Question about Panasonic KX-TG2632W Phone
KX-TGA242W My hand held phone unit does not display the person calling. I already have the service. Do I need to do anything special to activate it on my phone
I have the exact same phone but it wont show when the other people call or ring????? what can i do plz help(: thankx
Posted on Feb 16, 2010
  • HiTechGal Dec 21, 2010
    I had this problem too and a Verizon rep showed me where on their website under my account that I needed to enable this. I had the service, but it wasn't enabled. It was awhile ago, and it was buried under 2 menus, but they can also do this on the phone with you.
  • 54 Answers
No you do not once you call your phone company and have it added that is all.
Posted on Jul 30, 2008
How can i do two way on panasonic 5.8ghz
These directions are for the KX-TG5451, KX-TG5452 and KX-TG5453.
If you want to use the intercom feature, you need to know the handset number for the unit you want to contact. The base is zero. The handset number is set when you register the handsets. So to communicate with the base, press Intercom on the handset followed 0. The base will ring until someone presses Call to answer it (or one minute whichever comes first). (Alternatively, you can use the up/down arrows to select H1, H2, H3 or Base. Then press the right arrow key.)
To communicate between two handsets, press Intercom and then 2 (from handset 1 or 3 to connect with handset 2). Again the handset will ring for one minute or until the person with handset 2 answers. (To answer, they can press the phone, speaker or intercom button.)
If someone at the base wants to use the intercom, they need to press Select until the appropriate handset number is displayed. Then press Call.
To transfer a call, press Intercom and then select the desired handset. When the intercom message is picked up, indicate that a call is being transferred and press Off at the handset or base that initially answered the call.
For a conference call, initiate the call then press Intercom and select the handset to join the conversation. Once that person picks up, then press Conf. (I believe that Conf is a softkey so check the display.) This is only possible with the handset. (Another handset can join the conference by pressing the phone or speaker button on that unit.)
The manual for the KXTG5453 is available here: http://service.us.panasonic.com/OPERMANPDF/KXTG5451S.PDF .
If you have a different model of the Panasonic 5.8 GHz phone, please add a comment with the model number and I'll try to give the directions for that unit.
I hope this helps.
Aug 11, 2011 | Panasonic KX-TG5453PK 5.8 GHz DSS Cordless...
Hi, Can you help me my problem. I Need programming manual for KX-ta308. Specially for the restriction of outgoing calls on local extensions. Already downloaded a manual but cannot find outgoing...
Under alphabetic FEATURES, look at TRS (Toll Restriction) and COS (Class Of Service). It explains the concept of call restriction and how to program it.
We have a different 308 in the US, one that was built on a 624 platform, so a 624 features set will work, it just has a smaller number of lines :-)
Carl
Jan 31, 2011 | Panasonic KX-TA308 Phone
Panasonic kx-tga101s -- problem regarding making conference call - this is very much helpfull. But i have weird problem, i did call 1 person, and then i asked the person to hold and i made the other call....
Some Panasonic cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones.
Jan 26, 2011 | Panasonic KX-TG2740 Cordless Phone
How do you change the main display name on a Panasonic KX-T7453?
hello,
enter the menu of your phone, go to profile choose the profile you want and personalize it.
when personalizing change the name of the profile to the you want and activate the profile.
i am sure it will display your name.
thanks for using our website.
Jun 04, 2010 | Lands Phones
When receiving a call my nokia 1661 displays private no even though the number calling is in the contacts list. Any idea what I need to tweak to sort this very annoying problem...?
it is not your handsets issue it is a features where if that particular individual subscribed for his number to be showed as private number to everyone whom he/she is calling. You cannot do anything it will show if that person activated this service and it will not show you the name. ask that person that he/she activated any kind of services for private number.
May 17, 2010 | Nokia 1661 Cell Phone
How do I clear the numbers from the hand held phone as I want to donate the phone. The model is panasonic KX-TG2257.
There is an internal battery on the base unit, I am not sure if there is a door for it on this model. For the hand helds just remove the battery for a while.
Mar 02, 2010 | Panasonic KX-TG2257 Cordless Phone
I have the kx-tg 4500 4 line base unit phone. Line one flashes but does not ring or display caller. The other lines work fine. The handsets show no activity ie they don't even flash if a call comes in on...
I had the same problem once, turned off the base unit from power cord and the phone line and all connected handset units, then turned it back on & it worked.
Aug 05, 2009 | Panasonic KX-TG4500 Phone
Disconnection of computor to wirless modem when fax / phone hand held is activated
try to change the option for enabling the auto line transfer to handphone on pickup
(if the disconnection occurs during ur data transfer/FAX/voice call, this is usual..dont worry)
bye
Was my tip helpful?
Feb 11, 2008 | Panasonic KX-FPG175 Plain Paper Thermal...
Panasonic phone kx-t7630
Sorry I couldn't up load the manual for you but here's the link for you: http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Business-Home-Systems/System-Phones/Digital-Hybrid-IP-PBX-Phones/model.KX-T7630 You'll find all the programming settings on Pg 9. You'll need your "Pin code". I could not find anything on how to clear it if you forget it. You may need to go to a service center or call one. Good luck
Sep 08, 2007 | Panasonic KX-T7630 Corded Phone
Panasonic KX-TG2632W Phone Logo
488 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
