Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Hoover U5465-900 Power Cord Replacement
Hey guys,
I am mechanically/electrically inclined so a power cord replacement for this unit seemed to be a pretty straightforward job. I just rec'd the replacement cord, viola! Head meet wall! The cord goes into the back of the upright portion of the unit and I have removed every screw that appears to man (including looking behind the light housing assembly) and no go on entry. I do not want to start prying as I obviously may damage something. I have been looking online for service manuals for this 10 year old vacuum, but all I find is the owners manuals whose only use at this point would be for bird cage liner.
The vacuum works great, just the cord is worn/exposed and been pulled too tight (and therefor the jacket is no longer captured, the wires are exposed) too many times for it to be safely used.
  • 1 more comment
  • jp5472 Jul 30, 2008
    Been there, done that about an hour before giving up and posting here. No manual returned for this model....and even so, all they seem to offer is the Owners Manual for anything which IS NOT the Service Manual.
    I am getting truly off the wall responses -
    A) to my first response: Of course I immediately checked the Hoover site for a service manual.
    B) Second response: There is not a power short (where that came from is beyond me) - the current cord and the unit work just fine, its the fact that the jacket on the cord has been ridden over many times in ten years therefore making it dangerously worn and anyone with an ounce of safety in mind would want to replace a cord in that condition.
    MY PROBLEM IS THIS SPECIFICALLY:
    As others have posted on here for this same model: I need to get this housing open to replace the cord internally. I have removed EVERY external screw around the housing and it WILL NOT SEPARATE! Before I go prying with a spatula and damage something, IS THERE ANYONE OUT THERE WHO KNOWS HOOVER UPRIGHTS AND KNOWS HOW THIS UNIT COMES APART?
    Thanks, this is what I needed..an exploded mechanical view. Now I can see for sure where parts separate. I appreciate your help.
  • 2,323 Answers
Click here to see an exploded view of your vacuum.
Posted on Jul 30, 2008
    Genius:
  • 1,665 Answers
    Guru:
  • 1,894 Answers
I think there is some serious damage with your power circuit.
you will need to double check where power enters the unit.
that is where the problem lies.
problem can be of any kind like a shorting of the circuit or any bad component.
  • dewan nafees ahmed Jul 30, 2008
    well then you can get a service manual only if you are going to pay for the manual.
    and there are places in net where you get a manual by paying them. but lot of them are scams. so be careful.
    Master:
  • 382 Answers
Please checck out the following link for finding the manual of ur device!!...Im sure you can find a manual there!..
http://www.hoover.com/CustomerService/Manuals/Default.aspx
Please post back for how things turned or for further assistance..Thank you!!...
Regards!!!...
  • Natesan Sabesan
    Natesan Sabesan Jul 30, 2008
    Well i couldnt find any Service manual for your model Free on the net..IF you are willing to pay for Service manual I can help you with it..Also There are some phillips screws on the bottom that allow access to the belt... Under that Is the Power Cord Connection Lies and that is where you need to go For connecting the Replacement Cord!!.....
  • Natesan Sabesan
    Check The following link ...This is the DISASSEMBLY procedure for your model!!...Hope it helps you!!!
    http://www.elkypro.com/hoops2005/vacuum_...
Replace power cord on Hoover windtunnel vacumm
There are many different models of Hoover Windtunnel so I can't be specific to your model, you will need to determine where the cord enters the unit and how to gain access to the internal wiring. Disconnect the old cord and attach the new cord using the proper connectors.
Apr 02, 2017 | Hoover Vacuums
How to replace a power cord for a hoover vacuum?
Please add the specific model number, for example, Hoover vacuum, ECOVAC 497A.
Is this a wrap up power cord where you wrap it around two lugs on the vacuum, or is it a rewind type where the cord is wound inside the body of the vacuum?
Cheers.
Aug 15, 2014 | Vacuums
It started to spark at the cbale in the handle - seems to be a fixed unit, can it be fixed? hoover still works great, woeld be waste to have buy new one, thanks
You can remove the entire handle and cable by unlocking the handle at the bottom above the main dust bin. There should be a lock with an arrow on it, like a rectangle which you pull upwards - this will unlock the handle with the cable. Or there may be a twist lock dependent on the vacuum you have. Replacement handles with cords are available to buy online but if you are good at wire/electrical wire replacement, you can follow online videos on how to replace the original power cord.
Sep 06, 2013 | Sebo Vacuums
How do you change the power cord on the Hoover u5475-900 Wind Tunnel 6200? Thanks for your help.
