Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer is leaking from underneath....
Whirlpool Ultimate Care II; has part # 3954181 on rear of control panel, and has #3357978 stamped on rear of machine.
Water leaks from underneath washer; appears to coming from the front. Any suggestions on what it is and how I would take this thing apart to fix it?
Thx
  • 3 more comments
  • brmac Jul 30, 2008
    Model # is LSQ7533JQ1....
  • brmac Aug 01, 2008
    Good Lord. I can't believe how easy that was..... $ 45 for the new pump from Sears, and approx 5 mins to install using the directions supplied. No more leak!
    Thx a bunch!
  • gmtorg Aug 05, 2008
    Same problem water leaking underneath near front
  • facehead Aug 17, 2008
    I lifted the machine and the leaking appears to be coming from a white plastic container piece. There are two hoses leading into the container, but I don't know what it is called exactly. Can you please let me know if it is replaceable or should we call someone in to fix it?
    Thanks
  • Anonymous Mar 25, 2014
    washer model AWM 293 600 slow leak from below
    Genius:
  • 1,028 Answers
Lean washer back against wall ck pump under front in center for leaks or dark gray area in pump face remove hoses remove clamp top and bottom of pump slide forward off shaft
Posted on Jul 31, 2008
  • oldfixer Aug 03, 2008
    just saved $160 bcks pump is 65 off trk 138 to install by tech
Whirlpool ultimate care heavy duty leaks underneath, not agitate or spin. only humms and fills up
Again!! Any washer that does not drain has a bad Drain Pump. Very Common. I see this in 40-50% of the problems. Replace the drain pump and your washer will be very happy
Jan 19, 2014 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer were is the drain filter
Hi.
With Whirlpool top loader models the pump is located at the bottom of the appliance. The pump is accessed from underneath the appliance. Some model may have an access panel at the back. I think that with the Ultimate Care models the pump must be accessed from underneath. Here a repair video.
Here parts and diagrams.
Aug 07, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care II washer is leaking water from underneath. any ideas?
Take the front or rear panel off so you can watch the parts during the fill, wash, and spin cycle looking at the hoses and pump to determine where the water is coming from.
Nov 07, 2010 | Washing Machines
Ultimate care supreme leaks underneath
First check the hoses to the machine. If they leak the water follows the hoses and drips on floor. Also check the hose connection at the washer. They will leak inside. Next it may well be a water pump going out or the plastic hose that is under pressure when operating. The pump is in the middle of machine underneth - Sorry - Good luck
Oct 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer is leaking even when water in waher but washer off
check out you tube search whirpool washer repair, easy to see how to remoe the panel, most likely a bad pump is cause of leak. will be quite evident!! yo can even just tip unit back the underneath is open
Feb 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care II washer leaks
Sounds like the pump is leaking.
Access to inside washer:
This one you remove the whole outside case and not the back.
Remove two screws on each side of the back control panel, you may have to remove the plastic trim on each end of the panel. The control panel flips back so you can remove two brass clips, unplug the wireing in the back center. The whole outside case can be removed.
The pump is in front and held on by two clips.
Feb 13, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
729 people viewed this question
Dan Webster
Dan Webster
Sal De
