Question about Dell OptiPlex GX520 PC Desktop
Curly one Power switch plays up The motherboard is a new one and inspects fine. Also replaced control panel (power switch ) and power supply. It starts after multiple presses of the switch sometimes up to thirty presses. I observe the power supply and processor cooling fan when trying to switch ON and they just spin for a second or 2 then stops, motherboard may be intermittently grounding to the case.How do i remedy this? Thanks in advance. power to the board but will not switch on
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 202 Answers
Hi
there is way to find out
First ,disconnect all power cable and data cable from hdd,fdd,and remove all pci devices.
Now you have to check your pc mother board not touch to your pc case.
Second, check heat sink on cpu is mount properly check ram also.
now check on button if it is ok push it to on.
if now occouring same problem.
change cpu and check
if the problem is not solved you mother board is faulty.
Posted on Jul 30, 2008
  • yashan.co.in Jul 30, 2008
    reconnect hdd, fdd, pci devices one by one before on your pc
    you must shutdown your pc before connect peripharel devices.
    check your home grounding also.
Power supply or main board ? RCA flat screen
At a guess, main board. I agree if power supply board is bad, you won't get DVD working.
Dec 31, 2015 | RCA 26LA30RQD 26 LCD TVDVD Combo
Wont power up
My wont turn on too, There is a orange light on the tower, Green on the left, Battery ovel, If I push the restart button, also switch the power supply switch in the back, also unplug from it, Sometimes does it, Do ou know whats causing this to happen, Please let me know Thanks
Jan 26, 2013 | Asrock K10N78M Motherboard
No power from transformer
If the switch mode power supply does not power up then it maybe be faulty.
First check the power button wires from the front panel to the motherboard is seated correctly on the motherboard.
If it still does not boot up then replace the switch mode power supply, make sure the new switch mode power supply has the same or higher wattage rating.
Apr 05, 2012 | Computers & Internet
My old power supply had 4 wires going to the front panel on\off switch. The Dynex power supply does not support the switch. what do I use to turn the unit on or off. Will the unit function with out the...
Normally the front panel on/off power button and the front panel reset button plug into connector pins on your motherboard.
If you can find a User Manual for your motherboard it will show you exactly where the switch leads plug in on the motherboard. The motherboard's manufacturer and model number will be printed on the board somewhere.
Good luck.
Feb 05, 2011 | Dynex DX-400WPS 400-Watt Power Supply
Cannot power up computer with Dell motherboard E21882. Power supply seems fine. Even after I replaced power supply system would still not come up. Can I test the front panel plug to see if the power on...
yes but try testing all leads that attach to your hard drive including electrical extensions and also the ones from your motherboard that attach to your hard drive also test the leads that attach to cd,dvd,3.1/2 floppy drives
hope this helps
Aug 13, 2010 | Dell (E210882) Motherboard
My P4 VMM 1.0 with win 98 and XP always restart after shuting down. Please help me to solve the problem
This is most commonly an issue of either the ACPI instruction being sent to an ATX power supply being misinterpreted as a restart command, or the controller in the power supply being faulty in general.
The root of the issue can be either your motherboard, or your power supply itself. To test this, try using a different power supply on the motherboard. If it works fine, try testing your power supply on another motherboard. If your power supply works fine there as well, then there's simply an incompatibility of some sort between the motherboard and PSU.
If on the other hand it doesn't work fine on the other motherboard as well, then you know the PSU is faulty.
The degree of fault in the PSU can be anything between harmless and severe; for safety's sake, I would recommend replacing the PSU entirely if a new/different PSU resolves the issue, as your PSU burning out may cause damage to your motherboard and/or (other) connected devices.
Mar 16, 2010 | EliteGroup P4VMM2 Motherboard
Emachine W2047 No BIOS Start Screen
Replace motherboard. Processor socket burnt out, contact me for further support at compdoctor2005@btinternet.com
Dec 07, 2008 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Asus K8V SE Deluxe - will not turn on
it should have pins to reset it touch the two reset pins with screwe driver to activate it if still gont work you have a bios problem
Dec 05, 2008 | ASUS K8V-MX Motherboard
Curly one
I think that you have a faulty power switch there. I know it is new but there could still be a fault. Suggest try a new power switch as for the earthing check that the motherboard screws are all in place and secured to the case.
Thanks J
Jan 17, 2008 | Dell OptiPlex GX520 PC Desktop
KV7-V power supply
follow the power cable from the PSU to the motherboard and see if the 21 connection has melted to the motherboard. You are better getting a 500W silent type, but it depends on the peripherals you have installed, try www.ebuyer.com for various makes.
Oct 09, 2007 | Abit KV7-V Motherboard
Dell OptiPlex GX520 PC Desktop Logo
105 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
