Question about Panasonic Computers & Internet
When using the VW-BN1 to burn a n AVCHD DVD, the write process is interupted and an erroe code: 203-E-0 is shown
I didn't Pay!!!!!
Posted on Jul 31, 2008
How to download avchd files
There are a ton of HD videos available online that you can download and convert to AVCHD videos so that you can burn them to regular DVDs and play them in a compatible Blu-ray player. For example, Vimeo has a large selection of sample AVCHD content. Both AVCHD's MTS and MP4 file formats support 720p, 1080i, and 1080p video resolutions. When downloading videos you should try to capture it at the highest resolution (1080p) possible. However, that said if your video player or TV only supports 720p resolution then that's the format you should select when downloading a video.
RealPlayer Plus does not recognize MTS files. When using RealPlayer Plus to burn HD video onto a regular DVD, look for HD content in the MP4 format like the Vimeo screenshot below. If the resolution you want is only available as an MTS file, you will need to convert the MTS to the MP4 format using third-party software in order to burn an AVCHD DVD with RealPlayer Plus.
For More Detail - http://www.real.com/resources/download-convert-avchd/
Aug 27, 2014 | SanDisk MobileMate SD Plus 5-in-1 Media...
Tip
How to burn AVCHD Lite to DVD on Mac OS X?
AVCHD-Lite, which is a subset of the AVCHD format popularized by hard disk camcorders from Sony, Panasonic, and Canon, uses h.264 video coupled with AAC audio for recording movies. AVCHD Lite video is currently used by Panasonic DMC-ZS3, Panasonic DMC-FZ3, Sony, Cannon AVCHD Lite Camcorder, etc.
26b78f7afa860b1f_2_197_.jpg The main differences between AVCHD Lite and the regular AVCHD: a maximum resolution of 1280 x 720p in AVCHD Lite compared to 1920 x 1080p in regular AVCHD and a less-intensive compression method - both of which make the format more suitable for less powerful camera hardware.
What you need to burn AVCHD Lite to DVD on Mac OS X?
Neither of AVCHD and AVCHD Lite video is directly supported by iMovie or iDVD on Mac OS(10.6.3 Snow Leopard included) if you want to burn AVCHD Lite to DVD. There are 3rd-party solutions that work with varying degrees of success in allowing you to work with AVCHD Lite video on Mac, like Daniusoft DVD Creator for Mac . It is DVD Burner that can convert AVCHD Lite video to DVD. With it, you can add DVD menu, edit videos and pictures, add transitions and effect, etc.
Below is the step by step guide on how to burn AVCHD to DVD on Mac OS X
Step 1. Load files Just click “+” button to import AVCHD Lite files to this program or simply drag and drop them to it. And rearrange the file list by using the up-down arrows.
Tips: You can freely drag and drop the thumbnail to merge or split the video files.
Step 2. Edit files (Optional) To personalize your DVD files, you can edit the video files by clicking “Edit” button. For video files, you can crop the frame size, trim into several clips, append effects, add picture/text watermark and rotate.
Step 3. Create DVD Menu (Optional) This Mac DVD Creator also allows you to create your own DVD menu with rich selections of DVD menu template. Simply click “Menu” button to select one and set the “Frame”, “Button” and “Text” to customize your DVD menu.
Step 4. Start to burn After all necessary settings, you need to insert a blank or rewritable disc to your Mac if you want to burn video files on DVD disc. Or you can simply convert the videos to DVD folder, .dvdmedia or ISO file on your Mac for later burning.
That is it! Within several clicks, you can burn AVCHD lite to DVD easily. So, why not download Daniusoft DVD Creator for Mac for a try?
on May 21, 2010 | Computers & Internet
Dmp-bd87p-k won't play avchd videos
Through simple steps, this professional AVCHD to DVD Converter gives you an easy way to convert AVCHD to DVD without video quality loss so as to burn AVCHD to DVD to play AVCHD on DVD Player.You find it at
http://www.avdshare.com/play-avchd-on-dvd-player
Aug 19, 2012 | Panasonic Televison & Video
Error code 203 when trying to burn 2nd backup dvd disc
I was having the same problem (gateway P-7805u), tried about 7 different DVD-R's for the second disc and got error 203 every time. As a last resort I tried switching to CD-R's for remainder of backup and it worked! Hope this works for others.
Jan 03, 2010 | Computers & Internet
Cannot burn AVCHD disk. Get this error
The problem with creator 2009 has been fixed by the roxio people.
Instead of burning directly to the DVD disk as roxio software states,
one needs to first save this to be AVCHD movie as a file and then burn directly from the file. This works OK, but as stated this is different
from what the software claims. I'm happy. Thanks
Aug 01, 2009 | Roxio Creator 2009 Ultimate for PC
Burned video disc does not play on home DVD player
Did you burn the disc as AVCHD or DVD...if avchd will only play on blu ray avchd compatible players or ps3 , If dvd should play fine
May 20, 2009 | Canon VIXIA HF100 Flash Media Camcorder
Did not burn dvd
The DW-100 burns files in the same format as they were originally recorded by your camcorder. The Canon Vixia HG-21 records in AVCHD--a high-definition format--which is completely different from standard-definition DVD and which is not compatible with regular DVD players (even though the disc itself is a standard DVD-R). As it states in the manual for the camcorder, "High-definition (AVCHD) discs created using the optional DW-100 DVD Burner can be played back only with AVCHD-compatible DVD players."
The DW-100 is really more for archiving your files in their native format than for creating standard DVDs that can be played on regular DVD players. Regular (standard-definition) DVD players can't play AVCHD, although many Blu-Ray players can. Unless you use a Blu-Ray player that supports AVCHD playback, there are two solutions to your problem:
1. If you want to keep your recordings high-def, you can view them by playing them back with the DW-100, which must be connected to your camcorder via the USB cable, then from your camcorder to your TV via an HDMI cable.
2. If you want to have standard DVDs that you can play on any DVD player, either import the files to your computer and convert them to standard-definition using video-editing software, then burn them to DVD with your computer's DVD burner, or connect the analog output (component=better, composite=good) to a stand-alone DVD recorder (i.e. not the DW-100).
I've used the route of Vixia HF-10 camcorder > composite output > Panasonic DMR-ES25S DVD recorder (about $65 used on eBay) with pretty good results when I've wanted to give videos to relatives who don't have Blu-Ray players. You just have to make sure to set the camcorder 's analog (composite) output to 480i so that it formats the picture in the right aspect ratio, or else the 16:9 image will be squeezed to 4:3 instead of letterboxed.
Hope this helps. Good luck.
Mar 19, 2009 | Canon DW 100 DVD-RW Burner
Canon DW-100
Thanks, I think it works that way. gl
Dec 08, 2008 | Canon DW 100 DVD-RW Burner
Dvd burn erros
hi yar i m kishore frm andhra predesh ,india
adobe premier rpro is better then vista movie maker
there is no problem in making videos.
we can give more effects in that.k try it.
ur's kishore chowdary.
else save the video file into hard disk then write into dvd by using
nero,alchol etc
ur's kishorechowdary
+919441133420
May 04, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
210 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
