Linksys Wireless-G Broadband Router Logo
Anonymous Posted on Mar 05, 2011
RE INSTALL 2.4 GHz WIRELESS-G BROADBAND ROUTER .CANNOT RECALL PASSWORD CANNOT COMPLETE SET UP>?????? JERRY HELP. [email protected]
daPete
Level 2:
New Friend:
  • Expert 109 Answers
  • Posted on Mar 05, 2011
daPete
Expert
Level 2:
New Friend:
Answers
109
Questions
0
Helped
30436
Points
342
Perform a hard reset by inserting a paperclip into the reset hole while powering up. To access the router use address http://192.168.1.1
On older LinkSys routers, the username is set to blank and the password is set to "admin" (without the quotes). On newer Linksys routers, both the default username and the default password are set to "admin".
  • hulagrany Mar 23, 2011
    Thank you so much daPete for telling me there was a reset hole in my router. I hadn't seen it and kept telling everyone that mine had no reset button!
  • daPete
    daPete Mar 23, 2011
    You're welcome.
Anonymous
Level 2:
  • Expert 242 Answers
Anonymous
Expert
Level 2:
Answers
242
Questions
0
Helped
75983
Points
807
You can reset the router by pressing the reset button on the back. Login to the router at 192.168.1.1. default username and password should both be 'admin'. You can then make the necessary changes you need.
Hope this helps
Ray
How can I get the router IP of my Linksys 2.4GHz broadband router?
The Linksys G router gives you both wired and wireless connections over a broadband Internet connect to create a local area network. The Linksys router is compatible with wireless G and B devices, through the 2.4-GHz wireless band. The wireless speed is at 54 megabytes per second and you can get 100 megabytes per second with a wired connection. You have to set up the wireless configuration on the Linksys before using it on your network.
Plug the router's power cable into an electrical outlet. Attach an Ethernet cable into the Internet port on the back of the router. Connect the other end into your broadband modem. Connect your computer to the Linksys G using another Ethernet cable. This Ethernet cable can go into any of the wired router ports. Open your Internet browser. Type "192.168.1.1" in the address bar and hit "Enter." This is your router's IP address and the home of its Web configuration page. Click "Wireless." Click "Manual." Alter your SSID, also known as your network name. You can change this name to any value that you want. You can also change the wireless channel if you are in an area with many wireless connections that may interfere. Click "Save Changes." Click "Wireless Security." Choose an encryption method to encrypt your wireless transmissions. WPA or WPA2 are common security protocols you can use in wireless networks. Input a network key, also known as the network password. Click "Save Changes."
Setting Up WPA Wireless Security on a Linksys Wireless Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=3696 Wireless G-Broadband Router support http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G b> b> Changing the Wireless Network's Name (SSID) on a Linksys Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=4037
Change password
First open the browser ->put the IP address(normally IP address of d-link router is 192.168.0.1 but you should check the manual ) ->login using username and password.
Go to the "Security" tab or option and click on WEP or WPA, select the encryption, choose a password and click save or apply.
If you need any kind of technical assistance you can contact for Router support
Is there any way to find out what the current username & password are? I prefer not to reset the router because we have a gamebox attached to the router now & I don't want to goof it up.
Do you have at least one computer which has connected to that router via wireless? If so, the password should be stored in that computer.
If that computer has Windows 7, there is a built-in function to display the password. Go to:
Start > Control Panel > Network & sharing > Manage wireless
That will being up a list of routers. Find the correct one, right-click and select "Properties".
That will bring up an info box for that router. Select the "Security" tab, The security key (password) will be hidden behind asterisks. Place a check in the box for "Show characters". That will display the password
If the computer which has connected to the router has an older operating system (Vista or Windows XP), then you may not have that built-in password display feature. But you may still be able retrieve the password by installing some specialized software.
Here are two suggested free software programs to display wireless passwords:
WirelessKeyView by Nirsoft:
http://www.nirsoft.net/utils/wireless_key.html
http://www.softpedia.com/get/Security/Decrypting-Decoding/WirelessKeyView.shtml
Advanced Password Recovery by Josh Cell Software:
http://www.joshcellsoftwares.com/2011/08/advanced-password-recovery-password.html
http://www.softpedia.com/get/System/Back-Up-and-Recovery/Advanced-Password-Recovery.shtml
Hope that's helpful.
