Question about Amana Washing Machines
There is hardly any cold water coming out when I start a wash load. It takes forever to fill the tub. Could this be the mixer in the back where the hoses attach? Thanks, Kevin
  • 254 Answers
Yes, the cold water side is very common to get clogged with sediment you can try too change the filter screen in it but you usually end up having too replace the whole valve assm.
Posted on Jul 30, 2008
When the full washing cycle has finished and all the lights are off, water starts running into the tub. Would keep filling forever if I didn't turn hot and cold off at the connection. I then push...
Water will not shut off
1. Defective timer ( timer fill the machine)---replace
2. Defective water level control---replace
3.foreign particles in mix & fill valve---clean out valve
4. Defective valve---replace
Sep 22, 2011 | Fisher and Paykel GWL11 Top Load Washer
Kenmore 90 Plus Series washer washer takes forever
is the cold water all the way on?
if so, the first thing to do would be to check the screens in the cold water fill hose and the screen in the cold side of the water valve on the back of the machine. if that is not the problem then replace the water valve.
(turn the water off before taking the hose loose)
Jun 16, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Problem: the cold water just dribbles out when filling the tank and it takes forever to fill the tub.no problem with the hot water flow.
If you have water pressure to the cold inlet valve and the valve's filter is clear, you probably have a failed inlet valve...Replacing the cold valve should fix the problem..Not a big or expensive job..Good luck....Nomess
May 20, 2010 | Washing Machines
Fills to wash, drains but then tub won't fill for rinse cycle;
u need a new cold water valve, if u check the temp of the water while its filling it is mainly hot, or u have the hot nd cold hoses on the wrong way , as all rinses r cold
Jan 31, 2010 | Fisher and Paykel GWL11 Top Load Washer
When the water has reached it's proper level, the hot water turns off, but the cold water keeps filling until the water overflows the basket
Try this. With the wash tub empty, start to fill with water. Without turning washer off, unplug the washer from wall.
If water filling stops (hot and cold), then you are looking at a bad timer assembly. Replacement isn't that hard, parts can be difficult to find though.
If water continues to fill, your valve body / solenoid assembly is likely full of lime-scale. Easily replaced.
Jan 04, 2010 | GE WVSR1060A Top Load Washer
Kenmore Series 90 top loading washing does not fill with water
Well you eliminated the fill valve when you said it does fill with water. More than likely its a bad connection on the control board. I wouldn't betmy paycheck on it but thats where I'd start. Take the cover off the control board and while machine is on being really careful wiggle each wire until the water starts in the tub and you have found the problem.
Aug 23, 2009 | GE WVSR1060A Top Load Washer
HOT WATER WON'T FILL TUB
most inlet water hoses have screens in them.  You could remove the hose from the back of the washer and see if there is water flow.   If there isn't, the hot water valve assembly is defective.  These are solenoid operated valves that admit water into the tub.  They can be accessed behind the washer after you remove the back.
Mar 30, 2009 | Amana DLW330RA Top Load Washer
Maytag Washer (approx. 7 years old) has slow stream when filling
Follow the two inlet hoses from the back of your machine. They should each end at a valve (one for hot and one for cold). Make sure that these valves are all the way counter-clockwise and that the hoses are not kinked or pinched.
Jan 19, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Magic Chef washer 15 years old, fills slow no hot water
Pull the hot /cold hoses off and clean out the 2 screens in the valve.Put the hoses back on and re try washer .Problem solved?If still no hot water ,replace your water valve. Please Rate This !!!!
Jun 19, 2008 | Magic Chef CAV2000AWW Top Load Washer
Washing Machines Logo
32 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
