This problem should be removed because:
Problem with Poulan 14" Chainsaw
no oil to bar
Solutions (1)
Best Solution
Drain the oil tank, now will witha suitable cleaning fluid, rinse the tank out several times, this will help to remove any dirt in the oil filter screen, remove the bar and chain, clean out the bar rail and oil feed, now try again.
Testimonial: "I'll know more when I go to the shop to try it, but this is info that I can use and has the sound of a pro's advice,"
bar oiling problem
Put on new oil pump assembly, new bar chain clutch, sprocket, worm gear. Make one or two cuts and oil hole in bar plugs up with saw dust....
Bar sprocket smokes, gets hot spot
Poulan Pro PP4620AVHD 20" saw, runs great, shows oil on bar near powerhead but bottom of bar near sprocket gets hot spot, somkes &...
stihl 180 chainsaw,lack of oil to chain and bar
chain and bar no or very little oil ,chain and bar getting very hot quickly. the underneath of oil tank/engine area seems damp with oil
do you have to use a special bar
do you have to use a special bar oil for chainsaws?
no oil to bar
no oil to bar
Add Your Solution
42cc 14inch poulan wood shark service manual, I...
i need trouble shooting help to get my saw to run, fuel lines are fine, Im getting spark, and the breather is fine and...
Problem starting chainsaw
I was using the chainsaw for a while and then turned it off. I can't restart it. Something seems to be preventing...
the chain did not break but came off how do i fix
the chain did not break but came off how do i fix it.
The chain came off the
The chain came off the sprocket and stuck in the adjacent crack. I removed the sprocket cover and put the chain back on...
Fix-O-Meter
72
72 people viewed this problem
- 1 person found this problem to be helpful.
- 2 people are following this problem
Top Poulan Chain Saw Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
I put some gas in the oil tank after draining it, replaced the lid, and shook it for a bit; then I emptied, refilled with bar oil and closed it up. I went over the bar really well; I had forgotten the passegeways between the oil holes and the groove that the chain runs in, but I unclogged them. Oil still doesn't come out with engine running and bar off or with the bar on. Seems like there is a diaphragm pump under the clutch that runs off the shaft that's not working.
It depends on what model this is, most machines will have a mechanical oil pump behind the sprocket, either driven by the sprocket itself, or driven by a gear predded onto the crank, if the drive gear is metal, then the pump shaft gear will be nylon, it may well have striped this gear, to get to this you will need to remove the clutch and sprocket, clutchs are usually just spun onto the crank with a left hand thread, this is why you should NEVER run the saw without the bar and chain fitted, or the clutch could fly off the end of the crank and cause personal injury.once the clutch and sprocket are removed you should see the pump, check both drive gears, pull the pick up pipe out and check for blockages.
hey adw1 ! right on advice again. I found the parts drawing on the P{Poulan site, and ordered the pump kit, pick up tube kit, and th "oil-vent check valve". I'll let ya know how it turns out. I'm new to Fixya, is there a place to make a donation for your help ?
thanks again
watkibe
View More Comments
