2002 Chevrolet Impala Logo
Posted on Dec 20, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
02 Impala 3.4L. cooling fan 2 siezed. replaced whole fan tray including both fans. Fan 2 alway has 14vdc but never comes on. only fan 1 come on in high speed cycles. Swapped relays position 1 and 3 (fan 1 and 2) and swapped fuses (fan 1/2, cntrlr). No matter what fan two never comes on. [email protected]
Dan Hooper
Level 3:
  • Chevrolet Master 4,521 Answers
  • Posted on Dec 20, 2017
Dan Hooper
Chevrolet Master
Level 3:
Answers
4521
Questions
Helped
808917
Points
14307
Fan #2 should only come on if the A/C is on or the engine temperature gets over 200-205 degrees.
5 Related Answers
valkierneth
  • 76 Answers
  • Posted on Apr 19, 2009
SOURCE: FAN SPEED CONTROL DOESN'T WORK ON #1.
chevy's have a problem with the resistors losing conection and causing resitance which melts the connection check at the heater box it should be under the dash. there should be a harness that plugs in with several wires near the motor check this for any signs of melting. hope tis helps some
Anonymous
  • 10 Answers
  • Posted on Jul 07, 2009
SOURCE: I swapped my 17
go to your nearest tyre shop and get some tyres with a closer rolling diameter to your factory ones you can do damage to other coponents not just your spedo out
roniecon
Ronny Bennett Sr.
  • 6988 Answers
  • Posted on Jul 09, 2009
SOURCE: a/c blows hot air at idle
u have a trinary type switch on the high side somewhere on the high side,,,it may have 2 or more wires going to it and it is mounted on the high side line/or compressor,this is ur problem
Anonymous
  • 38 Answers
  • Posted on Aug 11, 2009
SOURCE: 2003 impala is it a temp sensor or cooling fan switch
Maybe your radiator is clogged flush it out.
Anonymous
  • 1187 Answers
  • Posted on Sep 18, 2009
SOURCE: 2001 Impala Cooling Fan Not coming on ever and car
Cooling fan relay switch (in the fuse box uner the hood). Look for othger relays in there that are the same type number (they are all marked). If you find one that is the same as the cooling fan relay, then swap the two relays and check. (Turn on car and turn on A/C ... fan will start ... or not).
Fan motor could be bad (most likely).
If you remove it yourself, don't scrapr the radiator fins with the fan blades.
Hope this helps!
1helpful
How to replace cooling fan assembly on 2002 jaguar xtype
you can remove from the underside by removing the lower plastic bumper cover, the torx screws will be more than likley siezed, you then have access to the rad fan unit.i think you can just about remove the fan unit without the radiator or you may have remove the whole lot but you will have to remove the support bar, 4 poss siezed bolts.drain the cooling system first then sort it on your bench,hope this is helpfull,
Cont question on impala ck engine
Haven't yet checked the coolant temp sensor ? Does the vehicle shift good , engine run good ? If yes the coolant sensor isn't any problem . Is this your only problem ,The 25 amp mini fuse that keeps blowing is labled as fan cont #1 > You have a direct short to ground on the circuit that fues powers up . Do yo know how to find a short ? Videos on youtube for checking for shorts . It's probably a wiring problem . Insulation rubbed through , touching metal on the vehicle somewhere . Your vehicle cooling fans have two speeds low an high , that's it . Relay Driven Dual Cooling Fan Diagnostics
1helpful
Ck engine light problem on 2001 Impala
Well the code is for the circuit - the computer commands the relay to turn the fan on and it doesn't happen.
The computer provides the ground for the relay.
If you have replaced the relay and the fan and the fuse still blows, I would look for a problem in the harness between the fuse box and the fan, including the ground circuit for the fan.
The fuse for the cooling fan is usually a 30amp marked "cooling fan" in the fuse box in the engine compartment.
Do you know what the 25amp fuse that is blowing is for ?
Cooling fans won,t come on
1 fan is for cooling the motor and the other fan comes on when the ac is turned on or its very warm outside it 2 stage
2001 Chevy Impala. Location of cooling fan relay on it please?
Chuck Smith, why are you answering an unanswered 11 year old question? :>D
Always include a link as proof. This vehicle has three relays.
Relay FAN CONT #3
Secondary Cooling Fan (Passenger's Side) Relay FAN CONT #2
Cooling Fan Control Relay Relay FAN CONT #1
Primary Cooling Fan (Driver's Side) https://www.startmycar.com/ca/chevrolet/impala/info/fusebox/2001..
7helpful
2answers
4helpful
3answers
The cooling fans stop working
check your sensor that controls the cooling fans.may need to be replaced.
2helpful
3answers
2001 Impala Cooling Fan not coming on ever and car running hot. Temp sensor on manifold has been replaced with a brand new one.What to check next?
Locate and replace the fan relay, you can purchase a electrical component locator which is packaged on cd repair manual at ebay motors $20.00.
4helpful
2answers
Cooling fan on car doesn't work
check the ac switch if it is a factory duel fan set up, it will come on with the ac compressor or with a temp sensor. also check for voltage at the fan that does not come on with a volt meter... always check the source voltage, if needed to eliminate a bad fan motor run a separate power wire to the fan to see if fan motor is good.. please rate my help, thanks
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
