Question about Samsung DVD-R155
I am not able to use a DVD-RW ?? The disc is not accepted ? What type of DVD-RW I need ?
    Genius:
  • 1,041 Answers
This unit allows you to record and playback high quality
digital images on DVD-RAM/DVD}RW/DVD}R discs.
You can record and edit digital images on DVD-RAM/
DVD}RW/DVD}R discs.
Posted on Mar 05, 2011
5 Suggested Answers
SOURCE:
eswaran73
SOURCE: Loading DVD-RW discs
My recorder has stopped accepting NEW DVD-RW discs and ejects them.
There is no problem loading DVD-R (new or recorded)or loading previous recorded DVD-RW, initializing and re-recording
I have tried several different DVD-RW makes. Puzzling??
Posted on Nov 08, 2008
SOURCE: My recorder has stopped accepting NEW DVD-RW discs and ejects them.
I had the same problem. After trying several brands, the only one which is working perfectly is Maxell (yellow discs). I found them is the US (Seattle), have not seen them in France where I am leaving. Hope it can help !
Posted on Feb 27, 2009
SOURCE: Will not accept DVD -R or DVD +R discs . Will play
Found out on another site that Cyberhome DVD player will only accept certain makes of disc and always struggles with DVD+R. Their was a Firmware update which supposedly solved this problem but this is no longer available, It's old anyway and was very cheap - will buy a new player!!
Posted on Sep 07, 2009
Mrteaze
  • 101 Answers
SOURCE: I need the update for the Dvd+r /rw discs. i can
I don't think there is an update available I did extensive research and found that this product is garbage with nothing but problems and to top it off the company has no internet site no phone no address ... go figure ... Best I can do for you is ... Use what works till it no longer works then trash it ... sorry:( and on a good note ... Sony and TDK are the Best media out there and work when no others will!!!
Posted on Sep 29, 2009
Testimonial: "Thank you so much for your research. I have had excellent recording with my recorder. I can record movies from my movie channels."
How to erase a dvd dics
dvd are read only.
dvd-r; dvd+r and dvd-rw are the re-writeable discs. mostly once only.
DVD Media Formats Explained
There are many different types of writable and rewritable DVD media on the market today. These formats include:
There are also "General Purpose" and "Authoring" discs. DO NOT confuse the "Authoring" media with the term for content development (making / editing what eventually goes on the DVD). The most common type of DVDR is the General Purpose type - if you do not know that you have an actual authoring recorder drive then you most likely have the general purpose type.
DVD-R is a write-once recordable format which allows excellent compatibility with both standalone DVD-video players and DVD-ROM drives. There are two main types of 4.7GB DVD-R discs: DVD-R for General Use and DVD-R for Authoring. Most consumer drives use the former cheaper General Use discs, while many higher end professional drives use Authoring discs. The correct media type appropriate for the drive must be used when burning. However, once burned, the discs should be able to be read in either drive type. (General Use DVD-Rs are designed to prevent backup of encrypted commercial DVDs).
DVD-RW uses rewritable discs which are rated at more than 1000 rewrites in ideal situations. Unfortunately, DVD-RW does not enjoy the same excellent compatibility with DVD-ROM drives and standalone DVD-Video players that DVD-R enjoys. Another drawback is that unlike DVD-RAM, one must generally erase a DVD-RW disc before reuse.
Most DVD-RW drives should also be able to record to DVD-R. However, the reverse is not true. Many older and some current DVD-R drives are not capable of writing to DVD-RW discs (but may be able to read burned DVD-RW discs). Some drives can also record to CD-R and CD-RW.
Currently DVD-RW and DVD-R are most popular in the multimedia market as well as the general consumer market. For instance the Apple SuperDrive, found in higher end Mac computers used in multimedia creation, is simply a DVD-R/DVD-RW (and CD-R/CD-RW) capable drive.
DVD+RW, like DVD-RW, is a rewritable 4.7GB DVD format. DVD+RW, however, in some ways offers some technical advantages, which for example include: lossless linking (which in turn more readily allows editing of a disc's contents after an initial write while maintaining integrity of the remaining data), currently slightly faster recording speeds, and optional future Mount Rainier drag-and-drop file access support (also known as DVD+MRW). However, DVD+RW does not have the very high compatibility with standalone DVD-video players and DVD-ROM drives that the DVD-R format enjoys. The level of compatibility of DVD+RW is said to be similar to that of DVD-RW. Also, DVD+RW does not currently have the same level of market acceptance as DVD-R.
