Question about Indesit Washing Machines
I have purchased a new door rubber seal(indesit W103) as the old one was split. i have removed the old one but cant work out how to put the new one on. It looks like theres a technique to it. please help
  • Owen Smith Jul 31, 2008
    How to replace door seal in Indesit W101 washing machine - not the same model as the above but might be similar enough
    1. Unplug from mains electricity.
    2. Pull machine out from wall carefully.
    3. Remove screws in top corners (that are holding down the top panel of the machine) at the back of machine.
    4. Remove top panel of machine (slide it slightly in the direction of the back of the machine, it just lifts off).
    5. Remove the detergent drawer (pull it right out and put it to the side)
    6. Remove the two screws at the top of the gap where the detergent drawer goes in
    7. Remove the two screws at the top, front of the machine
    8. Now lift out the panel with the control dials on it (etc.). Careful here, you don’t have to disconnect all of them, you should just be able to put this to the side with all the wires still connected.
    9. If the old door seal is still on (if not go to 10):
    a. Look carefully at the arrangement of the rubber at the lip of the drum and the door rim (you’ll need to know so you can put the new one on)
    b. The outer rim is sealed in by a circular wire linked by a small spring. It’s a bit tricky but you can unhook the spring from the wire (using a blunt knife to lever it out – careful not to damage the rubber) to remove it.
    c. The inner rim is sealed with a larger circular spring. You can either lever this out with the same blunt knife, or just pull ******* the rubber to get it out, and the rubber off.
    10. Now position the new rubber door seal between the drum and the door
    11. Grip tight around the outside and inside of the rubber door seal and attach it to the lip of the drum. This is the trickiest bit, and seems impossible but it is doable. The key here is that once you have a bit of it on, the rest will slip on as you work around it the circle. Even at the bottom and sides where your hands can’t reach it should slip on nicely. It ain’t easy, give it time.
    12. Now get the spring on the inner rim to seal it (again, not easy, give it time and muscle – you need 3 hands for this!)
    13. Then attach the outer rim to the lip of the door rim, and hook the metal wire back in place with the little spring.
    14. Put the panels and screws back in in the reverse order to how they came off/out. Make sure there’s no parts left over, ey!
    15. There you go – plug it back in and run a test wash. Check for leaks.
    I hope this helps. I took mine off our machine to clean it, couldn’t get it back on at first. Called TWO engineers, neither or whom could get it back on (and collected £50 each in call-out fees). Indesit would have charged £100 call-out fee. What a scam. Don’t believe the customer service people when they say it’s easy to replace.
Fantastic walk-through, thank you! These instructions also work for the Indesit WIA111
Getting the seal back on is tricky - if you feel you have to really force in back on (like a tyre on a bike) then you are probably doing it wrong.
I found once I had the knack it was best to stasrt again in the least accessible place
Posted on Oct 23, 2010
I have a indesit 90cm duel fuel cooker can some one tell me how to dimantle the oven door so i can clean in between the two pieces of glass
first you need to remove the door from the oven, Open the door fully and on the hinges you will see a little flap bit on each hinge, flip them over so they lock the hinges open.
Left the door up slightly and you will be able to remove the door.
Place the door on a soft surface handle side down and remove the screws around the edges, You will see how it is held together and be able to finish taking it apart.
When putting it back together make sure the insulating material and the rubber seals are located correctly.
Mar 06, 2012 | Indesit Kitchen Ranges
How to rid of mould on and underneath rubber seal by door as making washing smell musty,model is INDESIT IWME12, thanks
when coming across this problemn i just tell my customers to put the machine on its hottest wash with a capful of bleach instead of powder this works ok good luck.
Jun 07, 2011 | Indesit Washing Machines
I broke my rubber door seal loose on the passenger side in the icey weather today. what/how is the cheapest way to repair it? i am not using the remote, because that quit working a month ago after it ran...
Go to you local autoparts retailer you will need little tree clips that go into holes in the rubber seal and in turn push into holes in the door and you will need a tube of weather sealant glue.... Clean the rubber seal on the door and pull out the old tree clips ( tilt them on about a 45 degree angle to get them out don't tear the rubber) next put in the new tree clips you have bought following the same instructions on how you removed the old ones. Finally put sealant glue on the rubber where it contacts the door ( all the way around) and also on the door frame itself where the rubber will contact allow the glue to get tacky on door and rubber (Approx 10 mins) start at one end pushing the rubber back onto the door and inserting the tree clips as you go along when you get to the end viola your done! hope this helps
Jan 07, 2011 | 2003 Hyundai Tiburon
I have a Neff built-in dishwasher and sometimes there is a heavy leakage of water from the front right-hand side. The unit is 3-years old and there is a build up of scale around the rubber seals. The long...
Check the rubber seal in the bottom of the door has not perished or split,also check the bottom spray arm has not split on the ends as this will direct the spray directly onto the door,causing it to leak.
Hope this helps
Sep 19, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
Indesit w103 does not close at all, the door is broken, where can I find a spare part to change it?
Hi.
Go to ----WWW.4INDESIT.CO.UK/SPARES
You should be able to obtain the parts you require through this site.
Please leave feedback.
Thankyou.
Jan 06, 2010 | Indesit Washing Machines
Water leaks from a hole in the bottom of the drum. The hole looks as if it should be there
c. The inner rim is sealed with a larger circular spring. You can either lever this out with the same blunt knife, or just pull hard on the rubber to get it out, and the rubber off.
Oct 21, 2009 | Indesit WA 125 Front Load Washer
Zanussi fjr1454w door seal change.
with both clips,< locking rings > removed seal it is removable by just working it off the drum slowly,< there is overflow tube in front bottom side to disconnect also>. It is very important when installing new one that you put it in the same positiont as old one and lock rings go on same as well.
Apr 26, 2009 | Zanussi FJ1454W Front Load Washer
How to fit new door seal on Indesit W103 washing machine
this is not an easy job,go online and down load a copy of the machines manual even check out indesits web page.adrian
Feb 23, 2009 | Indesit W 123 Front Load Washer
Replace bottom door seal on Dishlex Global 300 Dishwasher - Model DX300SA
HI - i just replaced the bottom seal yesterday. The guy at the spares shop advised me to replace both (bottom of door and bigger seal ) at the same time to ensure no leaks - i did that. The bottom door seal come out when you unscrew the screws - (No need to remove door) and because of all the gunk (from years of washing and age of the rubber) i had to wedge a blunt knife in between (starting at one of the ends) and lever it out - MAKE SURE YOU TAKE NOTE OF THE WAY IT IS BEFORE YOU REMOVE IT! An easy way to remember is there is a nick in the rubber of the old (and new) seal and as it is not centred, just note if the nick is closer to the left or right of the machine, I have replaced mine and there is a little leak and now i wonder if i put the seal in upside down! it has to go in the same way - before you gimmy your's out can you tell me if the nick in the rubber is to the left or right? (LIZ at yodelayeeoo@gmail.com) If I have put in back right there is a chance the screw didn't go through the plastic part of the seal and therefore not holding it in place properly. GOOD LUCK! Don't worry about having to really work at getting the old seal out - you don't need it anymore and i didn't damage mine, regards, Liz
Jun 15, 2008 | Dishwashers
Washing Machines Logo
218 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
