Question about Philips 55PP9502 55" Rear Projection Television
Tv turns on but shuts right off
55PP9502 TV not working. When the TV is plugged in and is turned on, the power light on the TV lights up like normal. Instead of hearing sound and seeing a picture and few seconds later, the monitor remains off. Sometimes I hear some clicks in the back like it’s trying to turn on but then just shuts off again.
  • 4 more comments
  • RyanV Jul 30, 2008
    I bought the TV on Ebay a couple months ago from a guy in Indiana. It worked great for the couple months and I really enjoyed it. I’m not exactly sure what’s wrong with it though. From what I read, it sounds like there could have been a coolant leak from one of the tubes and it got on one of the circuit boards. I’m thinking that maybe it started to leak on the car ride home from Indiana. We had to take back roads so that we didn’t go so fast, but they were very bumpy. To be honest, I had no idea that there was any kind of liquid coolant in those TV's until I read about it. That's what I think is wrong with it. Every blog and website says that's probably it. I don’t know if that’s the only thing either. So that's what I know.
    just wondering if anyone knows how much this might cost to repair
    I didn't mean to close this problem out, how do I "reopen" it?
    I still have to try the solution :-)
  • RyanV Jul 31, 2008
    how do I view more solutions? or keep this open incase the solution does not work?
    thanks again!
    if I have to replace the circuit board where do I get something like that? or would be it be smarter to take it to a shop?
    thanks!
  • RyanV Aug 06, 2008
    thanks, it turned out to be a coolant leak that damaged both boards, well over $700 to repair :-(
    Genius:
  • 1,050 Answers
Take it to a shop is probably your best option.
However, you don't have to physically take it around to shops.
Call them first. 1) See if they service that brand of TV 2) Ask about availability of parts. There are some that it is difficult to get parts for. 3) Ask if they can do the service on-site or if your only option is to bring it in 4) See if they will give an estimate over the phone. Shops all have different markups on parts, and labor can vary. Some shops have a base fee, some don't.
Best of luck with this. Let us know what happens.
Posted on Aug 05, 2008
  • Coss Aug 06, 2008
    Thanks for letting us know.
    It does help all of us to learn a little more.
  • 813 Answers
U have too see a professnol tv repairer
  • 6,487 Answers
It will be better to take it to repair shop and let them do the replacement and also to make sure that its really the problem for you also to save time and money..
Good luck....
Posted on Aug 04, 2008
  • Philips Master
  • 19,396 Answers
The TV safety switch is diagnosing an internal error (short, overvoltage, blown IC or capacitor) and is turning off the TV to avoid eventual further damage.
When is like that you need a technician taking apart the TV and testing components inside.
Check the last pages of your manual to find the Customer service telephone number, or take the TV to a local repairman.
  • Ginko
    Ginko Aug 04, 2008
    And recarding the fault, coolant leak is not a very common fault, more likely is a blown capacitor or IC.
  • 10,594 Answers
There would be another Bumpy journey for this TV going to repair shop :D
  • 4,234 Answers
FIrst of all, the click you hear is the main relay turning on and off. If a problem is detected, the set will shutdown. If a coolant leak is the problem, you should be able to see this quite easily by opening up the back and looking at the boards under the CRTs. If there was a leak it will be obvious.
To fix it requires perhaps a board change, but more importantly, a replacement of the fluid and resealing of the fluid "tank". Can you please examine the boards and let me know if there was a leak?
If there was not a leak, there are a number of things to check on that may be the problem.
Please let me know.
Dan
Posted on Jul 30, 2008
  • ABRsvcs Jul 30, 2008
    By the way, This is a CRT based set tehrefore no "lamp".
    Dan
    Genius:
  • 1,665 Answers
Its lamp probably needs replacement
Better have a tech to figure out what problem's cause.
    Master:
  • 382 Answers
The noise is probably the power supply in hicup mode or safety mode, that's what happens when a fault develops in the set which loads the power supply down. All you have to do is get a multi meter and go round measuring things like Resistance to earth from collector of line out transistor this should be at least 10kohm , then measure the various diodes that can be found in the power supply...Also check for any broken fuses...Try to replace them..Thank you...
Please post back on how things turned or for further assistance...
Regards!!!!...
  • 1 more comment
  • Natesan Sabesan
    Natesan Sabesan Jul 30, 2008
    Yeah well exactly to say If the whole Circuit is gone it may cost around 200$ but dont worry if this is just a fuse then you can finish it with just 3.15 $...Thank you!!!... :)
  • Natesan Sabesan
    The Cost for Replacing the fuse or Also The Whole Circuit Board is already Mention By me!!..But Thats just an approximation and not the Exact cost!!.. Thank you....
  • Natesan Sabesan
    Natesan Sabesan Jul 31, 2008
    HOpefully for replacing a Circuit board better take your TV to a Shop which is a Smart option and even bettter than calling a service Person to your home...
    Thank you...