This procedure worked for replacing the cord on my Hoover U6425-900. At a minimum, you will need a number 2 Phillips screwdriver, wire cutter, and two electrical wire nuts and electrical tape. Remove the accessory tools from the storage compartment. Remove two screws, these are recessed. Remove the cover from the bag compartment, remove two screws located at top corners of bag compartment. You may have to open the side filter door but the accessory tool storage compartment should be free at this point and can be removed. You should see the power cord and related wiring. If you have a digital camera you could take a photo at this point in case you need a point of reference. Make note of the power cord strain relief routing and length of wire. Too much wire will make reattaching the storage compartment difficult and the routing prevents the cord from being pulled out.
On my model the wiring colors were purple, orange and white. My replacement cord had black and white wires. The orange wire will not be involved in cord replacement. Using the wire cutters clip the purple wire about three inches back from the existing terminal. If present, clip the two nylon wire ties and discard. The white wire will have a crimped on wire connector. Clip the white wire about three inches back from the existing wire connector. The old power cord can be removed by pulling it out from the rear, it should just slide out of the rubber insulating boot. If not use a set of pliers and crimp the boot from the wiring side and push it outside the vacuum housing. If you have to do this make sure you slip the boot over the replacement cord before you insert the new cord back into the vacuum housing. Remove about a half inch of insulation from the purple and white wires and from your replacement cord unless it was supplied with insulation already removed. Use new wire nuts and connect the white wires. Use the other wire nut and connect the purple wire to the remaining new power cord wire. Use some electrical tape and wrap the nuts to the wires a couple of times so they won't loosen. Make sure you route the power cord around the posts as this is the strain relief and prevents the cord from being pulled out. Reassemble and test.
Feb 03, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover UH70120 WindTunnel TSeries problems with the cord. im a tech savy guy and have been trying to fix a cord after it was pulled to far out and now wont auto retract, but just cant find a way to pull...
You will probably have to replace the cord winding mechanism. I have never had any luck trying to repair one. Cord retracters are great when they work but it seems like they always go bad before too long. On many units you can't even replace the cord if you get a bad spot in it, you have to buy a new cord reel which can get expensive.
Jul 21, 2010 | Hoover UH70120 WindTunnel TSeries Rewind...
How to replace Hoover PowerMAX power nozzle cord?
You can get the new cord at your local vac shop or you can take the power nozzle to the shop and have it repaired
Apr 27, 2017 | Hoover Powermax S3601 Bagged Canister...
Automatic Cord Rewinder is not rewinding anymore
I had the same problem - the power cord for my Hoover Elite Upright (U5507900) was stuck a few inches out and wouldn't go any further. But when I unscrewed the rewinding mechanism, the cord had clearly gotten twisted and partly buried under itself so after some work I was able to free it. Now it seems to be working fine, at least for the moment. Note that I had to use small screwdrivers to unscrew the cord rewinding compartment, like the kind of screwdrivers you use for computer repair.
HTH!
May 27, 2009 | Hoover Elite Rewind Bagless Upright...
How to replace power cord on Hoover WindTunnel upright vacuum
The aforementioned solutions probably never even attempted this fix on this model. The handle does NOT need to come off. but the 5 screws on the front housing DO: 2 above the light and 3 below it. Then to get the colored housing off you need to access 2 screws on the underside that are beneath the agitator roller. To do that, obviously the 4 screws holding the bottom plate need to come off too. Here's a link to a schematic that might help as you attempt to do this, (assuming that you still do!) http://www.elkypro.com/hoops2005/vacuum_parts/hoover/U5461-900.html
Once you have the main body housing cover off, then you can access the 2 screws atop of each trunnion cover that holds the motor assembly cover halves together. If you've made it this far, then gently pry apart the motor halves keeping even as yo do. Now you can see all the wiring necessary to cut and splice. Happy cord replacing! As for me, I am headed for the store, as I am not so sure I can remember how to get the darn thing put back together. But it was fun taking it apart!
Apr 15, 2008 | Hoover U6616-900 WindTunnel Bagless...
Replacing a fraayed and twisted power cord on a Hoover windtunnel upright
ok so I took this vaccum apart completely except for the electrical and motor systems. It seems to me that without dismantling both of these systems on the vaccum you can't replace the power cord. And I wouldn't recommend taking them apart unless you know what you are doing since replacing the power cord seems to require cutting the old power cord and soldering the new one onto the old terminals. All in all its probably easier to get a new vaccum altogether.
Dec 13, 2007 | Hoover U6616-900 WindTunnel Bagless...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
438 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
