Power supply problem
When I connect my dc power adapter to my computer, it does not charge the battery. The charging indication LED blinks twice and goes off and when I switch on the computer with the dc adapter connected, it runs on battery only.When the computer is switched on with the battery removed and adapter connected, it works in adapter supply. Adapter gives a constant output of 19V.
  • sohan378 Nov 12, 2008
    the powe light blinks in orange. wont start at all.
  • aclabo Mar 15, 2009
    mx6025 does not charge battery or run on ac power when adapter is connected - battery is new - adapter works for other computers - how do you repair/replace the dc power adapter??
    Genius:
  • 2,028 Answers
This is going to be with the power management system on the motherboard. These are the classic text book symptoms of a failed power management chip. Few shops will be able to fix this, most just say replace the motherboard, you might get lucky and find one in your area that can fix it, if not then you will need to send it to Acer for repair.
Posted on Jul 30, 2008
Flashing yellow light
attery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery c02983514.gif When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer.
Dec 20, 2013 | HP Pavilion ze4300 Notebook
Toshiba Laptop no longer charges battery
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Aug 07, 2012 | Toshiba Satellite L555DS7930 Notebook
Suddenly won't turn on no charge light indicator
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's power socket.If the power/battery LED light flashes and in a certain position this LED lightstays firm, then the power socket is either faulty or it has a dry solder jointwhere it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Jun 25, 2012 | ASUS G71G-A2 PC Notebook
My toshiba satellite l35 wont turn on,,,the light blinks then shuts off ,,,thats all it does
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
May 17, 2011 | Computers & Internet
I have a toughbook cf-19 and the charging lite keeps blinking red
You have a DC connector problem:
Jan 29, 2011 | Panasonic Computers & Internet
Yesterday my battery was indicating it was at 17%, so I plugged it in. Awhile later the "battery low" indicator came on screen so I realized it hadn't been charging. It still didn't charge if I...
Jan 27, 2011 | Panasonic Toughbook CF-51 Notebook
Computer is not charging the battery.
Your DC connector is probably loose from the system board:
Jan 05, 2011 | ASUS F8Sn-C1 PC Notebook
Charger blinking not charging, my orginal charger stopped working due to a damaged cord, I bought a replacement and all it does is blink on my computer while supposedly charging, after 4 hours, it is still...
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
Dec 09, 2009 | Toshiba Satellite A305D-S6848 Notebook
Power indicatoror
From the manual:
"Attach the barrel tip of the AC Charging Adapter to the AC Charging port of the POWER TO GO® and plug the standard two-prong plug into an appropriate, functioning 120 volt AC outlet. The red Battery Status LED indicator will flash, indicating a proper connection has been made and the unit is charging. The green Battery Status LED indicators will gradually light as the charge level rises. The POWER TO GO® must be charged for approximately 11-17 hours prior to first use. All Battery Status LED indicators will be lit solid (the red indicator will stop flashing) when the unit is fully charged.
Aug 29, 2008 | Black & Decker Power To Go Cordless AC/USB...
Discharging Battery
hmmm..try to run it with battery out completely, just from the power cord.
also, does the battery have one of those surface charge indicators, with the sliding scale?
also, plug the unit in overnight, off, and see if the adapter will charge the battery.
sometimes, you get voltage, but no current, and when the computer/battery come on line, the load will drop the adapter.
does the adapter light stay on, when connected to computer?
Feb 17, 2008 | Computers & Internet
Computers & Internet Logo
649 people viewed this question
David Payne
David Payne
