividing the power wire into two, one connected to the amp and the other wire to the other amp. Then you can connect each amp and sub in series individually by connecting one wire b/w amp and sub. I hope i solved your problem
Feb 08, 2008 | Car Audio & Video
Jl Audio 500/1 Car Audio Amplifier Logo
99 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
