Question about Saeco Talea Giro Espresso Machine
Temperature of the coffee?
Is there a way to increase the temperature of the coffee?
    Problem Solver:
  • 5 Answers
Heat the cups with hot water and keep them full of water until you are ready to pour the coffee. Put the milk in first and then the hot milk you have frothed. The coffee stays hot till the last sip
Posted on Jun 28, 2009
  • 515 Answers
Not what i know on Talea and Odea, but on Primea can you do it.
Posted on Jul 30, 2008
Temperature is low even when machine is set high
warranty? Owner's manual? troubleshooting section? Last of all, MFG customer service is usually helpful if you're nice about it.
Mar 05, 2015 | Coffee Makers & Espresso Machines
Heating not working
The factory temperature setting is low so that they can advertise the machine as 'low energy'. You can increase the temperature by pressing a series of buttons when the machine is in standby. Go to Instruction Manuals to read the required setting.
Oct 09, 2014 | DeLonghi Coffee Makers & Espresso Machines
Coffee brewing very weak
possible ways to remedy this problem:
problem of weak beverage
solutions:
1. Filter Type-BUNN paper filters must be used
for proper extraction.
2. Coffee Grind-A fine or drip grind must be used
3. Sprayhead-A six-hole stainless steel spray-
head must be used for proper
extraction.
4. Funnel Loading-The BUNN paper filter must be centered in the funnel and the bed of ground leveled by gentle shaking.
5. Water Temperature- Place an empty funnel on an empty
dispenser beneath the sprayhead. Initiate a brew cycle and check the
water temperature immediately below the sprayhead with a ther-
mometer. The reading should not be less than 195F (91C). Adjust
the control thermostat to increase the water temperature. Replace if necessary.
Apr 11, 2013 | Bunn 392 Pourover Coffee Maker With 2...
How do I increase water temperature on Krups KP 2100
Heat the cup before you use it, run hot water over it, or boiling water. The machine does not make very hot coffee otherwise.
Sep 22, 2012 | Krups Dolce Gusto KP 2100 Espresso Machine
DeLonghi Magnifica 3200 how to increase coffee temperature?
Evening to you
Not hot enough, do you leave it to stand with the green lights on?
By my experience the machine is best left on so everything is hot when the water passes through.
To let some time pass before you make the next cup.
And lasly to make sure that machine is clean.
Good luck
kolbrun
Mar 05, 2012 | Faberware FSCM100 Coffee and Espresso...
How to increase temperature on model BCM120. The coffee is not hot enough after brewing. Is it possible to increase the temperature on the thermostat.
There is no temperature adjustment for the heating element under the carafe.
The Instruction Manual says:
If coffee is too cold, machine not preheated, cups not preheated, milk not heated enough (if making a cappuccino or latté)
Jun 12, 2011 | Breville Coffee Makers & Espresso Machines
We need to increase the hot water temperature, how
Depending on the model, if using a manual knob for the tea valve(same kind of setup as the steam) then you will have to turn up the p.stat. If it has an electronic button then remove the front top panel and look on the side of the solenoid you will notice a knob attached to another solenoid called an economiser valve, there should be a plus and minus sign on the knob. Reducing the amount of cold water being mixed with the hot water will increase the temperature.
Jan 25, 2010 | Astoria Divina SAE-1 Espresso Machine
Adjusting temperature for bunn cwtf twin
Look for the black knob with the arrow and it might have a red paper tag attached, turn clockwise all the way, then back about 1/4 of an inch.
Jun 17, 2009 | Bunn VPR Coffee Maker
Adjusting the temperature
Our Bunn VPR was delivering luke warm coffee. The problem was lime scale buildup on the heating element. I recommend using a cleaner such as Brew Rite or a vinegar solution. If it still does not heat properly, unplug and remove the heating element for cleaning. This corrected our problem.
Coffee Temperature
Hi , if you could open the below cover check the heating sensor might lose connection / if their is possibility to unscrew the sensor try to applied heat sink grease available in appliances repair shop , make clearance to boiling tank thick two papers in applying sink grease,same in warming surface.
Jan 21, 2008 | DeLonghi DCR902T Coffee Maker
Saeco Talea Giro Espresso Machine Logo
354 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
