Question about Electrolux Vacuums
Electrolux vacuum making a clicking sound when the brush is engaged
  • 328 Answers
Check that there is nothing lodged between the roller brush and the main dirt channel. You may have to take off the sole plate by either locating the cross head screws underneath or if the hood pops off the top - some Electrolux models have screws now located on the top. Once the roller brush is open to your eyes, look at the drive belt and check its condition - it may be on its way out and needs replacing OR the brush roller has clogged up OR the caps which hold the roller brush in both ends of the roller are loose and need a slight tap to lock them back in.
Dont forget to rate this solution. Ty
Posted on Jul 30, 2008
Electrolux el 7020 Canister Vacuum shuts of continuously do i need to Change the Carbon Brushes
How old? If fairly new you should not need brushes, bad brushes would probably not allow the vacuum to run at all. Last time you changed filter? Sounds like the cover to the filter is not closing well enough. There's also possibility you have a clog in the wand or hose.
Mar 05, 2015 | Electrolux EL7020 Bagged Canister Vacuum
Electrolux Vacuum Renaissance Power head brush won't turn
if it is making a humming sound but not turning you belt is broken, if it is not check the reset switch (little res button) if that doesnt work check the connections between the cord of the powerhead and the wand, the wand and the hose, and the hose and the vacuum
give the hose itself a good look over sometimes the wires up by the grip break in the casing
Mar 12, 2014 | Electrolux Vacuums
My upright electrolux persicion vacuum when turned on just makes a horrible sound both on bare floor and on carpet brush does not turn
Hi, sounds like you need a new belt or brush and bearings . Sometimes when a belt goes it makes a bad noise as one of the belt teeth make be worn out. Hope this helps.
Jan 22, 2014 | Electrolux Vacuums
Makes heavy vibration noise when turned on for carpet and belt is good
Check the brush roll and the end caps to insure the brush roll is spinning freely. If there is wear or damage to the brush roll it can cause it to be out of balance and vibrate
Jan 12, 2014 | Electrolux EL5020 Vacuum
Roller Brush on Electrolux Nimble vacuum not rotating.
Many vacuums use air flow to rotate the brush. I would suspect the nail has blocked the piping inside and needs a tear down to remove it .
Aug 27, 2017 | Electrolux 5740 Upright Vacuum
I have an electrolux discovery II vacuum cleaner and the floor function works, but when I try to switch over to carpet mode, it doesn't seem to engage.
There is a red reset button on the back of the machine. When it trips, the brush won't engage. Press the reset button and then try your machine again.
Apr 07, 2011 | Electrolux Vacuums
Hello! I have an Electrolux Ultralux 2000,
Sounds like the belt on the beater brush has broke.replace the belt on the beater brush.
Dec 06, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Roller brush on PROLUX is making a chattering sound.
sounds like its the bearings in the end of the brush roll
Feb 20, 2009 | Electrolux 5740 Upright Vacuum
Vacuums Logo
74 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
