2001 Volkswagen Jetta TDI Logo
Posted on Mar 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Anyone know sequence and torque specs for a Volkswagen JETTA 2.0 L, AEG cylinder head?
Anonymous
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on Mar 06, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
16
Questions
0
Helped
5258
Points
39
Per Chiltons...
Step 1: 30 ft lbs
Step 2: 44 ft lbs
Step 3: Plus 90 degrees
Step 4: Plus 90 degrees
Here is the tightening sequence...
10 4 2 6 8
7 5 1 3 9
Anonymous
Level 3:
  • Master 869 Answers
  • Posted on Apr 28, 2011
Anonymous
Master
Level 3:
Answers
869
Questions
Helped
785481
Points
1021
Please specify your volkswagen jetta year model.
Anyone knows the torque setings for jetta 2 cli 1.8 head
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=big-block-injection_2%2F1-8-gti-cylinder-head
https://www.justanswer.com/vw-volkswagen/2706j-1997-jetta-torque-settings-vw-the-head-fly-wheel-big-ends.html
Need head bolt torque specs for a 1996 saturn sl
Quote:
Originally Posted by norvelplagbao52
1993 saturn sl2 1.9 dohc cylinder head torque
specs and sequence
Cylinder head bolt
tightening procedure:
CYLINDER HEAD BOLT TIGHTENING SEQUENCE:
INTAKE
SIDE
8 4 1 5 9
7 3 2 6 10
EXHAUST SIDE
In sequence,
torque the cylinder head bolts. Torque: 30 Nm (22 ft-lbs).
In sequence,
torque all bolts. Torque: 50 Nm (37 ft-lbs)
In sequence, turn each bolt an
additional 90 degrees.
specs and sequence
Cylinder head bolt
INTAKE
SIDE
8 4 1 5 9
7 3 2 6 10
EXHAUST SIDE
In sequence,
In sequence,
Good day, can anyone help me with torque specs and sequence for a 2002 volkswagen jetta 1.8L cylinder head to engine block.
The 2002 service manual says replace stretched bolts. stage I: 30 ft-lb (40Nm) stage II: additional 1/4 turn, stage III: another 1/4 turn. Start in center, work your way out diagonally back and forth (crossways) ending on the ends of the block. Do this sequence on each stage.
2helpful
2answers
Torque specs for 2005 nissan altima 2.5
According to Haynes Manual, 2005 Nissan Altima, using BRAND NEW cylinder head bolts:
1 - Tighten in sequence (as pictured) to 37 ft-lbs.
2 - Tighten an additional 60 degrees.
3 - Loosen all bolts completely.
4 - Tighten in sequence 26 - 32 ft-lbs.
5 - Tighten in sequence an additonal 75 degrees.
6 - Tighten in sequence an additional 75 degrees.
Can i change a leaking top gasket at home? I want to remove the head and have it skimmed.I am reasonally mechanical minded. What is the torque for fastening the top nuts? Manie vd Merwe. Jeffreys Bay
VOLKSWAGONS YOU NEED CYLINDER HEAD REMOVE SEQUENCE AND CYLINDER HEAD TORQUE SEQUENCE.YOU NEED A REPAIR MANUAL FOR TORQUE SEQUENCE OR YOU WILL HAVE HEAD GASKET LEAKS. TORQUE HEAD BOLTS TO * STEP 1 * TORQUE BOLTS 30 FT LBS * STEP TWO * TIGHTEN BOLTS 44 FT LBS STEP 3 TIGHTEN BOLTS PLUS 90 DEGREES.* STEP FOUR* TIGHTEN BOLTS PLUS 90 DEGREES AGAIN.
11helpful
2answers
94 mazda B3000 3.0L cylinder head torque specs
Step 1 torque to 59 ft pounds
2. Loosen one full turn
3. 37 ft pounds
4. 68 ft pounds
Use torque sequence below
2helpful
2answers
Torque specifications for head bolts 1995 Jetta 2.0
First pass, torque them to 30 Ft Lbs working from the center outward. Then go back again and torque them to 75 Ft Lbs.
1helpful
2answers
Need to know cylinder head bolt torque specs
Head Bolt Torque For your 1994 Oldsmobile Cutlass Supreme (3.4L SFI DOHC): clearpixel.gif Foot pounds (Final torque) clearpixel.gif Note: Torque sequence --------- | 6 2 3 7 | | 5 1 4 8 | --------- Step 1: torque in sequence to 33 Ft/Lbs Step 2: turn an additional 90 degrees Recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque. clearpixel.gif clearpixel.gif clearpixel.gif Foot pounds (Final torque) clearpixel.gif Note: Torque sequence --------- | 8 4 1 5 | | 7 3 2 6 | front --------- of engine | 6 2 3 7 | | 5 1 4 8 | Step 1: torque to 40 Ft/Lbs --------- Step 2: turn an additional 90 degrees Recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque.
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
