Question about Sony XM-1502SX Car Audio Amplifier
The overcurrent light is on any ideas? help - Sony XM-1502SX Car Audio Amplifier
  • Anonymous Oct 16, 2008
    My amp is used from a friend but he said was last known working. The red overcurrent light appears as soon as the amp receives power. This is the case when any combination of subs are attached or just 12v, ground and rem. The manual states two entirely different possible problems. Either to powerful signal or short in the speakers which cant be the case when they are not connected. The 12v line was tested at 12.38v. I do not have any capacitor but a 30amp in line fuse.
  • 10,594 Answers
Power Amp IC gone....replace it.
Posted on Jul 30, 2008
Fault code p1193 fuel pressure. has any one an idea what has caused this light to come on with this code???
P1193 - EGR Drive Overcurrent
Possible symptoms:
- Engine Light ON (or Service Engine Soon Warning Light)
P1193 Description: EGR Drive Overcurrent is one of the definitions for the P1193; however your vehicle's manufacturer may have a different definition for the P1193 code. Please check below for your specific make.
P1193 Information for specific makes:
P1193 ACURA
P1193 BMW
P1193 CHRYSLER
P1193 DODGE
P1193 FORD
P1193 HONDA
P1193 HYUNDAI
P1193 JEEP
P1193 KIA
P1193 EGR Drive Overcurrent
May 31, 2015 | Cars & Trucks
My lg air conditioner power and timer light blinks 2 time on each light (power 2 times and timer 2 times) I have no idea what this means. I know its an error code. But is it serious ?
It appears to be an error 22. According to the LG bible, it means an overcurrent protection has activated. In most cases, unplug the machine or switch off from power supply for at least 15 minutes, it should reset the main control board. If this doesn't work , it may have damaged the board. Alternatively, if your machine is on 3 phase, check that all fuses / circuit breakers in your meter box are OK and switched on. You may have a weak or disconnected power supply.
Dec 25, 2013 | LG Heating & Cooling
Overcurrent lights comes on whenever my amp is on
this can only mean 2 things, either your over working the amp, which means your amp is trying to push power that it don't have, and it's getting hot which is known as thermal mode. and the other reason can be that make sure amp rms. matches the rms. of your subs.
Mar 13, 2010 | Sony XM-2150GSX Car Audio Amplifier
Its on over current
when the overcurrent light lights up, this means the amp is being run too hard or too loud. try cutting the gain back a little. i always hated putting in the sony amps that had those lights on it. it seems that when you turn it up and get it sounding good the light comes on.... if the overcurrent light is on all the time and it doesnt make sund....the amp could be bad. good luck.
Dec 17, 2009 | Sony XM-754SX Car Audio Amplifier
WHEN I PLUG IN TV THE TIMER LIGHT IN THE FRONT COMES ON BUT THE SCREEN WONT COME ON AND I CAN HEAR A TICKING NOISE
the ticking comes from overcurrent circuit protection there are several areas inside the tv that could be causing this. The most common are the horizontal drive and output circuit and the power supply. If you call your area service tech he can give you a good idea on what the repair costs will run.
Sep 25, 2009 | Akai PT5492S 54" Rear Projection...
I have a 2002 galant. for some reason every time i install a new amp in my car it stops working after a few days. any ideas?
Hello d4n_r1ch1,
You don't say what exactly happens to the amps.
Is it the same make and model of amp each time? Do they fail gradually? Do they overheat? Do they go into protection mode? Do any of the fuses ever blow before the failures? Are there any "burning" smells or melted plastic parts?
In any event, I'd suspect some kind of wiring problem is killing the amps. Inadequate grounding, operating below or above rated voltage, and overcurrent are the most likely causes for failure. You can check the ground and the voltage with a multimeter. Overcurrent is usually caused by operating the amp into too low impedance. Again, that is something you can check.
Hope this helps.
Aug 24, 2009 | Pioneer Car Audio & Video
Amplifier keeps running overcurrent
sounds to me like you are overheating the amp, try down tuning the peak level of the amp, and also if there is anything around the amp clear it away, check if the fan is turning on, you may need to replace it,
May 20, 2009 | Sony XM-2150GSX Car Audio Amplifier
My amp turns on, power light is on, but overcurrent light also
make sure ground is good then turn gain all the way down turn on deck turn it all the way up then turn it off then back on agian its like a jump start the amp then should work and you can reset all youre levels
Apr 08, 2009 | Car Audio & Video
Sony car amp
Everytime the overcurrent light is on,the audio amplifiers IC's are in bad conditions
Jun 04, 2008 | Car Audio & Video
Amp overcurrent problem
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down (overcurrent), the amp likely has blown output transistors.
Sep 20, 2006 | Sony XM-2150GSX Car Audio Amplifier
Sony XM-1502SX Car Audio Amplifier Logo
237 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
