Crate px-600dp amp
Need output locations identified and cross for transistors
  • rdstuff02 Jul 31, 2008
    I know the transistors are tip-142;147's which cross to NTE 270;271 power Bipolar NPN & PNP
    respectivly what I need to know is Q8 is one or the other ect!!!
2 Suggested Answers
  • 7 Answers
SOURCE: Studiomaster 900E power transitors
read through this thread and you should be able to get a schematic
http://www.diyaudio.com/forums/showthread.php?threadid=140776
Posted on Jun 17, 2009
Need a manual for crate px-600dlx
Try Googling (crate)(px-600dlx)(manual) without parens.
Jan 13, 2018 | Crate Music
Left speakers do not work
As power amps are just two amps joined together all you need do is identify the left channel and compare it with the right. Ignore any parts common to both channels. The first thing to do is a visual check. If something looks broken burnt, or odd compared with the right channel then you have probably found the culprit. I suspect you could have a power output failure. It might be that the output devices are separate transistors. They might need to be replaced.
By the way just follow either the internal speaker leads or the connections to locate the right and left channels.
Nov 10, 2017 | Yamaha HTR-6130 Receiver
Where is the serial number on a crate amplifier
Real basic owners manual is here:
http://www.crateamps.com/pdf/manuals/CA6110DG_OM.pdf
Look at the chassis, or pull a part number off the original speaker to match speaker and back cross reference to the amp versions that used it. The OM is at least good enough with the block diagram to allow it to be serviced easily enough.
Feb 21, 2012 | Crate CA6110DG Gunnison Acoustic Guitar...
Flexwave 120H Speaker wire shorted amp won't work
Solid state amps are very subject to blowing out the output transistors if speaker leads get shorted. Take it in for repair.
Aug 31, 2011 | Crate FlexWave FW120H Guitar Amp Head with...
I am attempting to repair a Kustom K100A-1 guitar amp. I found one shorted output transistor, an RCA 36892, which crosses with a NTE 130. Do I need to replace all 5 outputs with matched transistors, or can...
I don't have a schematic for this unit, however good design would not demand matched transistors.
If a transistor has shorted, USUALLY mating transistors have been damaged. I am not sure how "5" outputs are configured as usually there is symetry and an even number. If the "5" are all on one side and there are mating trnsistors of another number, then likely there is damage to more components and probably back one stage in the drivers or even farther.
Hint: when re-powering this after repair, put a 100 Watt light bulb in series with the power into the unit to act as a limiting fuse that resets without driving heavy current into the unit causing more damage due to failed parts that were not eliminated in the first reapir.
Jan 06, 2011 | Music
I have a Crate GT 15, not getting anything to the speaker when I plug in.
Do you have electronics experience? Inspect the amp for broken or cold solder joints and any burned components. Check to see if the fuse blew and that the output IC's or transistors (not sure what Crate used in these) are not bad. Check your speaker wire as well.
Jan 15, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Does anyone have the voltage specs on a PNT-426 Power Supply. It is for my NEC PlasmaSync PX-42VM5A Monitor. My electrician has found a faulty diode but doesn't have the voltage specs on it. I have a...
I have a PX-42VM5A and my Power supply is a PNT-426 (by Sanken Electric Co. LDT). Here are my specs: INPUT: AC 100-240V; OUTPUT: (there are nine outputs) +170v 1.6A; +60v 1.6A; +5v 4.0A; +2.5v 1.9A; +3.5v 1.9A; +7v 1.0A; +12v 0.5A; +12 v 1.9A and +6v 1.2A
Jun 17, 2009 | NEC PlasmaSync 42VP4D 42 in. HD-Ready...
Amp works but DC comes out of one speaker output
To get the clamps off click HERE.
There may be several bad components. Normally, shorted outputs (the most likely cause of DC on the outputs) causes the amp to go into protect mode. In your amp, you may have shorted output transistors, open emitter resistors and possibly a problem with the protection circuit.
To get up to speed on the basics, read through the following page:
Amplifier Repair Primer
After you read through that page, remove the clamps and check all of the output transistors to determine if any are shorted.
Let me know what you find.
Oct 04, 2008 | Power Acoustik GOTHIC OV2-520 Car Audio...
Bose SA-3 Amp / Blown Fuse
The problem is not the transformer. You now have shorted output transistors at the very least. By corssing the wires you presented a zero(0) ohm impedence load to the output section. It quickly went into overload. Before the fuses had a chance to open up, the outputs fried. This unit will require new output transistors and perhaps the previous driver circuit will require parts as well. Figure on $20-$50 in parts plus hte local labor rate for the repair.
Dan
Sep 25, 2008 | Bose Lifestyle SA-3 2-Channel Amplifier
336 people viewed this question
 Grubhead
Grubhead
