Speakers not working properly
I have recently reconnected the ADE-210C speakers but they are not working properly. They work for the test but will not work for any other programme. Can you help?
    Problem Solver:
  • 19 Answers
Try going to control panel, then click on the icon for sound , check and see if the properties for this are active if not you may need to set the parameters for the speakers to work correctly
Posted on Aug 01, 2008
Our rear speakers aren't working properly.
Well that proves the hardware works. Crack the manual for the unspecified model and see why the source selected or the sound mode selected don't utilize those speakers.
May 30, 2011 | LG Audio Players & Recorders
Speaker are not working properly
there's so much possible reason why its not working.
1. speakers might be in mute -try to un - mute it
2. speakers might be not connected properly - try to look for its connection and try to reconnect it.
3. speakers might not have installed drivers - try install the audio driver or update its driver.
Feb 25, 2011 | Sony VAIO (PCWA-A200)
No sound from my speakers
There is some loose connection. If its a sound card, try removing it from the slot, clean the contact ponits and replace. If the sound system has a separate amplifier, just touch the stereojack to see if the speakers produce a humming sound, which means the speaker circuit is OK. Now try twisting the jack to your PC and if there is cracling sound from the speakers then the audio output socket needs to cleaned with pure alcohol to remove any carbon deposits...........sodeep
May 05, 2009 | Audio Players & Recorders
Only right speaker working
disconnect all the cables and fix it again,then check the speaker sounds bychecking the sound settings in control pannel.
Aug 03, 2008 | HP JBL Platinum Computer Speakers
Got Advent speakers,Model ade-210f for pc pluged in to green port,speakers have been tested and work however not on my pc
please follow me double right click in speaker icon to open volume control check all faders are in up position-no mute box are checked.
press option select properties check(in playback)that boxes are checked.
Jul 07, 2008 | Audio Players & Recorders
Advent ADE 210C
There is no easy way to tell you this. The smaller speakers usually plug into the large speaker. The large speaker is the sub and has a power source for the other speakers.
I can't fix this for you, but if I helped you get it fixed, please rate it as a fixya not a helpful rating. These ratings let me be allowed to help you and others in the future.
Jun 02, 2008 | Audio Players & Recorders
Actual hardrive memory loss
I HAD NORMAL DESKTOP SPEAKERS
THEN CONNECTED BOSE BUT BOSE DID NOT WORK PROPERLY.THE SOUND WAS NOT CONTINOUS
SO RECONNECTED IT AND CONNECTED NORMAL SPEAKERS TO THE DESKTOP.BUT NOW NOTHING CAN BE HEARD IN NORMAL SPEAKERS ALSO.WHAT TO DO.
Feb 19, 2008 | Audio Players & Recorders
Problem with pioneer vsx-916 av receiver
Be sure you have proper impedance with both sets connected. Some units have a selector switch in the back of the receiver to set the proper bias. ...accordianman
Jan 21, 2008 | Pioneer VSX-915 Receiver
MS-900 (AOpen speakers)
please install motherboard cd in you pc then set the volume control option to windows default thats all..your speakers will get ready to work properly...
Dec 30, 2007 | AOpen MS-900 Computer Speakers
My speakers have stopped working.
Ok, I may have the solution. After I posted here I went back to trying to fix it myself and I did, well, mine anyways. I back to the control panel and went to Hardware/Sounds, clicked on the manage my audio devices again, and then where it said "no audio devices installed", nothing there, I right clicked my mouse and it brought up a little box that said: Show disconnected devices and Show disabled devices, make sure both of these are checked...that was my problem why i kept showing nothing. Then hopefully your spears icon shoud reappear like mine, and you can then click on it, then properties, and ENABLE it...hope this helps, let me know :)
Nov 11, 2007 | Audio Players & Recorders
134 people viewed this question
 Grubhead
Grubhead
