Question about Jenn-Air PRG3601P Gas Kitchen Range
Oven not working
On 8/24/7 went to preheat oven, notice that display kept blinking on and off along with a clicking noise, oven did eventually heat up it took it awhile. as of 8/26 oven does not work at all timer display is just blank.But the top of the stove top works just fine. called GE they said that it probally need resetting or the breaker or fuse has tripped. unplugged for awhile, still got same problem. checked the breaker it's ok. please help turn on oven does not come on . THE BOTTOM OF OVEN IS JUST WARM. I smell gas.
  • 54 Answers
Http://www.geappliances.com/search/fast/infobase/10002629.htm Follow the driections here to see if they work I had the same problem and this fixed mine.
Posted on Jul 30, 2008
Top oven doesn't heat properly
What is the model number of the unit?
Dec 03, 2012 | Ovens
My Dimension4's convection oven often starts to make grinding noises when it preheats.
From the description it is the turnable motor, eventually it will need to be replaced down the road.
Mar 22, 2012 | Microwave Ovens
I noticed my oven was taking longer and longer to reach the preheat temperatures I was setting. As time went on, the stove was not heating up past 285 and now the temperature never increases but I can...
It is probably as simple as changing the ignitor...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Aug 16, 2010 | Maytag MGR5770 Gas Kitchen Range
Thermador Pro Harmony Range--> Blue Lights Blinking
thermador rang, blue light blinking. Oven is not working,
Oct 03, 2009 | Thermador Pro Harmony PRG304EH (Gas)...
My oven display is beeping and blinking 'PBR' on the display. What does that mean?
I had this same problem last night.. I have been having problems with the oven shutting off on preheat.. That sort of stopped. Last night lost power to the house. When it returned the oven was beeping and flashing PBR. I turned off the breaker for a few mins. last night and it returned. It was bugging me so much that turned it off the whole night. Woke up this morning turned the breaker back on and it stopped. I don't think this is the total solution. I am thinking that eventually I am going to have to replace power board in this oven. Hope it works!
Sep 23, 2009 | Jenn-Air Ovens
Oven not heating KitchenAid KERC506HWH3
This is probably the thermal shuttoff fuse. Usualy mounted in the back of the oven. Aftermarket fuses are resetable but the OEM ones that come with the ovens usualy are not, so when they go out they stay out. This shuttoff only effects the power to the element so the rest of the oven appears to work.
The oven has to come out and remove the rear covers, behind the covers you will see 2 wires that go to a small 1/2 in dia "plug" that mounts directly to the surface with 2 screws.
Remove the connections and put a meter across the cuttout. it should read very close to zero ohms, if not its blown.
Apr 23, 2009 | Frigidaire FEB27T5D Electric Double Oven
Built-in ovens have a thermal fuse mounted in the back of the oven preventing the bake and broil from operating. In some cases this fuse will open after a self clean operation. In some models, the cooling fan turns off too soon, causing an overtemperature condition that may also cause the fuse to open. You will have to remove the oven and take off the back panel to gain access to this device.
May 25, 2008 | Frigidaire PLEB30T8A Electric Double Oven
Sharp Carousel Convection Microwave R-9H56 suddenly stops heating
at highvoltage section wiring may bae problem, check wiring and connectrors of magnetron and capacitor and transformer.
Dec 11, 2007 | Sharp R-510HW Microwave Oven
Oven not working
Gas Burner valves use a flame proving circuit to verify that a flame exist before releasing gas to the burners in the oven as a safety precaution, this sensor being exposed to temperature extremes, fails over time.
Aug 27, 2007 | Kitchen Ranges
if this cooker is fitted with a clock check that it is not set to delay start mode(auto) if it is reset clock and this will resolve problem
Jun 13, 2007 | KitchenAid KERC506HBS Electric Kitchen...
Jenn-Air PRG3601P Gas Kitchen Range Logo
262 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