2answers
I forgot my pass word and want to change it. My daughter put in her security pass word and can't remember it for a wireless-G 2.4 GHz Broadband rouuter.
Hello
You can do a factory reset.
1 unplug all cables to router.
2 Hold down small reset button behind router,use a pen tip to hold this button in for 30 seconds.
3 Reconnect cables,power cable first.
4 Log into router using default password and username.Which should be......
username=admin
password=password or admin
Once loged in you can reset your username and password to what you want.
How to set up The wireless G 2.4 GHz broadband router linksys?
Plug a computer into the router. Open your web browser and in the address bar type 192.168.1.1 or 192.168.0.1 If the router is fresh from the factory the login will be admin and the password will be password This should get you into the configuration for the router.. from there look on the left side of the web page and you will find config options for all aspects of the router.
Want to connect aDI-604UP wired router to a DIR-615 wireless router to use as a printer port wirelessly
Hello Richard.
For this, you have two types of connection
1. LAN_LAN (ethernet to ethernet) -->wireless router is acting as a switch
2. LAN_WAN (ethernet to internet)-->wireless router is acting as a wireless router
in this case, you need the LAN_LAN connection
Physical connection:
plug an ethernet cable from the ethernet port on the wired router and connect the other end of that cabl to the ethernet port on the wireless router
Configuration:
log-on to the setup page of the wireless router, do this while the wired router is turned off.
-open your internet browser, type 192.168.0.1 on the address bar. Then type the username & password for the router ( default admin as the username, password : ).
Under the setup tab, click manual configuration. Then click network settings, change the router ip address to 192.168.0.5 & disable the DHCP server. save the settings. Just personalize the wireless network.
Hope this helps.
1helpful
How do I secure my router with a passcode ? I am a customer with hughes net and i have tried for 4 days to get my router secured. i have spoke with several reps and have been told several different things...
Do this on your wired computer
Step 1:check your ip address
  • click start>run>type cmd on the run box, command prompt will be opened
  • type ipconfig/all > look for default gateway under Ethernet adapter Local Area Connection
Step 2. access the setup page of your router
  • open you internet browser > type the default gateway numbers on the address bar
Step 3. personalize your wireless network
  • go to the WIRELESS tab > personalize the Network Name( SSID )
  • go to the wireless security SUBTAB > personalize the wireless password ( ideal security mode will be WPA-personal or WPA2-personal
Don't forget to save the settings
6helpful
2answers
Have Linksys Wireless-G 2.4 GHZ 54Mbps Broadband router. Bought a new desk top computer and it won't let me install the CD. Linksys tech support was unable to assist because the warranty had expired. I was...
Hi there, you don't need to install from the disk. Make sure your modem connects to your router and then the computer's LAN port is connected to the LAN port of the router. Open internet explorer and in the address line type 192.168.1.1 this will connect you to the router's setup. On older Linksys routers the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin." You then can find the wireless setup to configure your router. Make sure if you use a WEP code you use the same code from your computer's wireless adaptor. Good Luck...
Net gear was completely disconnected from computer. net gear WPN82r v 2 was inadvertently reset. dont have a password. any help
To bypass the wizards, connect the router via an Ethernet cable, log in from a DHCP enabled (IP & DNS) computer at
http://www.routerlogin.net/basicsetting.htm
User name is admin and the password is password, both in lower case letters.
Note that wireless connectivity is off by default. When you configure this router manually , remember to turn the wireless connectivity on.
Linksys Router Installation Model Number WRT54GX4 with SRX
Booba,
With your question about the internet type you are right to set it to DHCP. And For the password you are also right. Now for the ssid that will be the name that your router will be broadcasting. If you can get your computer online through port no.1 on the router that only means that the router is already configured properly for internet connection. Now since the wireless is not working its possible that its not connected yet to the wireless network that you have set up where you were running the setup cd. Do you know how to view the available networks on your wireless computer? If you kindly provide me with the operating system of your computer that will go wireless on your network and also the model no. or the brand of the wireless adapter on it.
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
