D-Link DIR-615 Wireless Router Logo
Posted on Mar 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can connect to my wireless internet on my laptop, but then it says there is no internet connection. What do I need to do?
Tony
Level 3:
Master:
  • Master 451 Answers
  • Posted on Mar 06, 2011
Tony
Master
Level 3:
Master:
Answers
451
Questions
0
Helped
121230
Points
1215
Check your ip address and see if your getting both IP and DNS address.
check your router and see if it has a WAN address by going to 192.168.0.1
if not power cycle the cable or dsl modem and then your router and try again.
Wireless antenna or wireless router
Did your ISP Boingo supply you with a DSL or cable modem with a built-in wireless router? If only a DSL or cable modem is supplied and you wish to connect to the Internet by wireless then you need to connect a wireless router to this DSL or cable modem.
You can connect to the Internet using a LAN cable from your laptop to the DSL or cable modem.
If your laptop as a built-in wireless card you can to the Internet via the wireless router.
If you laptop does not have a built-in wireless card then you can install a PCMCIA wireless card into the card slot of your laptop to the Internet via a wireless connection.
My lap top isnt set up for wireless connection to internet
Connecting laptop/computer to wireless router
If you have a wireless router and it is connected to the DSLor cable modem and Internet then -To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards and wireless adapters in all the laptops/computers needs tobe configured with these router's wireless settings. Then the laptops/desktopcomputers can communicate with your wireless router and access the Internet via the DSLor cable modem.
How to change browser to allow conection to internet
To connect to the Internet you need a few extra things aswell as a network or wireless card and install the LAN or wireless driver.
1. You need to sign up with an Internet service provider.
2. Connect a LAN cable from your computer to the DSL or cable modem
3. You need a DSL or cable modem and connect and configure the modem to inaccordance with your Internet service provider's instructions.
4. Install Internet Explorer if it has not been done.
5. If everything has been done correctly, when you open Internet Explorer youcan access the Internet.If you have a wireless router and it is connected to the DSLor cable modem then -
To connect to yourwireless router, the router needs its wireless settings to be configuredwith the SSID, encryption key etc., also the wireless cards in all thelaptops/computers needs to be configured with these router's wireless settings.Then the laptops/desktop computers can communicate with your wireless router.
How do i get my netbook to connect to the internet/ what wireless device can I get to make it work
You need to have an active internet connection with a wireless gateway to connect to the "net" wirelessly. You also need to have a wireless device installed in your laptop. The device in your laptop usually has a switch to turn it off and on. This switch maybe on the side of the laptop or may be on one of the keyboard function keys, either way, the wireless support lamp should be on or green for the wireless system to work on the laptop.
If you do not have an active wireless internet connection, you cannot connect to the net although you should be able to connect to a unsecured wireless network which is in range of your laptop ( like in a shopping centre).
If your laptop does not have a wireless device fitted, visit your local computer shop to ask what they have available and at what cost.
2answers
How to get the router to work.... i have a desktop and a laptop and the desktop has internet .....but how do i get the laptop connected to the internet using the router
Connect your internet connection to the port on the router
then connect your laptop and desktop to the router.
if you have a user name and password enter these in the router settings
everything should work
4answers
Unable to connect two wireless laptop for internt sharing
Make sure your computers are set to DHCP instead of static.
1helpful
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
2answers
My lap top connects to the network but I cannot get on the internet
u need a wireless key to connect to the internet, log in to the router page and wireless settings - copy the wireless key to get connected wirelessely
Iam trying to connect my laptop to the innet. i have wrt54g router.
Hi jjroyc
Let's see if we can get your laptop connected to the Internet.
First, I have some questions and a few instructions for you.
(01) Is this a new (to you) router?
(02) Do you already have one or more computers connecting successfully to the Internet using this router?
(03) If yes, are any of them connecting wirelessly?
(04) Have you recently (at another location for example) successfully connected this laptop to the Internet? If so, did you connect it "wired" or "wirelessly".
(05) Are you trying to connect your laptop to your router "wirelessly" or "wired"?
(06) If you are trying to connect the laptop wirelessly, turn off your laptop's wireless radio and connect the laptop to the router "wired" instead (using an "Ethernet Patch Cable"). Once we've established that the laptop is capable of connecting to the Internet via the simpler "wired" connection, then we'll move on to the more complex wireless connection.
(07) Please, go HERE to download the manual for your particular router. You will need to determine the version number of the WRT54G model 1st. There are instructions there that will guide you through this.
BJ
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
