Question about Canon PIXMA MP160 All-In-One InkJet Printer
Ink low My printer won't print because it says the black ink is low. I'm sure there's still ink in the cartridge. How do I fool it to continue to print? I have a Canon Pixma MP 180/160 photo printer. Elaine
    Guru:
  • 1,049 Answers
Hopefully you won't devalue my answer just because it isn't the one you want to hear. But on a canon Pixma, the most likely reason it says "empty" is that you had the ink dry within the cartridge when it wasn't in use. That means that even if it isn't completely empty, what ink is in there without the addition of some sort of solvent, is unusable. There is also the issue that if you manage somehow printing with slushy ink it may still lead to clogged nozzles, damage to the print head, etc.
You could get a syringe and possibly inject something into the top of the cartridge to thin the ink, but unless you literally just installed the cartridge it probably isn't worth your time. It's a downside to the design of the printers which have the small ink nozzle installed on the print head rather then the copper tabs on the cartridge like HP deskjets etc. They are cheaper to make but not nearly as air tight.
Posted on Jul 30, 2008
I have a Lexmark Pinnacle Pro 901 printer and its set up to print using black ink only, but it keeps telling to replace color cartridges and it won't let me print at all, how do I print using blac
The printer would need all cartridges to have sufficient ink levels to continue printing - that's to prevent damaging the printhead. Every time a cartridge is replaced, all colors are primed simultaneously thus the need for all cartridges to have ink.
To save on your ink investment, try printing in draft mode and by making sure that your printing preferences is set to print using black ink only.
Oct 25, 2012 | Lexmark Pinnacle Pro901 All-in-one Inkjet...
Canon mg5220 printer won't print black
Try this: take a small, sharp knife and make sure the air slit on the top of the cartridge goes all the way through the plastic.
You know that little tab you have pull off the top of the cartridge before inserting in the print head? There is a tiny slit under the tab to let air in, which is necessary to let the ink flow out. The slit is made very small so ink won't leak inadvertently out the top. Sometimes the slit doesn't go all the way through the plastic. When that happens, the ink can't flow.
I blew through that slit on a defective cartridge and no ink came out. I used a pen knife to open the slit (it doesn't take much) and then blew again. This time ink spewed out the bottom. My print test showed the black ink coming through. It was a bit spotty so I cleaned the print head and now the black ink comes out just like its supposed to.
Mar 13, 2012 | Canon Pixma MG5220 InkJet Printer
The printer won't print. It says replace the color ink cartridge. All I want to do is print black and white.
You can only use the black ink cartridge without the color ink. But no need to replace them in your printer.
When you print just choose black and white for the printed text must be black not colored. But if you still received such notification...just try to replace the color ink cartridge to continue printing
Note: As per my experience. printer with exclusive black ink alone will damage the printer easily due to unbalance printing of ink
Sep 20, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink cartridge and I have a drawer full of small 8BK cartridges. How can I get it to use the small black...
Canon PIXMA MX850 Multi Function Printer Printer Canon MX850 will not print from... Answer Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink... (More) Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink cartridge and I have a drawer full of small 8BK cartridges. How can I get it to use the small black cartridge and not the large black cartridge? Thanks
Sep 30, 2009 | Canon PIXMA MX850 Multifunction Printer
HP Deskjet 6940 not printing after replacing ink cartridge
My HP Deskjet 6940 is not printing. The color (left) low ink light is dark and the black (right) low ink light is flashing. I replaced the black ink cartridge with a new one but the low ink light continues to flash. No tears/rips in the circuit strip and all the copper leads appear to be connected
Sep 29, 2008 | HP Deskjet 6940 InkJet Printer
Printer cartridge low
It is very unlikely that this is a sensor issue. The ink is probably dry or the cartridge itself is clogged. You could get a syringe and possibly inject something into the top of the cartridge to thin the ink, but unless you literally just installed the cartridge it probably isn't worth your time. I think there are ink refill kits online for these.
Adding new ink might also help to thin the old ink.
Jul 30, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Black ink not recognized
Select printer, properties.
Select printing preferences, select advanced.
Select more options.
Make sure you do NOT have Use color cartridge for all black printing selected.
(I had set that a while ago when my black cartidge ran out when the kids had a paper due - I forgot I had reset it. Once my color cartidge ran low, everything printed pink).
Let me know if that works for you.
Jun 05, 2008 | Dell 924 All-in-One InkJet Printer
Not printing
The remaining levels of the following ink cannot be correctly detected.
Color
The following ink is running low.
Black [830]
Prepare a new ink cartridge.
The resulting print quality may not be satisfactory, if printing is continued under this condition.
If either black or color ink cartridge has run out, you can set the printer to continue printing with the other cartridge from the Ink Cartridge Settings on the Maintenance tab of the printer driver.
----how to resolve it
email me: akemzone@yahoo.com
Feb 24, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Pixma 4200 compatible ink cartridge problem help
The ink detection is a critical function of the printer.
Ink actually acts as a lubricant for the heads, and running (Printing) without ink is equavalent to driving a car without oil.
I.E. It will seize eventually....
Hopefully you didn't print much without the ink, and your heads are still in good shape...
Here is a chip reset procedure....
With the original chip now attached to the compatible cartridge (you may need double sided tape to get the chip to stick well to the cartridge), and with the cartridge now in the printer, Press and hold the Reset/OK Button for 5 seconds to reset the chips.
  1. The "Ink Low" dialog box will pop up (similar to photo 1 below)
  2. Continue to print until the "ink has run out" dialog box pops up (similar to photo 2 Below) Click "OK" to continue to print.
  3. The "Ink Low" dialog box may reappear, if so repeat the first 2 steps
  4. Then the "once empty" dialog box will pop up (similar to photo 3 Below) Click "Yes" to continue to print
  5. The "Not Liable" dialog box will pop up (similar to photo 4 below). Click "Yes" to continue to print
  6. Continue to print until the "remaining level of ink" dialog box pops up (similar to photo 5 Below) Click "OK" to continue to print
  7. Another dialog box will pop up with the "press and hold the Resume" or "press and hold the Paper Feed" button (similar to photo 6). Press and hold the "STOP/RESET" button (for Canon MP Series) or "PAPER FEED" button (for Canon IP Series) for 5 seconds. DO NOT Click "Back" or "Cancel Printing"
  8. The "Ink Monitor" dialog box will appear and the printer will continue to print. (similar to photo 7) In the event that that the "press and hold the Resume " dialog box pops up again, Press and hold the Paper Feed Button or Stop/Reset Button for 5 seconds
Feb 05, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Colour printing
Check the following thread, it might apply to your problem. and just as a printer can be fooled to show a low level ink, I guess it can happen the other way around. http://www.fixya.com/problems-solutions/t103191,p342983/Epson-Stylus-Photo-R300-InkJet-Printer.aspx Good luck
May 19, 2006 | Epson Stylus C64 InkJet Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
48 people viewed this question
old marine
old marine
