Corrupted iTouch
Update and restore error messages on iPhone and iPod touch
Last Modified: April 21, 2009
Article: TS1275
Old Article: 307219
Symptoms
When trying to update or restore your iPhone or iPod touch with iTunes, you may see an error message in iTunes that stops the update or restore process. You may also see the "Connect to iTunes" screen on your iPhone or iPod touch:
The error message in iTunes may also include one of the following numbers (but is not limited to): 2, 4, 5, 6, 9, 13, 19, -18, -48, -50, 1002, 1011, 1013, 1601, 1602, 1603, 1604, 1608, 1609, 1611, 1612, 2003, 2004, -9808
Products Affected
iPhone, iTunes 7 for Mac, iTunes 7 for Windows, iPod touch, iPhone 3G, iTunes 8 for Windows, iTunes 8 for Mac, iPod touch (2nd generation)
Resolution
Many restore errors can be resolved using the troubleshooting steps found in this document.
Update to the latest version of iTunes
To see if you have the latest version of iTunes, open iTunes and:
Windows: Choose Help > Check for Updates
Mac: Choose iTunes > Check for Updates
Restart your computer
Simply restarting the computer can clear up certain issues that could prevent iPhone or iPod touch from being restored. After restarting, try restoring the device again in iTunes.
USB Troubleshooting
Connect iPhone or iPod touch to a different USB port on your Mac or Windows PC. USB 2.0 ports that are built-in to the computer are preferred over a hub. If iPhone or iPod touch were connected to USB ports on the front of the computer, try connecting them to rear USB ports. After doing this, try to restore the device in iTunes.
If this fails,
Restore on a different computer.
If the issue is not resolved with the above steps, try to restore on a different computer. Ensure that the computer you are restoring on has USB 2.0 ports, the latest version of iTunes, and that you are connecting directly to the computer.
Advanced Steps
Make sure you have admin access
If your still having problems estore using a new user account
Create a new user account on your computer and try to restore while logged in as the new user. iTunes will download a new version of the software restore file. After creating the new user, log in to that account and open iTunes and attempt to restore to see whether the issue persists in this new user.
Windows Vista and Windows XP
From the Start menu, choose Control Panel.
Open User Accounts.
Select Create a new account and follow the instructions to complete the account setup process.
Once the new account is created, choose Log Off from the Start menu.
Log in to the newly created user account.
When a restore issue is specific to a user, it is likely due to an unusable .ipsw file. The ".ipsw" files are what iTunes uses to restore your iPod or iPhone. If those files are unusable, then try deleting them so iTunes can download a new copy of them. Creating a new user will also cause new .ipsw restore files to be downloaded in the new user. You can find the ".ipsw" files in these locations:
Windows XP
iPod touch: C:\Documents and Settings\[username]\Application Data\Apple Computer\iTunes\iPod Software Updates (If you don't see the Application Data folder, you may need to show hidden files by opening (My Computer)
Click on Folder Options. in that window click on the view tab, and make sure that show hidden files is selected.
Windows Vista iPod touch: C:\Users\[username]\AppData\Roaming\Apple Computer\iTunes\iPod Software Updates (If you don't see the AppData folder, you may need to show hidden files)
1.
Open Folder Options by clicking the Start button , clicking Control Panel, clicking Appearance and Personalization, and then clicking Folder Options.
2.
Click the View tab.
3.
Under Advanced settings, click Show hidden files and folders, and then click OK.
After removing and reinstalling the latest version of iTunes, try restoring iPhone or iPod touch again in the origonal user account.
As an added note, If running Microsoft Windows XP and the issue is resolved on another computer, but you continue to experience difficulties on your original computer, you may want to update or reinstall your Windows USB drivers and then try restoring iPhone or iPod touch again.
If none of these steps work you will need to contact either apple at
1-800-APL-CARE (1-800-275-2273)
Or another service provider of your choosing to get the ipod touch serviced or replaced.
I hope this article is very helpful for you and easy to follow. Good luck :)
What operating system are you using?