    Kind regards!!...
    Top Expert:
  • Philips Master
  • 64,336 Answers
You have a short in the high voltage circuit supply board, what ever the cause most likely the price to fix it will be more than it is worth, esp. if it is a projection TV, I found this out 1st hand.
Hi, i have here a mitsubishi WD-57733. once the unit is switch ON, green LED light and a few seconds the status LED light then shuts off. I think light engines good since i just replaced a new lamp.
hello i've just checked the manual for here is some information
None TV is powered off. Normal operation.
Green TV is powered on. Normal operation.
Green 1. TV just plugged into AC outlet.
Wait until blinking stops before turning on (approximately 1
minute). Normal operation.
2. AC just restored after power failure.
3. TV Rebooting after System Reset was
used.
4. TV Rebooting after power fluctuation
or receiving abnormal digital signals
from digital channel, or digital device.
5. You have begun the procedure to
update software from an authorized
flash memory device.
For detailed information, see the instructions that accompany
the authorized software update. IMPORTANT: Do not
use unauthorized software at any time.
Green TV just powered off and lamp is
cooling.
Starts to blink 30 seconds after turning off TV. TV can be turned
on before blinking starts or after blinking stops, but not while the
indicator is blinking. Normal operation. hope it helps regards shaun
Green TV powered off and auto-on timer is set. Normal operation. TV can be turned on at any time.
Dec 06, 2010 | Mitsubishi Televison & Video
Hi I have a Sony Grand WEGA KDF-60XS955 TV
Ur right the cooling fan is defective,check it,clean it might work normal again.Not, than the cooling fan must be change.
May 04, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
My panasonic rear projection TV turns off
this just happened to us, we tried the reset button, didn't work. we unplugged from surge protector and plugged the tv in the regular wall socket and after a few minutes the green light quit and we were able to turn tv on
Apr 08, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Had a power outage while watching tv. Then 3 blinking lights.
This is an on-going problem with DLP sets. Normally you shut the set off and the cooling fan cools the lamp down and then it shuts off. In your case, of which it's not your fault, however your lamp has taken a major hit by not properly cooling down, in turn, you need to replace your lamp at this time.
I suggest in the future if you have an electrical storm and a chance of a power outage while your watching tv, I would'nt play that model or any other model of a DLP set.
Jun 23, 2009 | Samsung HL-S5087W DLP TV
Sony bravia tv
Solution is simple....
First, unplug power cable from the back of your TV. You will notice the flashing light is still flashing. Don't worry, go to the Second step.
Second, keep pressing on the POWER button, located on the panel at the top of your TV, to shut off your TV. This will stop the flashing light from appearing.
Third, Plug the power cable back onto your TV
Fourth, press the POWER botton ONCE, using the same button used in the Second step to turn your TV back on.
Fifth, you will see the POWER light comes on, as normal.
Sixth, using your remote control, press the green button to turn on. Your TV should work as normal.
Jun 08, 2008 | Televison & Video
Will not turn back on
Take off back cover. The problem power board is to the right of the board where the power plug feeds into the TV. There is a large white fuse right bend the power plug. With a meter it read ok; about 8 inches deeper into the TV on that board was the resister next to two fuses. My 4 amp 125 volt fuse did not read on my meter. After replacing, it worked fine.
Feb 12, 2008 | Pioneer SD-P50A3Q 50" Rear Projection...
55 inch (55pp95 0217) turns on then clicks off
I believe what you have there is a Philips 55pp9502/17 and with hose symptoms it's most likely the Smd capacitor 2009 on small signal board is leaking. Replace 2009 using 319801634710. Locate 2009 on the flyback side of the ssb, above the marking for ic7011 which is absent. Caution: remove ac power for at least 10 seconds before removing the Ssb from the chassis.
If you're not that good with SMT (surface mount technology), like some of us techs simply replace the ssb as a module, Philips p/n# 310432815384...
Bill
Oct 31, 2007 | Philips 55PP9401 55" Rear Projection...
TV won't turn on
Ready? The solution is = Replace four capacitors inside DM module 1000mf / 25v high temp. For details.........Look @..
www.Chris@ChrisAndNat.com.................T.
Oct 24, 2006 | Mitsubishi WS-55613 55" Rear Projection...
TV auto shut off-power indicator light blinking-won't turn back on
You could have gotten an electrical surge that put your set into a shutdown condition and unplugging the set and letting the Microprocessor reset will fix this problem if it dosent blow out the main power regulator as you still or might I say have a regulator IC problem. IF THIS PROBLEM HAPPENS AGAIN MORE THEN A FEW TIMES WITHIN A SMALL TIME FRAME I WOULD HAVE THE SET LOOKED AT BEFORE THE REGULAOR BLOWS SOMETHING OUT!!!!
Jan 11, 2006 | Toshiba 43H70 43" Rear Projection...
Philips 55PP9502 55" Rear Projection Television Logo
248 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