DVD+R is a format that only was introduced to the public very recently (early 2002). DVD+R is a write-once 4.7GB format which promises to dramatically increase the compatibility with standalone DVD-Video players and DVD-ROM drives. Whether that claim is fulfilled remains to be seen, but initial reports have been very positive. It must be noted, however, that 1st generation DVD+RW drives do not support DVD+R burning, and it is likely that most cannot be upgraded to do so either. If one wishes to have DVD+R burning functionality, one must purchase a newer drive specifically designed to do so. DVD+R discs currently are somewhat more expensive than DVD-R discs, but prices will likely drop with time. Burners that write to these discs is the HPDVD100i and the DVD-Writer DVD200i drive
Thanks to www.AnandTech.com for this helpful information AnandTech Home
Mar 07, 2016 | Televison & Video
Will not accept nem rw disc to record to
then u have kept the settings to finalize disc
u need to change the settings.
Jun 19, 2008 | Televison & Video
My Philips DVD Recorder does not accept a DVD disc shows no disk. The DVD disc does not revolve. A CD disc revolves but shows junknown
Could be that you are using the wrong type of DVD ? There are two formats DVD+R, DVD+RW etc and DVD-R, DVD-RW etc. Some machines are capable of using either, others can use one of the two formats.
My other suggestion is that some machines are picky about which manufacturer's DVDs they will use.
6.November.2015
https://en.wikipedia.org/wiki/DVD_formats
if you have an error code this might be useful
Dvd recorder won record on DVD RW disc
Some possibly relevant answers here which suggest my answers above
http://www.digitaltvbanter.co.uk/uk-tech-digital-tv-digital/25025-brand-new-panasonic-dvd-recorder.html
Nov 06, 2015 | Philips Televison & Video
When trying to play a computer generated DVD +R DL, I get a message that says this type of disc cannont be played. please insert a different disc
The disc is probably an incompatible format for this model player. Even if the disc is finalised in your PC, or in a DVD recorder, this player may still be unable to read it. Some DVD recorder/players do not recognise DVD+R (or +R DL) media, while others won't recognise +/-RW discs (except CD-RW); this is a model limitation - not a fault with either your player, the PC burning software or the discs themselves.
Nothing can be done to fix this except purchasing a model which accepts multimedia (+R/DVD-RAM etc). The question is, does your player play ANY normal DVDs? I am guessing your player will accept DVD-R DL discs just fine since this is standard as well as proper shop-bought movies.
Feb 19, 2011 | Panasonic DVD-S35 DVD Player
My LG DVD RECORDER, MODEL RH7500 won't play DVDs.
Check the model specifications for your device. Some players will only accept DVD-R and not DVD+R or not DVD+RW discs. I know it all seems the same, and it's very frustrating, but many companies restrict the type of discs they will allow. My player does +R but not -R. It should still be able to read DVD discs that you made yourself, but they will be of a different type.
Nov 03, 2009 | Televison & Video
What dvd do i use for philips dvd recorder r610 is it plus or minus can you please answer this
Depends how its marked if its DVD-RW it use minus, if its DVD+RW its uses plus. If its
DVD-RAM its for DVD+/-RW (and CD-R, CD-RW, DVD+/-R).
Dec 09, 2008 | Televison & Video
No disc
with these types of DVD RECORDER unit ,you have to purchase a specific DVD+RW brand so the system can accepted . I have this problem once , I ended returning the unit and getting a DVD RECORDER that will be compatible for all DVD players . Like the PANASONIC DMR-EZ27 ,hope this info helps you.
Apr 26, 2008 | TruTech TT1620 DVD Recorder
Dvd writer wont accept dvd-r
If you have posted the correct model of writer, then it only supports the writing of DVD+R and DVD+RW discs, but CD-R and CD-RW disc writing are supported, and it should play all forms of DVD, so it won't burn DVD-R and RW discs, but if it wont play all types then try a cd/dvd cleaner, but to be honest when writers start playing up the lens is normally faulting and a replacement drive will be required.
Jun 18, 2007 | HP DVD Writer (ds703a) (DS703A) DVD+RW...
Nov 03, 2006 | Pioneer DVR-5100H DVD Recorder
Samsung DVD-R155 Logo
95 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
