Question about X2 DL380 G5 X/2.33-1X4M 5140 2GB 1P P400/512 COMBO SBY (430028-005) Server
Continuous rebooting When I turn my surver on, it nevers goes into BIOS, all I get on the screen is a blinking cursor and then it reboots, I can tell that it reboots because the fan speed changes slightly and the screen goes blank again.
Check the power supply unit. POST is may not be reaching the board itself.
Posted on Jul 31, 2008
Powers on but has blank screen
Remove all media, DVD,CD,USB, Unplug, remove battery, plug in, reboot, Is the fan spinning? LED's blink? Sound? At reboot do you get a BIOS screen? Does the blank screen have a white cursor in the top left? Need more info.
Mar 02, 2013 | HP Pavilion dv4000 Notebook
Laptop cursor dark screen
can you tell me more about this situation, i build and troubleshoot computers all the time but this question needs more detail. you say laptop dark screen blinking cursor, the only thing i can get out of that is one thing. while booting up hit the f2 or delete key several times till you get into the bios, then find the tab that says default settings hit save and exit and reboot it, but more information would really help me to help you,
Nov 10, 2012 | Dell Latitude D620 Laptop (Latitude-C620)...
Tried F6 and F11 to reboot my compaq mini notebook, it's not working. When I turn on the notebook it shows F9 change boot device order and F10 BIOS setup options then it goes to a black screen with...
Hi
it may be worth trying the F12 key at startup it may work for you
good luck
or try the F8 key on start-up and try the back to last known good configuration
Jun 12, 2011 | Compaq Mini 110c-1001NR Notebook
I have hp dv9700, after improper shutdown kept rebooting
What happened is that you interrupted the disk write on 'saving settings'. Very BAD. You may be able to start in safe mode, by pressing F8 while windows is starting, then selecting options to attempt to repair. The alternative, is to boot from the windows CD and select 'repair'.
Feb 09, 2010 | HP Pavilion dv9500 dv9600 and dv9700 FF...
Blinking cursor after recovery CD
when cursor blinks, try to press any key!
tell me what error message it gives than!
Dec 29, 2009 | Toshiba Satellite A60 Notebook
My Acer Aspire One shows black screen only.
Acer Aspire One BIOS Recovery The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies and may void your warranty, so use at your own risk.
Follow every step carefully!
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn't reboot by itself wait 5 minutes before turning it off, just to be safe that it isn't still flashing the BIOS.
Download WIN98BOOT.ZIP and HPUSBFORMATTER from the internet normal bootable like a diskette won't work with a usb stick
I had mine 2 months it's a common problem with the notebook.
The onely thing that you have to do is download these programs with someone with a internet connection.
Good luck
May 08, 2009 | Acer Aspire One Netbook 8.9" Notebook
Won't complete the boot up
As far as the rebooting is concerned id check the bios boot order make sure it can see the HDD. You normally recieve that blinking cursor when it cant find the HDD or boot device.
Also have you tried using hte restore cd's It's a bit of a last resort effort but my guess is your HDD is dead if you attempt to run the Restore CD's and they fail it pretty much means its the HDD.
The cracking noises will be from the speaker wires either loose or touching something else causing a static type effect. Fix is to adjust wires possibly replace them. Not easy to do by yourself. Unlikely that the speakers are affecting the reboot though.
Other possibility is a faulty mainboard capacitors that will definatley rebooting to occur.
Let me know how you go with the bios and restore discs or if you need further help.
Mar 23, 2009 | Acer Aspire 5100 Notebook
Hp pavilion zv6000..Please HELP!!
That blinking cursor is the way in which the BIOS is telling you that Windows is missing - its most critical, core files have been corrupted beyond repair. The only thing you can do is to reinstall using the recovery cd or your own Windows install disk.
Mar 15, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
HP Compaq d530 SFF PC Desktop. Black Screen and Cursor blinking..
Try to enter in to BIOS by restearting the notebook (Pressing F2 function, if the notebook enters in to bios then no need to worry. after theat i suggest you to reinstall the notebook to original factory settings dy the recovery disks.
Mar 06, 2009 | HP Compaq d530 SFF PC Desktop
Cant boot
In your bios you should be able to change your settings for the hdd. Make sure everything in bios matches your hdd & then save changes & reboot. Hopefully that will allow you to enter windows.
Jan 24, 2009 | Computers & Internet
X2 DL380 G5 X/2.33-1X4M 5140 2GB 1P P400/512 COMBO SBY (430028-005) Server Logo
197 people viewed this question
Top X2 Computers & Internet Experts
 steve
steve
Bill Boyd
camjl
Are you a X2 Computer and Internet Expert? Answer questions, earn points and help others
