Question about Minolta magicolor 2350 Laser Printer
Need help soon, with constant error
First - error message 08 - main motor, even after turned off for quite some time. Next - turned off AND unplugged. good news = no motor error message. Bad news = Paper jam Transfer. checked side and back interior could see no paper, but will not reset or print after turning off. What to do? Thanks, Karen
    Sergeant:
  • 183 Answers
You can find all trouble shooting ideas on following website:
ftp://ftp.minolta-qms.com/pub/cts/out_going/manuals/2530dl/user_e.pdf
Good luck
Posted on Feb 07, 2009
Model 2530DL - Fatal Error Code 08H - help!
Worcesterlad came up with this some time ago: it's not a solution but somewhere to investigate:
Error 08 relates to the main motor having problems turning. Quite often this is caused by a faulty consumable (opc,toner or transfer belt). Could also be that the lid is not closing properly and stopping the toner carousel turning freely
Jul 14, 2011 | Konica Minolta Magicolor 2530 DL Laser...
The washer is stopping midway through the load and an error codeLE what seems to be the problem
This is usually a communication error, unplug the machine for 20 minutes and then see if it returns when power is restored.
but if this does not helps then the actual reason of LE error code is as follows:--
LE LOCKED MOTOR ERROR
• The connector (3-pin, male, white) in the MOTOR HARNESS is not connected to the connector (3-pin, female, white) of STATOR ASSEMBLY.
• The electric contact between the connectors (3-pin, male, white) in the MOTOR HARNESS and 4-pin, female, white connector in the MAIN PWB ASSEMBLY is bad or unstable.
• The MOTOR HARNESS between the STATOR ASSEMBLY and MAIN PWB ASSEMBLY is cut (open circuited).
• The hall sensor is out of order/defective.
The hall sensor seems to be part of the motor.
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
Motor lock can be caused by several things from a loose connector, to a bad motor, or even the hall effect sensor failing or dislodging from it's mount. Any one or more of these components could have caused this error.
Dec 20, 2010 | Samsung WF337AA Front Load Washer
Estudio350 with error c010, checked the fuser, drum unit , dev unit, all are turning freely, error comes on as soon as fuser comes to full temp
Hi
Error C010 indicates main motor fault. Please check the main motor. If main motor not running under output test, then you'll need to replace it. If motor working, u might need change the LGC board. Take the drum unit out and check inside for any irregularties in drive system belts.
Hope this helps...
Daniel
Sep 30, 2010 | Toshiba E-Studio 3511 Color Copier
My drum on my washing machine is not spinning. And le error pops up
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jun 15, 2010 | LG WM-2277HW Front Load Washer
Washing mashin is writing error LE what does it mean?
May 06, 2010 | Samsung WF337AA Front Load Washer
WE are a very small non-profit and can't afford a tech to come in and fix it right now. I purchased a used Cannon NP 6030 and I made one copy fine. Then the error message ''E010 Turn copier off and then...
There are several things to try for the E10 error. E10 indicates " main motor lock, main motor rotation sensor,main board". It's a general fault which can be caused by
  • Dirty Corona wire
  • Dirty Drum
  • Dirty Optics on mirrors/glass
These would be the first things to try. After that, you're looking at a bad main board. Hope you find this answer to solve your problem.
Nov 16, 2009 | Office Equipment & Supplies
Hi :-) I also have P603 / Er09 / Er07 / 00-- Error messages, even after being unplugged overnight. Upon power application the unit clicks quite loudly 10 times in a row, then repeats this 4 times, before...
