Trying to connect my phone to computer via usb port nothing shows up to alow to move my photos to my computer
  • kymelson Jul 30, 2008
    home vista premium samsung u600 i downloaded the driver from samsung any ideas what to do now would be awesome thakx
How do i go about accessing my images,music on galsxy s2 via pc
When you connect your cell phone with the supplied USB cable and then connect it to your computer's USB port the computer should detect the cell phone as an USB storage device which you can then open to download to your computer.It this does not work then -
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB mass storage device oran external storage device, you can then open the folder on the memory card andcopy the photos to your computer.
Jan 01, 2012 | Acer Computers & Internet
I'm trying to set up my computer so my phone will charge. What do I need to do?
You'll need a USB-to-cell phone cable, commonly called a "tether." Normally tethers are
used to provide internet connectivity via cell phone to the computer (sounds desperate
and terribly slow, but not only is it possible, its better then nothing). Its also useful for
uploading pictures from camera phones to a PC/cloud.
The tether for your phone will have a USB type A port on one end (for the computer)
and a connector on the other end (for the cell phone) that's called a USB "Mini-B" connector (since you phone has a USB Mini-B port).
This cable is very commonly available, since its used for digital cameras (and nice MOTORAZRs).
Here's a link to one manufacturer's "USB Data Cable" for your phone:
http://www.wirelessgalaxy.com/motorola-rival-a455-oem-micro-usb-data-cable.html
I'm not endorsing www.wirelessgalaxy.com, its just that they have a nice photo of your tether.
Jun 09, 2011 | Motorola Mobility MOTORAZR VE20 Cell Phone
How to upload my picture from galaxy S to my computer
you can try connecting your phone to the PC through USB port, or if you have blue tooth support on your pc you can send your photo via blue tooth
May 05, 2011 | Computers & Internet
How do I download pictures from my Sony Ericsson phone onto my computer
You can transfer photos from a phone to a computer via USB cable. In the computer, the phone will be visible as a removable drive to which you can drag and drop or cut/copy and paste your photos. I hope this helps.
Oct 22, 2010 | Sony Ericsson Z520i Cellular Phone
I cant download my pic from my camera it showes no inage found
Hai,
The easiest and best method to download photos and video from your camera to your computer is via a little USB card reader (which are quite cheap these days).
Card readers also work for moving photos from the computer onto a card.
Plug the reader into a USB port and insert the memory card.It will show up as a drive, and you can simply drag and drop the photos across to the folder of your choice.
Click HERE
Aug 23, 2009 | Kodak EasyShare C330 Digital Camera
I want a software to download photos from my cellphone to my Pc
Didn't you get the software CD (PC Suite) when you bought your cellphone? PC Suite, Data Cable, Headphones, all come as free accessories. If you don't have it, download the PC Suite of your phone model and use the file transfer option. Alternately move the photos to your memory card, take out the memory card and insert it in a card reader. Connect to USB port and move the photos to a drive or folder in your pc. You can use copy-paste or cut-paste (to free your phone memory).
Aug 05, 2009 | Nokia Cell Phones
Want to connect a Mac laptop to a EpsonStylus Photo R340 printer.
Hi
Try connecting the printer to a different usb port if you have extra port and make sure the connection is direct from printer to your mac
Hope this helps
Nov 14, 2008 | Epson Stylus Photo R340 InkJet Printer
RX620 wont communicate via powered USB hub.
on a windows system, go to printers and faxes, delete all icons there. unplug the printer, reboot your computer, then as soon as your computer is up, connect the usb cable... now wait.....
after about 5 mins, check printers and faxes if it has an icon for your printer, if it does then print a test page, if it does not show an icon, try another cable, try another usb port or try it on another computer entirely...
Sep 05, 2008 | Epson RX620 All-In-One InkJet Photo...
Reply
Hi there again,
I am assuming you are using XP OS.....
I have a couple of questions for you.
Try this.............
With computer on and camera NOT connected,
Please look at my computer,
1.What happens when you connect camera to usb lead then connect the lead to the computers usb port?
2,Would it upset you if we use another way of moving your photo and video files from camera to computer?
3.Does Memory card work in another device or computer?
Solution 1 =================================
If usb did not recongise the camera on the usb port then it will be a software and hardware reinstall ,
Remove usb lead from computer
Go to Add/Remove from you control panel.
Remove the cameras software.reboot.
restart install software first and reboot,
do not connect camera yet,WAIT.
once restarted add camera via usb
should be good to go.....
If it does continue to give you issues then consult the manufactuerer.
Solution 2 =================================
if the usb is connected to the camera via usb lead to usb port on the computer and you can see the cameras' drive info then its more than likely you will be able to open and use this file ,if so you should be able the move these files to your computer too.
Solution 3 =====================================
Explains itself really-Replace it if you need to.
Hope this sorts out your problem.
I beleive your card reader may be poked,
Uninstall and reinstall try again, replace if presists.
these solutions I have put forward have been proven to work in many situations so good luck and let us know the results thanks
Jul 16, 2008 | Computers & Internet
Trying to upload photo's but phone wont connect via usb
while connecting phone to pc through usb port u should install the phone software in the pc first otherwise the pc will not allow you to connect and trasfer data. if there is a software u can easily trasfer data from phone to pc and pc to phone.
May 23, 2008 | LG KU990 Viewty
Computers & Internet Logo
129 people viewed this question
David Payne
David Payne
