Question about Pioneer Audio Players & Recorders
My pioneer xc-p410m cd player willnot work when put it in it will not read disc and i did not ruin it i dont know whats wrong
SOURCE: Cd player
M-Error is a mechanical error and could have a multitude of causes. just went through it with a TAD-5160 unit where it was a small slip gear moving a tin lever to ingage the transport sled to insert or eject the disk from and to the carusel. You may have to take the unit apart and asess the problem. Harleysp.
Posted on Jun 06, 2007
  • 624 Answers
SOURCE: Hello I have a Pioneer XC-L11
It is most likely that the laser pick up is bad. That is the part that reads the disc and is the most common reason. You can try a lens cleaning disc to see if it just needs to be cleaned, but if that does not work you will need to take it in for service. This problem can be caused by several different things, from the spindle motor (spins the disc), to the pick up (reads the disc), or even an IC that controls one of those things. Once you have cleaned the lens, you can also try cleaning the disc's. If a disc has a fingerprint or scratch in the area of the disc that is know as the TOC (table of contents), it will not read the disc. Fingerprints in other areas of the disc will cause the player to skip or even stop playing. I use windex and a soft cloth like a bath towel to clean the disc's, it works as good or better than the disc cleaning kits you can purchase, and it is much cheaper.
If none of this helps, it has a problem that only a trained technician can figure out with the proper test equipment. Then you must decide if it is worth getting fixed. Some service centers offer free estimates, but those are the ones that don't actually check your equipment first before giving an estimate. They just give you a ballpark figure that is usually pretty high. To get an acurate estimate you normally have to pay for it. A technicians time is worth money, my shop charges $25 for an estimate.That is pretty cheap. Some are as high as $65 for an estimate. But if you are paying for an estimate, they will normally at least troubleshoot the unit and determain just what the problem is, compared to a free estimate which is just a guess and a ballpark figure usually high to cover the cost no matter what the problem is. You may also end up paying much more for a repair when you get a free estimate, because you have already approved that amount, and many shops will charge you that much even if they find a simple problem that only takes 30 minutes to fix.
Replacing a pick up normally cost about $125 to $150 because the part can sometimes cost as much as $75.
I hope this was helpful for you and lets you make an informed decision. let me know if you need any more help.
Posted on Jul 13, 2008
SOURCE: Stereo CD player/tuner XC-L11 not working at all
Just fixed mine - replaced 35v 47uf electrolytic capacitor in awu7837 module (inside shield case) - this module connects to display unit. see for more info and diagram Cost - 16 pence from Maplin p/n se47m35 kq68y
Regards, Dave
Posted on Sep 29, 2008
  • 226 Answers
SOURCE: unlocking LG DR787T
The LG DR787T will recognize CD-R media, and CD-RW for updating its firmware. Do not use DVD media. You have to copy the update to disc. There are instructions on the LG website on how to upgrade using CD media. Search for the file: "2_SoftwareUpdate.pdf"
Start here: LG Support - LG Global Site
Posted on Jan 10, 2009
SOURCE: Screen reads NO DISC
I had the same problem but I solved buying "Laser Lens Cleaner " Philips Magnavox after 3 attempts the DVD starts to work fine again. First only 3 min, then 10 min and now the entire CD cleaner and after I left the CD cleaner for 15 min I tried to play the DVD and WORKS!!! perfect!!!
Posted on Feb 16, 2009
Pyle pld3mu wont read disc
probably bad disc or possibly you used wrong screws in side of unit that went in to far and are blocking cd to operate properly
May 14, 2014 | Pioneer AVIC-N1 Car DVD Player
Cd player doesn't play cds
Pioneer is a very good cd player i know this from my friend having one, I know in some cases like yours if a CD player does not play cds it is a dirty or scratched lazor head( disc reader ), you could try buying a cd lazor head cleaning kit i done this a few times for cd players an my dvd player an it worked pop in cleaning disc an follow simple instructions about 10 mins at most that job if it works no worries, if a cd cleaning disc doesent work its more likely the cd lazor head is burnt out or past cleaning like my ford probes jvc cd player wont work because the reader is past cleaning sadly from age as its a car that has has 3 owners im looking for new cd player now, just try a cleaning kit few times if that will not work it may be ruined an you will have to get another sorry to say that but its same for me. hope this bit of help works
Nov 16, 2013 | Pioneer DEH-P77DH CD Player
My Pioneer PD-TM1 18 Disc player reads through all three disc magazines searching on each individual CD disc one at a time, and then will not play any one of the disc?
Seen alot of these "drop" the laser lens inside the unit! Have had some luck glueing the lens back on using radio/tv cement. Don't try super glue or it will ruin the lens! No luck replace the laser!
Apr 12, 2010 | Audio Players & Recorders
My cdj 800 is having a problem with cd reading.its not reading cds as it was new..just 1 year nw for my player.if put cd inside it cums out afetr 2,3times if i insert cd inside then it getging read......
Sometimes so CD does not play in certain CDJ, i have 2 or 3 disc which
does not play or eject when i try to play in CDJ 100s but when i play them
in another player they go well.
Pls try to have some other brand disc or you may clean compartment of the CDJ their may be dirt inside CDJ. I hope this will help.
Jan 29, 2010 | Pioneer CDJ-800 Turntable
Pioneer PD-F805 can`t read discs.
Few things either cd,s are not compatible
laser has died or laser ribbon cable is broken
Jan 07, 2009 | Pioneer PD-F805 CD Player
My pioneer cd/dvd/rw-dvr 111D will not recognize a cd in the drive, usually this happens with game cds. it does recognize some,but some it does not. i have put the same disc into another computers cd/dvd...
My cd drive does this as well not a good thing but I have found that if you put a disc you know it will read in then anydisc you want it to read it should read it. Mine only does it every now and then. I have also found that if just after the cd door closes if you give it a tap on the cd door it will read the disc try it it might work for you. I have taken mine to a repairer and the drive is operating fine and they could not figure out what was wrong for it to do that and yes it did do it for them to.
Jul 26, 2008 | Pioneer Computers & Internet
Please insert appropriate Cd
you need i dont know what one you need but heres the web site. the cost about $150.00 to $250.00 im looking for a place to download it for free but hasn't work.
Jul 21, 2008 | Pioneer AVIC-N2 Car DVD Player
Frmtread error
how can it solved?? My old mp3's work perfect, now i made a new mp3 cd on the 700 MB space, but it doesnt work anymore.. i get ERROR 23 on my display.. what to do??
Jul 02, 2008 | Pioneer DEH-P3500 CD Player
187 people viewed this question
Top Pioneer Audio Players & Recorders Experts
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