contact sagem 0835 0900316 technical support helpline you will need serial number of your box and the model a new power adapter was all I needed and can now watch all the programmes i had on the disc and thought i had lost
helen april 2010
Oct 11, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
Samsung washing machine shows error "LE"
Jun 14, 2009 | Samsung WF203ANW Front Load Washer
Xerox 5760 Color Copier has fault 03-302 at start-up
Xerox 5350, 5352, 5760 Code Description 00-009, 030, 031, 032, 033 A door was opened while paper was being fed 00-047 Paper in duplex 00-1 Auditron 00-2 Diagnostic error 00-3 Faults error 00-4 Ric error 00-5 Job manager system error 00-6 LLM interface 00-7 Standby error 00-8 Communications error 00-9 Xerographic error 01-300 Front interlock 01-310 Right upper interlock 01-315 Left upper interlock 01-320 Left lower interlock 01-325 Fuser interlock 02-910 Key counter missing 02-920 Wrong combination of accessories 03-302, 321, 322, 326, 327 LLM to ISIL communications problems 03-328 IOT communications problem with duplex or tray 4 03-330 IOT communications problems with HCF 03-335, 336 LLM communications problems with edit 03-340 NVM memory 03-341-347 Communications problems between IOT and sorter 03-350-354 Communications problem with LLM and user interface 03-363, 364 Communications problem between LLM & optics 03-370-03-373 Communications problem between LLM & DADF 03-380, 384 03-416-422 RAM memory problem 03-424, 426 NVM memory problem 03-430, 432 Billing problem 03-439 GRAIB communications problem 03-440 RIC communications problem 03-441 RIC NVM problem 03-442 Modem 03-443-458 RIC problems 03-460 Serial communications processor problem 04-300 Main motor or drive problem 05-100-108 DADF registration sensor 05-110 DADF exit sensor 05-115, 120 DADF jams 05-305 DADF document drive 05-310, 312 DADF document sensor 05-316 DADF registration sensor jam 05-325 DADF exit sensor 05-335, 341, 345 DADF interlock switches 06-300-310 Scan problems 06-315 Scan drive 06-320A, 320B, 320C, 325 Scan problem 06-330 Lens drive 06-340 Exposure control problem 06-342 LLM CPU problem 06-344-350 Exposure cvontrol problem 06-352 IOT CPU problem 07-300, 315, 330, 345 Tray faults 07-360-370 HCF problems 07-375, 380A, 380B Duplex problems 08-100-110 Feed problems. Lead edge of copy paper is late getting to feed sensor of tray 1 08-115-162 Feed problem. Lead edge of copy paper is late getting to registration sensor 08-165 Paper jam at registration sensor 08-310-370 Paper at a sensor when power is turned on 08-330 DADF nudger sensor 08-380 Registration side to side problem with home position 08-390 Nip 09-300 Copy cartridge finished (drum unit) 09-310 Add black toner Add color toner 09-320 Add color toner 09-330 Wrong copy cartridge (wrong drum unit) 09-340 Drum cartridge not installed properly 09-350 Waste toner full 100 A fault has occurred 10-100 Exit jam 10-105 Exit jam 10-110 Vertical sensor jam 10-120, 122, 125 Duplex jam 10-150, 155 Too much or not enough paper in duplex tray 10-300 Fuser thermistor 10-302 Low fuser temperature 10-304 Bad fuser temp 10-308 High fuser temperature or open thermistor 10-310 High fuser temperature 10-312 Fuser not up to temperature after energy save 10-314 Fuser problem 10-320 Fuser web finished 10-330, 335, 340 Exit switch, vertical sensor switch actuated when power is turned on 11-100-116 Sorter jam 11-150-176 Sorter auto stapler jam 11-310, 314, 316 Sorter interlock 11-325A,B,C,D,E,F,G Sorter index 11-352, 354, 356 Sorter auto stapler interlocks 11-365A,B,C,D,E Sorter auto stapler bin 11-370,371,372A,373A,373B,374 Sorter auto stapler staple failure, staple home problem or tamper home problem 11-385A,385B,390A,B,C,D,E,396A Sorter auto stapler staple failure, staple home problem or tamper home problem 301 Fuser web must be replaced 302 Copy cartridge (drum unit) must be replaced 501 Tray 1 must be rebuilt 502 Tray 2 must be rebuilt 503 Tray 3 must be rebuilt 504 Tray 4 must be rebuilt 505 HCF must be rebuilt 506 Bypass must be rebuilt 507 Duplex unit must be rebuilt 508 Replace black developer 509 Replace red developer 510 Replace green developer 512 Replace brown developer 513 Copy cartridge (drum unit) will need replacing soon 514 Fuser web will need replacing soon 515 DADF belt should be replaced 516 DADF feed rollers should be replaced 517 Replace exposure lamp 518 Replace suction filter 519 Replace ozone filter 520 Replace optics filter 521 Replace particle filter 522 Replace upper fuser roller 523 Replace fuser pawls 524 Replace pressure roller 525 Replace pressure roller pawls 900-905 Key operator calls
Jan 16, 2009 | Office Equipment & Supplies
Need help!!!!!!!!!!!
A previously released Madden NFL 08 update for the PLAYSTATION 3 was causing an error code (80010009) to appear and prevent online game play.
There has been a fix published by Electronic Arts (EA) on this problem.
This has now been resolved, but if you already downloaded the update, you will need to remove it before the game will work.
Please follow the steps provided by Electronic Arts below.
If you have encountered an '80010009' error message after downloading the most recent Madden NFL 08 update, please perform the following steps listed below:
  1. Press the PS button on the controller and select QUIT.
  2. In the main screen of the XMBTM user interface, select Game.
  3. Highlight the Game Data Utility folder and press the X button.
  4. Highlight the Madden NFL 08 file and press the Triangle button.
  5. Delete the file.
  6. Restart the game.
This will allow you to launch and play Madden NFL 08.
Dec 13, 2007 | Sony PlayStation 2 (PS2) Console
Minolta magicolor 2350 Laser Printer Logo
171 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
