No Desk top while system get booted
Hi all,
This is raghavendra from India, I am working as sys admin i have faced this kind of problem at my office laptop.What is the possible cause for it, also do let me know the resolvinng factor.
  • yashan.co.in May 11, 2010
    hi raghavendra,
    first i wanna know after welcome screen you get nothing on your desktop no any icon on that no bg image right.plz clear this confuses.
    Novelist:
  • 202 Answers
Just right click on u r desktop and got to arrange icons by option in that tick show desktop icons it will show u r icons
this solution is apllied for WIN200,WINXP,WIN2003 etc
Posted on Jul 30, 2008
In my office facebook is blocked . how to unblock it
almost certainly this is a sys admin issue at your work not likely to unblock your fb account for any reason
May 25, 2012 | Facebook Computers & Internet
Says its missing bootmgr
kindly specify the operating system....i am giving solution for vista boot manager missing: copy c:\boot\bcd c:\boot\bcd_backup c: d:\boot\bootsect.exe -NT60 SYS c: /force
Reboot Run the Vista Boot CD. Click on the startup recovery option at the top. Reboot.
Aug 31, 2011 | HEWLETT-PACKARD HP Mini Glossy Black...
Hi We're using Kyocera Mita KM-2560. Unfortunately someone in our office was able to change login settings through device internal web interface. When I turn on the machine it asks username and password....
try Admin on both username and password ( A caps).
Also try 3000 on both or 6000 on both. try to select the system menu button and type the username and password there.
Jul 20, 2017 | Kyocera Office Equipment & Supplies
Dv6700 boot up problem. power light on. When power on is pressed, the lights in top panel flash once then nothing happens. does not boot. Tried removing battery, reseating RAM nothing worked
Try taking the sys to the BIOS screen and set the defaults after that if the sys doesnt boot up do a system restore by going into the recovery manager page from F11 key on startup to a date when the sys was working fine. IF that doesnt work try enabling the low resolution mode from the advanced boot options from F8. If this doesnt work out than finally you will have to run recovery on the sys.
All the best
Feb 09, 2010 | HP Pavilion dv9000z Notebook
No manual for 320 GB desk top hard drive
its a plug and play just connect to the sys and start working on it
but be careful that u connect the power to the Ext.HDD first and then after that connect it to the USB port
similarly safe remove from the Sys and remove it only after u see the msg It is safe to remove the USB drive disconnect the USB cable from the Sys wait for 20-30 secs ten power off the HDD for better performence of the Ext HDD
Jul 27, 2009 | Electronics - Others
Changing the main answer message
Hi Cindy,
a couple of requirements here;
1~ you need to know the VM huntgroup number ie; number dialled to access the voicemail system
2~ the administrator mailbox number usually, 999 or 9999 by default
3~ the admin vm pin code which is usually 8642 by default
basic menu selection;
4 change system gereetings
1 change primary greetings
the system will supply voice prompts to allow you to change system greetings,
The superkey is the Blue key on the top left of the set
4 sys gereetings
1 pri greeting
if you are trying to change AA greetings follow the above just change the VM box number to the one associated with the Auto attendant alternativly you can configure the greeting from the System administration tool under the following ;
Sys Administration menu -> Voice Mail -> System audio files Update
select the AA greeting and greeting type
Feb 02, 2009 | Mitel 5220 IP Phone
Service Center
For all HP and Compaq home and office peripherals, pls try:
Redington India Ltd
C/O SS Enterprises, 79,H.G.B.Road,
Melarmath, Agartala, West Tripura
Agartala 799001
Tripura
Contact Nos: 0381 2309849
Email: agtmotorola@rediffmail.com;servagartala@gmail.com
Redington India Ltd
C/O S.M infotech,HG Basak Road, Swasti bazar,
First Floor,
Agartala 799001
Tripura
Contact Nos: 2386070(0381)
Email: serveagartala@gmail.com
Alternately, you can also checkout this page.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 13, 2008 | Compaq Presario 700 470024-192 Notebook
Password is no longer working
What type of system is the phone on? IP Office?
Who has access to the system admin? You are talking about your hot desk logon and your voicemail logon?
Dec 28, 2007 | Avaya 5400 Series 5410 Phone
DI 524 Router Not able to connect to office VPN on Wireless
I have the same model router at home, just checked the settings, you should be able to pass through the router with a normal vpn connection.
If you use a special VPN client, like a CheckPoint Secure VPN client, the router might block it. Also you might want to ask your office's sys admin if you are not blocked by the firewall or something similar. Your office's sys admin will prolly solve your problem since he knows your work network's configuration and setup and how to connect to it.
Nov 08, 2007 | D-Link AirPlus DI-524 Wireless Router
Desk top won't display-hibernation mode
Based on your post of failure to boot due to hibernation, you can try removing the battery and AC adapter connection for an hour or so. Thereafter, insert battery back and charge but don't power up. Allow the laptop to charge for a couple of hours. Try powering up/booting. Press F8 to start in Safe Mode. Once in Safe Mode disable Hibernation.
If the laptop still fails to power up, then it may be entirely another problem.
Post back results. Good luck and kind regards.
Nov 04, 2007 | HP Pavilion dv4000 Notebook
Computers & Internet Logo
David Payne
David Payne
