Question about Sony STR-DE575 Receiver
My reciever does not work
I have a Sony reciever-STR-DE575. When I turn it on, it flashes a message "PROTECT". I unplugged the reciever for a couple of days, hoping it would reset itself but it did not. The volume is set at 5. Is it repairable or I should buy a new one?
thanks,
Mirza
  • 10,594 Answers
Power Amp IC gone in your set, replace it.
Posted on Jul 30, 2008
  • 3 Answers
Hi i have a sony str de 475 reciever, but i dont have a remote control for it. is there any way to programm any other remote? for example from tv lg327000?
Posted on Jun 08, 2009
No sound. It flashes protect.
Your device has went into protection mode, an internal malfunction causes it to shut down in order to protect itself.
Somtimes a physical reset will help.
Turn of and unplug device fro a couple of hours
Feb 15, 2012 | Sony STR-DE345 Receiver
Sony home theatre system
Good enws is yout unit is not fried. Bad news is you need to get the protection fuse replaced...
Mar 04, 2008 | Audio Players & Recorders
I have a Sony STR-DE 597 reciever. I have been using it fine for a few years with no problems and it sounded great. I turn the unit on recently and a message was displayed on the unit that said PROTECT....
Protect will usually show up if the receiver was turned up too loud to the point where the speakers will crackle, the receiver will switch to protect to not damage anything. Unplug it for about 30 seconds and check all the audio wiring in the back to make sure everything is plugged in good and tight and no loose cables or stray pieces of copper audio wire and plug it back in.
Aug 21, 2011 | Sony STR-DE595 Receiver
I just bought a new Sony STR-DH510 reciever, I connected a sub woofer and 2 surround sound speakers to it and it worked perfectly. The next day I go to turn it on and it will turn on for about 30 seconds...
Problem is in the amplifier output stage...there is probably a shorted component...the short could have come from a bad speaker..or the speaker wires getting touched together while it was on...you could return to store if it is new and get a new one...maybe it was a return and accidentally got put back into stock
Jan 20, 2011 | Sony STR-DG510 Receiver
SONY RECEIVER IS LOCKED. IT JUST FLASHES THE WORD "PROTECT"
It either got an electrical short somewhere on the chassis or overheated. Press down the power button on the receiver and hold it until you hear a second click from inside the chassis. Then try to power it back on and go from there.
Dec 29, 2009 | Sony STR-DE575 Receiver
My right front speaker does not work and when I have the volume over a certain level "protect" is displayed and it stops working
if the speakers are more watts than the amp puts out or if u have to many speaker wires laced into one port the protect mode will switch on
Dec 13, 2009 | Sony STR-DE575 Receiver
Sony DE-445 reciever flashes PROTECT
Sounds like a grounding problem. If the ground plug isn't missing or loose try plugging it into a different outlet.
Jun 13, 2009 | Sony STR-DE445 Receiver
Sony STR-D460Z receiver
A common cause are failures in the amplifier output stage, the drivers, and some of the support components. You will have to send the unit out for service.
Jerry G.
Feb 08, 2009 | Sony Audio Players & Recorders
My reciever is flashing the word PROTECT and will not function. It's a Sony STR-DE445
Follow the steps below to troubleshoot if the word PROTECT or PROTECTOR is flashing on the A/V receivers display.
  1. Check the speaker wires and speakers for proper connections.
  2. Reduce the volume level. IMPORTANT: If the receiver is played back at maximum volume level it may enter the protect mode. Maximum volume listening will cause the receiver to run very hot and may drain the output capacitors.
  3. Disable the surround sound option if both the A and B speakers are being used simultaneously.
  4. Ensure the top of the receiver has proper ventilation to keep it from overheating.
  5. If the message only occurs when using a DVD player, the sampling frequency may be set too high. IMPORTANT: Some receivers provide compatibility with the higher sampling frequencies through alternate connections. Consult the owners manual for specific information.
  6. Unplug the AC power cord for about 1 to 2 hours to reset the output transformers.
If the issue is still unresolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Dec 15, 2008 | Sony STR-DE545 Receiver
Sony STR-DE575 Receiver Logo
772 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
