Transmission control module
I have a '97 chrys. concorde, just got a P0700 code which idicates,
transaxle control system fault. Transaxle control module has a fault.
Also the PCM detected an incorrect gear ratio condition in 3rd gear.
Can I replace this module easily, or does it take a tech to rebuild?
  • Anonymous May 05, 2009
    Please describe the specifics of your problem below. We'll add your post as a comment to littlezappa5's "transmission control module" problem, and notify you when a new solution is offered.
You want me to PAY to get the answer from you.... yet if I fixed it, you want me to tell you how I did it for free so you can charge people for my knowledge????
What a scam.
Posted on Jul 31, 2008
TROUBLE CODES 605 AND 700
Is this P0605 and P0700? If so read on.
P0605 - Control Module Fault
Possible causes- ECM/PCM Harness power supply circuit is open or shorted
- ECM/PCM Harness ground supply circuit is open or shorted
- ECM/PCM may be faulty
P0700 CHRYSLER - Transaxle Control System (TCM) Malfunction
Possible causes- Shorted or open circuit within transmission control module (TCM)
- Failure of transaxle control module
Tech notes Since the P0700 is just and informative code, check the TCM for more codes to resolve the problem
Sep 12, 2012 | 2001 Chrysler Concorde
Error code 0700 aa1 aa2
Hi there:
The DTC P0700 is a Information Code The Transaxle Control Module (TCM) that monitors the malfunction of sensors and actuators relating to transaxle control. If any malfunction is detected, the TCM informs the PCM by sending a signal (P0700 code). P0700 means that a code has been set in the TCM.
This code is for information ONLY. If this code is present, check for transaxle codes. So basically, the P0700 code is telling you to check the TCM for a transaxle DTC. The TCM can not turn on the check engine light so it has the PCM do it, which can only be done with a diagnostic scanner. The self retreival method for chryslers with the ignition key will not pull up the specific transmission fault codes in the TCM.
Hope this helps.
Mar 30, 2012 | 2001 Chrysler Town & Country
Transmision codes p0700 and p2706 dodge durango 04
Both codes (obviously) point to transmission related problems.
DTC P0700 - Transaxle Control System Fault Conditions
The P0700 code is for information only and the next step is to check for transaxle codes in the Transaxle Control Module (TCM). So you'll have to have the dealer or another qualified shop/technician pull the transaxle codes from the TCM and go from there.
DTC P2706 - Shift Solenoid "F"
First check your wiring before you get inside and open the ****** up. Could be loose wiring, if not do the operation and make sure you do a heat test with the solenoid before you replace it.
Hope this helps and just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa.
Nov 01, 2011 | 2004 Dodge Durango
I have a 2011 dodge caliber and it isz throw a c0700 code could u tell me what this is
P0700 DODGE - Transaxle Control System Malfunction
Symptoms - Engine Light ON (or Service Engine Soon Warning Light)
- Driveability problems
- Transaxle shifting problems
Possible causes - Shorted or open circuit within transmission control module (TCM)
Tech notes Since the P0700 is just and informative code, check the TCM for more codes to resolve the problem.
P0700 DODGE Description The transaxle Control Module (TCM) monitors the malfunction of sensors and actuators relating to transaxle control. When the TCM detects a malfunction with the control, a signal is send to the Engine Control Module (ECM) to trigger the Engine Light or Service Engine Soon light. The ECM stores the P0700 code and it means the TCM detected a malfunction with the transaxle controls.
CLEAR THE CODES AND SEE IF IT RESETS. MOST LIKELY NOT A PROBLEM
Sep 07, 2011 | 2002 Dodge Grand Caravan
What do i need to replace to fix error code p0700 on a 2002 dodge intrepid
(DTC) CODE # P0700....Transmission Control System (MIL Request) Translation: Transmission Control Module (TCM) Malfunction or Failure. P0700 Information Code The Transaxle Control Module (TCM) monitors the malfunction of sensors and actuators relating to transaxle control. If any malfunction is detected, the TCM informs the PCM by sending a signal (P0700 code). P0700 means that a code has been set in the TCM. This code is for information ONLY. If this code is present, check for transaxle codes. So basically, the P0700 code is telling you to check the TCM for a transaxle DTC. The TCM can not turn on the check engine light so it has the PCM do it.
I hope this helps....let me know if I can assist further !!
Feb 21, 2011 | 2002 Dodge Intrepid
Car does not run ,I check the code ,it is P0700
Because it is not starting, you should replace the Crankshaft sensor (above the oil filter, back of the engine)-it will cause a P0700-I have a 99 SL2, 178,000 miles
Translation: Transmission Control Module (TCM) Malfunction or Failure. P0700 Information Code The Transaxle Control Module (TCM) monitors the malfunction of sensors and actuators relating to transaxle control. If any malfunction is detected, the TCM informs the PCM by sending a signal (P0700 code). P0700 means that a code has been set in the TCM. This code is for information ONLY. If this code is present, check for transaxle codes. So basically, the P0700 code is telling you to check the TCM for a transaxle DTC. The TCM can not turn on the check engine light so it has the PCM do it. The dealer probably saw the code P0700 and went to the TCM and pulled out the code stored there telling them the Transmission Solenoid Assembly (TSA) is bad. This is a good example of understanding what the codes actually mean. If the manual you looked at said the TCM is bad and to replace the TCM when you see a P0700, then it is wrong.
Jan 24, 2011 | Saturn Ion Cars & Trucks
Error P0700. What is the cause? How to repair it?
P0700 JEEP - Transaxle Control System Malfunction
Symptoms
Possible causes
Tech notes: Since the P0700 is just and informative code, check the TCM for more codes to resolve the problem. So you'll have to have the dealer or another qualified shop/technician pull the transaxle codes from the TCM and go from there.
Good luck (remember to rate this answer)
Jan 17, 2011 | 2004 Jeep Grand Cherokee
Error codes p0700 and p2706
First check your wiring before you get inside and open the tranny up. Could be loose wiring, if not do the operation and make sure you do a heat test with the solenoid before you replace it.
Aug 02, 2010 | Dodge Durango Cars & Trucks
2000 chrysler voyager van
Since yours is a forward engine car. The transaxle must be located in the front.
Jul 14, 2009 | 2000 Chrysler Grand Voyager
Check engine light on 2005 town and country 3.3
Translation:
P1776: Solenoid Switch Valve Latched in Low/Reverse Position. The TCM monitors the L/R solenoid to ensure that the fluid transfer happens. It uses a Pressure switch to verify this. Usually this code is set by a switch that is stuck or a solenoid that is not mechanically operating.
A transmission shop would be better suited for this type of work.
Apr 11, 2009 | 2005 Chrysler Town & Country
Computers & Internet Logo
244 people viewed this question
David Payne
David Payne
